Mick's Aquaone Minireef 160
Postby mick777 » Tue 02 Apr, 2019 12:36 pm
Hi been out of the hobby for a few years, but my wife secretly purchased me a new tank as she knows I missed it,
The Tank is an Aqua one Minireef 160 its main tank is 90cmx45cmx45cm, sump is 60cmx38cmx40cm and rodi storage is 16cmx38x40cm
So far all I have done is fill with ro/di water added sand and salt, tweaked the over flow pipe like in this video https://www.youtube.com/watch?v=XNT5QSEMzB0 to cancel out some noise, added in a Aquael Reef Circulator 2500 power head and aquaone auto top system
I have ordered 18kg of Caribsea life rock shapes, going to try Bacteria House Bio Block in the sump and 90CM DSunY Marine LED with wifi for main light
mick777
Re: Mick's Aquaone Minireef 160
Postby mick777 » Wed 03 Apr, 2019 10:58 am
I got Mail the Bacteria House Bio Block (20cmx20x10), I am interested to see how it goes
Just waiting on my eggcrate to put it on in the sump
mick777
Postby mick777 » Thu 04 Apr, 2019 11:20 am
The Caribsea Life Rock Shapes came today
Now need to figure out the layout I want
Box One 9kg
Box Two 9kg
mick777
Postby mick777 » Thu 04 Apr, 2019 6:46 pm
Rock in, not sure if I like the layout or not but will see after a week
mick777
Postby mick777 » Sat 06 Apr, 2019 4:59 pm
Purchased another Aquael Reef Circulator 2500 power head for left side of tank.
also 3D printed and new return nozzle to replace the straight though pipe that came with the tank and 4 loc-line connections in abs
this one splits the water flow in to 4 different directions as it comes out, works great and seems to have increased return pressure
(https://www.thingiverse.com/thing:1784377)
mick777
Postby mick777 » Tue 09 Apr, 2019 2:53 pm
I received the light today
mick777
Postby mick777 » Sat 13 Apr, 2019 1:53 pm
Parameter update:
Salinity: 1.025
PH: 8.1
KH: 120ppm
Nitrite 0ppm
Ammonia: 0ppm
Nitrate: 10ppm
I have been left a dead King prawn in the water to make that ammonia read on the test, but I still haven't seen any ammonia, or nitrite, but nitrate is going up and diatoms are showing on some of the small live rock bits i got from the lfs and a small amount on the sand
I have a feeling that might have to do with the Caribsea life rock's Bacteria
mick777
Postby mick777 » Thu 18 Apr, 2019 9:13 pm
While waiting for the tank to cycle, I decided to use some mdf I had laying around so mounted the power broads to it so I can slide them out from behind the tank all in one go
I am sure someone will point out its not good to have power boards running from another power board, but the main one is the only one that is surge protected and there is only one power point on the wall where the tank is
also noticed the new light and power pack were getting quite hot so I mounted a fan on the power pack and used an old CPU cooler to cool the light
the fan on the light runs at full speed on a timer with the lights, as for noise I can not hear it over the protein skimmer noise and the air it gives off I can feel coming out of each end of the lights heat sink
Also ordered an extension cable for the lights control box so I can mount it to the mdf.
mick777
Postby Grubby » Tue 23 Apr, 2019 11:17 pm
Sweet set up. I am in the process of getting my MiniReef 150 up and running. Just ironing out the bugs, leak testing, making mods and getting ready for the next phase, adding Sea water.
Are you going to flick the Moray pump ? I hate the damm things, noisy, uneconomical, etc. I am going to gumtree mine its mint in the box unused, as I have ordered an Aqua Medic DC Runner 3.2 which is due tomorrow.
I wish my 150 had the sump space of the160, the 150 sump is cramped . But seeing as I pick my 150 up brand new at a General Auction for $150, I'm not complaining.
Grubby
Postby mick777 » Wed 24 Apr, 2019 1:31 pm
Grubby wrote:Sweet set up. I am in the process of getting my MiniReef 150 up and running. Just ironing out the bugs, leak testing, making mods and getting ready for the next phase, adding Sea water.
