Turbo snails Vs Trochus snails
The forum for all general topics not covered by one of our specialised forums.
Moderators: Scooby, liman, Dr DBW, Moderators
Postby Thanh3k » Wed 10 Nov, 2004 6:35 pm
both look relatively similar, i was just wondering which one would be better to buy to clean up the algae in my sump/fuge. Or are both equally as good?
thnx
Thanh3k
Re: Turbo snails Vs Trochus snails
Postby ATJ » Wed 10 Nov, 2004 8:42 pm
Actually, Turbo spp. snails are quite different from Trochus spp. and most Trochus grow much larger than Turbo. Two of my Trochus are nearly 10 cm high!
Here is a Turbo sp.:
And here is a Trochus sp.:
If you can, it would be good to have a mix, but Turbo on their own will do a good job and if you get a few they will breed.
ATJ
MASS Member
Postby Thanh3k » Wed 10 Nov, 2004 9:21 pm
thnx ATJ as usual you are a wealth of information.... ok a mix it is
Thanh3k
Postby spoonhandler » Thu 11 Nov, 2004 1:06 pm
I've also found both do a good job, but on the down side, my Trochus is now so big, it causes a bit of havoc as it roams around - knocks things over, etc. Very fast growing. They're also a bit noisy - they make a scraping sound on the glass by rotating their shells back and forth, usually when they think they're under attack (other snails, hermit crabs, etc), but possibly also to loosen stubborn algae (not sure about this, but I've seen them do it when nothing is nearby to bother them).
spoonhandler
Postby mgpro » Thu 11 Nov, 2004 1:09 pm
i got some turbo snails from someone at a MASS meeting last year and now i have hundreds of snails. they breed very fast and must be finding enough to eat. at night if i turn a room light on the front glass is covered in them, though during the day you can only see several dozens.
mgpro
mgpro
Postby Garbo » Thu 11 Nov, 2004 1:26 pm
My snail always die on me. I have a crushed marble base and the smaller snails can't move across it so they flip upside down and die if i don't right them.
I think the bigger the better, they are more productive.
Garbo
Return to General Discussion
Users browsing this forum: Google [Bot], Milan04 and 0 guests
