Well i've sat looking at marines for years, and finally have the cash to do something about it. Decided that I'd like a bit of a challenge, however at the same time dont really have the space for a large tank. Hence the choice of a Pico.
System Objectives: To gain experience in maintaining a reef aquarium and inverts, and keep a pico tank stable before one day moving on to a larger system.
System Type: Hopefully SPS and Softies
Strike up Date: 7th January 2009
Display Tank: Interesting shaped corner tank with 5 sides, 23L empty
Display Lighting: 70W MH In DIY fitting with 10k Bulb currently.
Stand: No stand, top of a bookcase.
Hood: No true hood.
Sump: No Sump
Refugium: HoB converted Penguin 125 with heater including 1kg LR
Refugium Lighting: Intending on using LEDs when I add cheato or other macro.
System Water: NSW
Display Water circulation: Currently a Koralia Nano (900L/h) in addition to Penguin HOB refugium (500L/h): So current flow is approx 1400L/h so roughly 65-70x turnover.
Return Pump: Penguin 125.
Skimmer: Surface Skimming associated with the Penguin.
Cooling/Chilling: 15cm Fan on surface.
Evaporation Top Up:ATO timed daily system using SP3000 dosing pump
Calcium Addition: None as yet
Alkilinity Addition: None as yet
Other Chemical Maintenance: GAC run in the outflow section of the penguin.
Nitrates: <5 ppm
Phosphates: 0.02
Alkalinity: 9.5 dKH
Calcium: 430ppm
Salinity / Specific Gravity: 1.028
Magnesuim: Unknown
FTS
Hopefully this will be an interesting diary for anyone considering a pico