I am lucky my moray is very quite (my skimmer pump is louder), I will probably still change it out, but just using it for now
Since the sump does have a space for refugium, I fudged one
mick777
Postby Grubby » Thu 25 Apr, 2019 1:01 am
Nice, so let me make sense of all of this. You have the bakki plate below the refugum which sits on egg crate. Looks like you have added more glass baffles to your sump and increased the water level. Correct ?
Grubby
Postby mick777 » Thu 25 Apr, 2019 10:32 am
Grubby wrote:Nice, so let me make sense of all of this. You have the bakki plate below the refugum which sits on egg crate. Looks like you have added more glass baffles to your sump and increased the water level. Correct ?
Just added a divider made from report cover spines from office works and Plastic Mesh 7 Count Canvas Sheet from spotlight and a 3D printed black comb to keep the macro algae in one area of the sump, because were the protein skimmer sits it’s just one large open area
mick777
Postby Grubby » Thu 25 Apr, 2019 9:26 pm
I think I am gonna have to get me a 3D printer.What sort of 3D printer would you recommend ?
Yes its amazing what you can utilise from chain stores in the Aquarium. Office Works, Spotlight, Bunnings, Ikea and Daiso have all yielded things for my hobby.
Also I see you sump is the after Market Aqua One glass sump Multi divider, now I understand. All good.
Grubby
Postby jok3r801 » Fri 26 Apr, 2019 11:30 am
Awesome setup you have going there mick.
How are you finding the Bacteria House Bio Block?
I purchased 2 of these for my tank i am setting up. Would be good to get feed back from others.
jok3r801
Hi, I am new around here!
Postby mick777 » Fri 26 Apr, 2019 1:07 pm
Grubby wrote:I think I am gonna have to get me a 3D printer.What sort of 3D printer would you recommend ?
I have two Anycubic 3d printers and are happy with both, Ones a linear delta Plus and the other is i3 mega, both purchased from the Anycubic official ebay store form Australian stock for great prices
jok3r801 wrote:Awesome setup you have going there mick.
Yeah seems to be good at the moment, it does float for a bit when you first put in, but it did sink to bottom of sump after 24h or so
mick777
Postby mick777 » Fri 26 Apr, 2019 1:09 pm
My DIY Light Shade/Reflector using some 3d printing, Aluminium Foil Tape, plastic panel from the bottom of 2 reusable bags and 2 report spine holders
mick777
Postby Grubby » Sat 27 Apr, 2019 10:38 pm
What is the light ?
Grubby
Postby mick777 » Sun 28 Apr, 2019 9:24 am
Aqua one Extendable Mini Touch LED, it has red blue and white leds. probably not the best light but I already had it and it fits great, :)
mick777
Postby mick777 » Sat 11 May, 2019 5:56 pm
Was meant to post this about a week ago.
added 4 turbo snails to help with algae
and a few corals
attached this purple star to a removable rock, just in case I need to keep its size down
and this i got for free as they said it had not opened, so I thought lets see if i can make it happy
mick777
Postby mick777 » Sat 11 May, 2019 6:01 pm
after a week of being in the tank it looks better
Also Got a Baby Bubble tip anemone (about 2cm in size)
also some clown fish and another coral
mick777
Postby Combatants » Wed 29 May, 2019 9:57 am
Looking great :)
My wife has been dropping hints that she wants another tank after been out of the hobby for a few years.
Combatants
Images: 15
Postby mick777 » Mon 03 Jun, 2019 1:06 pm
Combatants wrote:Looking great :)
I also got a photo of my other clown
Yellow tailed damsel who has been hiding in the caves
I purchased some fish today
Bicolor Angel
Cleaner Wrasse
Twin Spot Goby
and also 2 Nassarius snails
mick777
Postby mick777 » Mon 03 Jun, 2019 3:19 pm
I have moved my tank journal to here https://www.nano-reef.com/forums/topic/ ... ireef-160/
I have been trying to keep both going, but I have deiced to just continue that one
mick777
Users browsing this forum: No registered users and 9 guests
