Tommo's 4x2x2 - New FTS
Postby tommo77 » Sat 25 Jul, 2009 4:09 am
Hey guys, after reading through this website for the past few months i have decided to do my own tank journal.
System Objectives: What is the end result going to be?
Happy and healthy system with nice fish and some nice corals
Mixed Reef mainly LPS
June 09
4x2x2
Display Lighting: Lighting specifications.
Guppys 150W halides supplemented with 4x54W actinics
Stand: Stand specifications.
3 door stained pine cabinet
Hood: Hood specifications.
Sump: Sump specs if applicable.
3x14x18 consisting of 4 compartments drain/skimmer, DSB with macro on top, Live rock rubble, Return pump/filter sock/carbon sock which is fed by a smaller pipe from the drain!
Refugium: Refugium Specifications if applicable.
Refugium Lighting: Lighting specifications.
25W 5000k Compact fluoro which is mounted on the underneath of cabinet
System Water: NSW
Display Water circulation: In tank water circulation.
Tunze 6025 2500L/hr - modded
JVP 12000 L/hr
Return Pump 4000L/hr
Return Pump:Sump return pump.
pondmax 4800L/hr
Skimmer: We all got one do you?
Aquamedic Turboflotor multi sl
Evaporation Top Up:Auto topup or manual?
Manual from RO unit
Calcium Addition: Damprid
Alkilinity Addition: BiCarb
Magnesium salts or epsom - measured 30ml scoop twice weekly, probably too much
Iodine 5ml twice weekly
Nitrates: >5ppm
Phosphates: N/A at the moment
Alkalinity: On my carbonate hardness tests it measures 140ppm
Calcium: 450ppm
Magnesuim: N/A
Fish:
1x Blue Tang - 5cm
1x Lipstick Tang - 5cm
1x Long Horned Cowfish - 2cm
1x Coral Margined Butterfly - 4cm
1x Yellow Tail Cleaner Wrasse
1x Striped Goby - 4cm
3x Anthias - 3cm
2x Perculas - 3cm
Inverts:
Skunk Cleaner Shrimp
BTA - Split into 3
Peppys
Corals:
Fluoro pink and Ice Fire's, Orange, pink/red, lime green, green/lime green, purple with gold rim, dark green zoanthids and yellow
Purple, Red, Green Morphs
Tubastrea
Torch
Organ Pipe Coral
Xenia
Green tipped Sarcophyton
Lobophyllia
Duncan
Finger Leather
Cataphylia
Green Toxic Hammer
Here's a few pics
My two foot nano which was taken down and given away
My 4 footer
Pics arent that great but i will work on that :nut:
Any thoughts about anything to help me out would be greatly appreciated!!
Tommo's 4x2x2
tommo77
Postby tommo77 » Sat 25 Jul, 2009 4:13 am
If someone could tell me how to re-size the pics that would be great! Will put some more pics up soon of QT and fish as well as the sump install!
Tommo's 4x2x2
tommo77
Postby SaltwaterTankLover » Sat 25 Jul, 2009 11:25 am
Cool Tank.
Got any pictures of the tangs???
-Matt
SaltwaterTankLover
Postby lachlanmiller » Sat 25 Jul, 2009 2:25 pm
hey. i have a 2foot nano as well, i upgraded to a 2x2x2, and am planning a reef octopus nw-110 or a marine sources ms 120, but was hoping to keep the 2foot nano in service too. How did you get your airlift skimmer to work. what size pump did you run, i just cant get it tuned. i can either produce way too much skimate, or when i tune it down, it produces no skimate, just fills the cup with bubbles. any tips?
<a href="http://www.masa.asn.au/phpBB3/viewtopic.php?p=682669"> 2x2x2 Cube Journal</a>
<a href="http://www.masa.asn.au/phpBB3/viewtopic.php?p=633797">Oldness</a>
lachlanmiller
Postby tommo77 » Sat 25 Jul, 2009 4:46 pm
Hey dude
This skimmer i think its just one of those red sea airlift 60's or something was just an aqua one 2500 pump i ran it off, usually its to do with how high or low you put the water level in the skimmer, the higher you have it the darker the stuff will be if it is lower you will be producing more of the wet lighter stuff.
