Aiptasia Removal from rock.
Postby kipper31 » Fri 07 Sep, 2018 9:48 pm
How is best way to kill aiptasia from live rock that I’m wanting to reuse in about a months time.
Basicly shutting down one tank,want to kill a heap of pest and then reuse rock in a months time in a new setup but want aiptasia 100% killed with no chance of It comeing back.
Not concerned about leaving rock filled with phosphate,just want aiptasia gone.
New tank will be cycled as per new setup,with existing liverock from a smaller aiptasia free tank.
kipper31
Re: Aiptasia Removal from rock.
Postby uglyman » Sat 08 Sep, 2018 12:26 am
If you want to keep the live rock full of bacteria just get a small hobby butane torch and burn all the aiptasia you can find but for me I would acid dip then bleach the entire rock just to be 100% sure.
I got so sick of aiptasia in my system I nuked all my live rock with acid and bleach but they have returned thanks to some still being in my sump baffle and even to my amazement in the plumbing (No they don't need light to survive) grrrr.
Good luck :crossfingers:
Uglyman's 4ft LED lit mixed reef
If your not prepared to be wrong, then you'll never come up with anything original.
Join the Marine Aquarium Society of Victoria today!!
Join MASOV's Facebook Page
uglyman
Postby Slartibartfast » Wed 12 Sep, 2018 2:06 pm
I have been very lucky, I got a single peppermint shrimp and it destroyed the aiptasia in two days flat never to return.
But yes, acid and bleach will kill most nasties. If you then have spare time I would put them in the black drum with saltwater and a pump and do a 100% water change once a week. Will get rid of some phosphate until you ready to use it again.
Slartibartfast
Postby TbyZ » Sat 15 Sep, 2018 5:32 pm
I injected kalkwasser paste into the aiptasia & that seems to have done the trick
TbyZ
Postby Aydee » Mon 17 Sep, 2018 4:32 pm
I dropped the rock in vinegar for about 5 minutes (Excessive I know). Then rinsed thoroughly. I mean really thoroughly. This kills a lot of the bacteria, but I then got a big plastic tub. Put NSW in it. Heater and pump. Drop rock into this with another rock that wasn't infested with aiptasia.
There will be enough die-off from this that you'll repopulate the rock in fairly short order. Basically do a little cycle with the rock again.
Will guarantee aiptasia is gone.
Aydee
Postby mcs » Sun 07 Oct, 2018 5:54 pm
Might be a bit late, but for future or for anyone else, a fellow reefer and i found that just wacking a bit of super glue over the top of them worked really well, i actually totally removed them from my tank in this way.
Cheers.
mcs
