Roz 5x2x2 tank
Roz 5x2x2 tank
Postby Roz » Sat 24 May, 2008 11:28 pm
Well here I am finally starting my journal ,the idea has been accumalating over several months Firstly removed a wall where the tank was to be ,then had to get all the gyprocking done . Next lay a concrete slab for the foundation as the floor was unlevel.While all this was going on the cabinet was being made.I finally got it all together ,which I might add at times I didn't think it was going to ever happen as one thing let to another, as I had to get the laundry plastered then tiled,paint before I could get the tank up and running so the paint didn't end up in the tank and also the fumes from the paint would have not been ideal for the tank then the time came to put the cabinet in place
<img src="http://i283.photobucket.com/albums/kk288/Roz3355/WALLFORTANK.jpg" width="600"></a>
What a mess I was in . I thought things could only get better
Next the cabinet finally got put onto the slab
<img src="http://i283.photobucket.com/albums/kk288/Roz3355/FRONTVIEWBARETANK-1.jpg" width="600"></a>
Images reduced to 600 width Scooby
Live, Let, Live
5x2x2 Tank Journal
Roz
Roz 5x2x2 tank
Postby Roz » Sun 25 May, 2008 12:55 am
A list of my equipment tank 5x2x2
cabinet 900 high
sump standard 3ft with 3 sections ,1 with dsb with macro algae
2 x300 watt heaters
eheim pump 1262 for my water to go into the tank
octopus 300l/h to pump water into my skimmer
octopus dnw 200 6540 skimmer
3 hydor koralias k copy 5000
Lights 2x250mh with 4 t5 and 2 moonlights
My live stock
25 kg live rock +40kg base rock
3 small star (hitchhikers)
1 pistol shrimp
4 snails (hitchhikers)
2 clown fish added well after cycling
2 mini crab which are in the sump( Hitchhikers)
my water parameters are ammonia 0, nitrite 0 salinity 1.024 ph 8.1 temp 26
This has taken approx 4 months to get to this point
Live, Let, Live
5x2x2 Tank Journal
Roz
Postby starfunker » Sun 25 May, 2008 1:14 am
Nice spot for it!
starfunker
Postby Paraboy01 » Sun 25 May, 2008 9:54 am
Sounds and looks like of to good start :clap: , more pics when you can I'll will be set up similar in next month or so, i also live in adelaide where did you get tank and stand
Paraboy01
Postby Ausie_Fish » Sun 25 May, 2008 10:28 am
The only thing I would change in that list of goodies is
The thing with the copies is the shaft does seem to rust quite quickly. Other than that looking good
Reeflections Aquarium,
Ph: (03)9532-2766,
http://www.reeflectionsaquarium.com
Ausie_Fish
Postby Adam007 » Sun 25 May, 2008 10:36 am
Ausie_Fish wrote:The only thing I would change in that list of goodies is
I wouldn't say that, the first bunch of them were having problems with shaft's rusting, however it seems recent ones purchased do not have this problem. Even if they do rust, there is a thread in the DIY forums on exactly how to change the shafts for very little cost.
Adam007
Postby Rusty1 » Sun 25 May, 2008 10:39 am
I think the only 1's that rusted were the 1's from Ethan which were the paralel imported 1's to the best of my knowledge.
I am under the impression the 1's from AOA and Guppies have no issues.
Least thats my understanding.
Tank Now For Sale
Reef In The Wall
Tank on Facebook- Closed
Reef In The Wall- FB
n0rk: For all I say, I still love halides. The "crispness" is still unrivalled in most situations. I am a schmuck who wants to go halides.
Rusty1
Postby evojb » Sun 25 May, 2008 10:44 am
all from the same place, they will all do the same. But cheap to fix.
evojb
Postby Spides » Sun 25 May, 2008 7:18 pm
Lookin good Roz :thumbsup:
Spiders 6' Inwall (TOTM March 09) DECEASED
"The greater danger for most of us lies not in setting our aim too high and falling short, but in setting our aim too low, and achieving it." Michelangelo
Spides
Postby dougie » Sun 25 May, 2008 7:56 pm
great start! :thumbsup:
Roz 5x2x2 tank
Postby Roz » Sun 25 May, 2008 11:43 pm
Here we go for the next update ,the sump which Scooby made for me and we hooked every thing to get me on my way.
Originally I used flexable coil hosing but found this wasn't any good for me as I couldn't get it to go on enough and ended up with leaks so I went to the irrigation shop and got some of their hosing and attached with marine stainless hose clamps at all connections which has proven to be sucessful no leaks.
<img src="http://i283.photobucket.com/albums/kk288/Roz3355/SUMP.jpg" width="600"></a>
Then filled with coral sand that came with the 2nd hand tank I bought.
I then added another 65kg of sand from Aggies to get the required depth of the dsb for both the main tank and the sand bed for the refugium.
<img src="http://i283.photobucket.com/albums/kk288/Roz3355/TANKWITHBASEROCK.jpg" width="600"></a>
Well next came filling with ocean water through Michael (tuskfish) and to start things going I put a tiny bit of food in each day as if there were a couple of fish in there, then finally the live rock arrived after forever it seemed so I rushed to the airport to pick up.
I brought it home and dipped each piece in ocean water to shake off anything that may have died and then placed into the tank.
I originally only wanted 2 sections of rock and the centre clear but couldn't fit it all in that way so have ended up with it the way it is now.
There is no areas that can not get flow through and also when I get more fish hopefully they will swim through the rocks.I guess only time will tell.
This next picture is one of my stars that came with the live rock.
<img src="http://i283.photobucket.com/albums/kk288/Roz3355/starfish3underneath.jpg" width="600"></a>
My next photo is of the sump completed.
Here is a couple of pictures of my tank with where it is at now, thank you for looking at my tank and I will update as time goes on and as I get more additions.
Image Image
Image Image
Regards Roz
PS: I would have never been able to get this going had it not been for this site and in turn getting in contact with very kind and helping people who are into this absolutely wonderful addictive hobby.
Live, Let, Live
5x2x2 Tank Journal
Roz
Postby Paraboy01 » Mon 26 May, 2008 8:57 pm
Looks tip top Roz :thumbsup:
Paraboy01
Roz 5x2x2 tank
Postby Roz » Tue 27 May, 2008 1:05 am
Thank you for your kind words :thumbsup:
Live, Let, Live
5x2x2 Tank Journal
Roz
Postby Tuskfish » Tue 27 May, 2008 9:54 am
Nice to see ur underway now Roz, Looking good :thumbsup:
Can u tell I was bent when I wrote this ?
6' Tank by Tuskfish (August 2008 TOTM)
Tuskfish
Re: Roz 5x2x2 tank
Postby Adam007 » Tue 27 May, 2008 10:15 am
Roz wrote:I went to the irrigation shop and got some of their hosing and attached with marine stainless hose clamps at all connections which has proven to be sucessful no leaks.
Hi Roz,
Keep a very close eye on those stainless hose clamps. Usually the clamps themselves are stainless however the screw in thread is not and this causes rust, which is really bad for your system. I just used zip-ties on everything as those plastic hose clamps are useless IMO.
Adam007
Postby amashun » Tue 27 May, 2008 10:29 am
:roflmao: aren't they all made by sun sun? :roflmao: have no idea why would you say so.
Roz, i though you were setting up a nano? don't know why i have a feeling that you may follow Tone's patch, 5x2x2 is a nano right? :roflmao:
Tank looks great mate, however, i would like to suggest put the skimmer return in the feed pump section, so it can reduce the micro-bubble in the refrig. also add more sand in the middle chamber for the DSB (although you may have a lot sand in the display) so the macro algae can receive more light too..
Just out of curious, have you test how many water goes into your sump when you turn the pump off?
amashun
Roz 5x2x2 tank
Postby Roz » Wed 28 May, 2008 12:13 am
Thank you Adam I will definitely be keeping my eye on the clamps and I will replace with cable ties thank you for the advise
Live, Let, Live
5x2x2 Tank Journal
Roz
Postby triplesided » Tue 10 Jun, 2008 12:38 pm
got an updated pic for us? :poke:
[url=http://www.masa.asn.au/phpBB3/viewtopic.php?t=189999]The old 8x2x1.5[/url]
[url=http://www.masa.asn.au/phpBB3/viewtopic.php?t=194360]The new and improved 2' cube[/url]
triplesided
Postby hellaflush » Thu 23 Apr, 2009 3:50 pm
*cough* update *cough*
ive noticed your forum activities would suggest your setup has vastly changed since last year... time for an update Roz!
p.s. how are those violet coralimorphs going? care to frag?
Adz
R.I.P Pacman
hellaflush
Postby Namn8r » Fri 24 Apr, 2009 3:03 pm
Hey Roz,
Have you switched to ASW yet? How are your corals doing now?
Nam
Namn8r
Re: Roz 5x2x2 tank
Postby Roz » Sat 08 May, 2010 9:24 pm
Well definitely long overdue for an update never enough hours in a day to get all done .I have added a chiller which has proven to be a very valuable asset. I now have 4 tunzes on a multi control unit and also got rid of the guppy all in one and up graded to 3x250 halide and 4x2ft t5 units.I also replaced my reef octopus skimmer with a Turbo made and to say the least very impressed and so much easier to do maintenance on It is external and is hooked up to a laguna pump .Well enough of the chit chat I will add some piccies .My zoo garden is going great guns I must say I have a weakness for a nice zoo I hope the picture uploaded okay???
Live, Let, Live
5x2x2 Tank Journal
Roz
Re: Roz 5x2x2 tank
Postby Tuskfish » Sun 09 May, 2010 1:10 pm
Good to see everything has settled down now.
The chiller was a wise investment.
Tank is looking good and that powder blue looks like it has put some beef on.
Tuskfish
Users browsing this forum: MSN [Bot] and 1 guest