This skimmer didnt really produce the dark muck you find in others but it was a steady dark brown liquid produced, i think it worked pretty well too be honest!
Will be getting those pics of the fish and QT soon matty
Tommo's 4x2x2
tommo77
Postby tommo77 » Sat 25 Jul, 2009 8:22 pm
comment deleted
Tommo's 4x2x2
tommo77
Postby camo1 » Sat 25 Jul, 2009 10:26 pm
You could put in another baffle on the left and use as a dsb, you could the use carbon in a FBF/cannister.
camo1
Postby tommo77 » Thu 13 Aug, 2009 8:46 pm
Havent updated for a while so here we go,
I got a couple of holes drilled and made my overflow/sump which consists of compartment 1 skimmer and where the water flows down, 2 is the liverock, heater and just a 5cm layer of sand with caulerpa could of put more sand but i ran out :nut: and the 3rd compartment is just the 4800L/hr return pump!
So here it is;
The FTS is not that great due to bad lighting conditions
Tommo's 4x2x2
tommo77
Postby tommo77 » Mon 17 Aug, 2009 7:12 pm
Little update
Fixed up my whole tank journal, re-sizing the older pics which should provide better reading and viewing.
Since my last update i have added a new little addition the long horned cowfish called Mad Dog
I have also added a bubble tip anemone which has swelled in size from a tennis ball to a football ha ha and is now hosting a pair of clarkis, surprisingly it found a big hole in a rock that i had carved for my nano and hasnt moved fingers crossed, touch wood!
Tommo's 4x2x2
tommo77
Postby morrismini1022 » Tue 08 Sep, 2009 9:58 pm
nice tank, very clean looking. hope your anemone stays put looks good.
morrismini1022
Postby tommo77 » Wed 09 Sep, 2009 11:25 pm
Hey mate cheers,
Got a few updates to put up soon its hard to take good pics with average cameras!
Tommo's 4x2x2
tommo77
Postby tommo77 » Fri 11 Sep, 2009 7:17 pm
Got a couple new pics which are better quality then the last ones, hope you enjoy and any feedback and or comments would be appreciated!
Mad Dog just starting to grow his horns :)
My BTA hosting the perculas
My favourite picture of Spike the Butterfly
Customary FTS best one i could get.
Tommo's 4x2x2
tommo77
Postby sydneydrewid » Fri 11 Sep, 2009 7:43 pm
those cowfish are awesome, they have such personalities :)
nice fts shot aswell, the anthias look to have plenty of room :thumbsup:
Postby Steve.Hill » Fri 11 Sep, 2009 7:54 pm
Hey Chris,
The last FTS is great. Nice and sharp.
I like the shot of spike. Nice colours.
Steve
Steve.Hill
Postby tommo77 » Fri 11 Sep, 2009 7:55 pm
Thanks!
Yeah i havent put too much liverock in there i dont like the look of having too much, wanted to create more space for my fish to swim :)!
I was re aquascaping the tank after a rockfall the other day and the cowfish was following my hand everywhere wasnt fazed at all lol!
Tommo's 4x2x2
tommo77
Postby tommo77 » Fri 11 Sep, 2009 8:00 pm
Cheers Steve!
Tommo's 4x2x2
tommo77
Postby morrismini1022 » Fri 11 Sep, 2009 9:12 pm
what happened to the clarki clown
Just a wiper snapper learning everything i can :D
My barrier reef
My 4x2x2
morrismini1022
Postby tommo77 » Fri 11 Sep, 2009 9:33 pm
Bit harsh but i took them back as they kept headbutting my cowfish at feeding time.
Tommo's 4x2x2
tommo77
Postby tommo77 » Sat 12 Sep, 2009 2:45 pm
Is my return pump too big?
