Setup with everything supplied that it came with plus a bit of black sponge to trap any micro bubbles before they get into the tank, resun 280 chiller with reef octopus 1000l/hr pump running and 4500l/hr tunze nanno for added circulation bringing total to 5500l/hr which is over 45 times per hour. Chiller pump sucks from heater area and returns here as well so it doesn't add to turnover and did it this way as it is much neater.
Didn't use the substrate (yet) as I wanted the rock to vent out a lot of the detritus trapped in it for the first few months and this has payed off with consistently low levels with nitrates always under 5ppm.
20 litres water change weekly with salt mix - Aquasonic
Sponge cleaned weekly in water removed for water change.
detritus siphoned weekly from the two spots it collects and then tank blasted with a power head and filter wool used for 24hours to polish the water.
[/img]