Pondmaster 4800L/hr
Tommo's 4x2x2
tommo77
Postby Jesster » Tue 29 Sep, 2009 8:10 pm
looking good Chris!
looks like you overcame the skimmer and WS issues ok. Crypto is the devil :pirate:
not sure about the return pump but are the sump/DT water levels consistent? I know nothing about sumps...
has the cow fish bitten you yet? :devil:
Jesse
Jesster
Postby tommo77 » Tue 29 Sep, 2009 9:52 pm
Cheers for the comments Jesse,
All is going very well and my FTS has changed alot since that last one :)
Cowfish has bitten me quite a few times i actually scooped him into a large net the other day for 5 mins as he wouldn't let up when i had to re-arrange all my corals haha hasn't bitten me since, best fish though!
Tommo's 4x2x2
tommo77
Postby tommo77 » Thu 01 Oct, 2009 5:25 pm
Bit of an update;
Just ordered a new lighting unit from Guppys which has the 150W halides plus 4x54W actinics to bring out the colour of my corals more.
Picked up a yellow tail cleaner wrasse yesterday from Ocean Reefs.
Was thinking of grabbing a Vortech MP40W but i think i may wait until i have a bit more money lol or until someone can convince me :P
I have been offered a toxic green hammer coral which i will be picking up in the next couple of days stay tuned for some pics !
Also i got some duncans and a nice lobophyllia from Darren the fish doctor which are top notch so thankyou Darren!
Tommo's 4x2x2
tommo77
Postby Jesster » Thu 01 Oct, 2009 5:46 pm
PIC PICS :poke:
I have the 250w GAPO unit and it does the job.
that wouldnt happen to be a CDU toxic hammer would it? pics :poke:
Jesse
Jesster
Postby tommo77 » Thu 01 Oct, 2009 5:57 pm
Yeah did you change out the halide bulbs and get new ones, i am keen to get my hands on some 20K bulbs but i figure with the actinics it wont matter too much?
That would happen to be the CDU toxic green :devil: ;)
Tommo's 4x2x2
tommo77
Postby Jesster » Thu 01 Oct, 2009 9:38 pm
tommo77 wrote:Yeah did you change out the halide bulbs and get new ones, i am keen to get my hands on some 20K bulbs but i figure with the actinics it wont matter too much?
havent changed out the MH globes yet but have changed out the T5's.
up to personal preference i think in regards to lighting choice. The light that comes from the GAPO MH globes is pretty white/yellow so an upgrade to a good 14000k would be my choice.
I mainly use the T5's to supplement the MH, running the MH or 5 hours and the T5's for 10 hours. theres a mix of Aqua blue +, fiji blue and 2 GAPO actinics T5 globes. i need to change the last too out cos they've faded a heap in just a few months.
I wanna see this hammer :pirate:
Jesse
Jesster
Postby tommo77 » Thu 01 Oct, 2009 9:51 pm
Yeah true, i bought extra T5 globes for it and have my 15k AMD bulbs which are pretty good!
Just received the hammer tonight!
Will put pics up soon
Tommo's 4x2x2
tommo77
Postby tommo77 » Thu 01 Oct, 2009 10:30 pm
Toxic Hammer all closed up!
Photo just doesn't do it justice it is an amazing fluoro green cant wait to get my actinic lights!
Tubastrea
Tommo's 4x2x2
tommo77
Postby sydneydrewid » Thu 01 Oct, 2009 11:02 pm
looking very nice there!! cant wait to see the hammer open up :thumbsup:
Postby Jesster » Sat 03 Oct, 2009 1:36 pm
sweet! that looks awesome chris! hows it opened up now?
I think I miht need to upgrade some the 15000k AMD MH globes.
FTS :poke:
Jesse
Jesster
Postby sydneydrewid » Sat 03 Oct, 2009 1:38 pm
:withyou: FTS and i think the hammer should be well and truely opened by now :poke:
