Nathan's Starfire Stick box 6ft TOTY 2014
Postby ssscuz » Sun 04 Aug, 2013 11:11 pm
Nathans Bigger Reef :clap:
After getting the offer of a lifetime from Brett (gwithian). I will be starting up a new tank, the old tank will be torn down and this one will replace. I have had ups and downs with the last tank. I am hoping this time around it will be easier and that I can put the knowledge that I have learnt over the last year and a half.
System Objectives: I said mixed reef last time and turned into a fairly SPS driven setup, this time I hope I can keep sps with some fish that I just couldn’t have in the 4fter. :nut:
System Type: SPS dominated, Mixed Reef
Strike up Date: 15th September 2013
Display Tank: 6ft x 2.5ft x 20” full starfire viewing and rear overflow.
Display Lighting: Ati powermodule 10 x 80w
Stand: Steel
Hood: Steel frame with melamine doors
Sump: 1200 x 800, three partitions with in built frag tank
Refugium: section in sump
Refugium Lighting: DIY Led/t5 hybrid
System Water: ASW red sea blue bucket
Display Water circulation: 2 vortech mp40w back wall and maxspect gyre xf130. Mp10 will be used in the frag section
Return Pump: Royal exclusive speedy 75w
Skimmer: vertex 250
Evaporation Top Up: avast marine peristaltic pump, controlled by apex, pumped from the garage
Other Goodies
Geo 818 carx with marine sources add on chamber
Diy led/4x24w t5 for frag tank
De bary 25w uv sterilizer
Calcium, alkalinity and magnesium Addition: calcium reactor, coral bones
Other Chemical Maintenance: vodka/vinegar for carbon dosing, lanth for phosphate
Nitrates: 0.00ppm
Phosphates: 0.03ppm
Alkalinity: 8.0dkh
Calcium: 400ppm
Salinity / Specific Gravity: 1.026
Magnesuim: 1240 ppm
Fts
20/8/16
14/5/16
1/7/15
12/04/15
17/2/15
28/9/14
4/8/14
1/6/14
1/5/14
26/4/14
1/4/14
3/3/14
26/12/13
7/12/13
16/11/13
Heres the baby, previously Brett's(gwithian) and pre that Scotto's
Sump plans
Stand that should be built this weekend
sump 1
ssscuz
Re: Nathan's Starfire Stick box 6ft x 2.5ft x 20
Postby culturedreef » Mon 05 Aug, 2013 2:36 am
Yeah for you, I think this will really cement you into the reefing world.
I have a couple of spare eheim 5000 return pumps that you can have, the bubble king can handle the extra load. :thumbsup:
Give me a call when I get back on the 20th aug. :thumbsup:
culturedreef
Postby Bandit » Mon 05 Aug, 2013 4:33 am
:clap:
Hope you don't beat me to getting it wet...lol
Bandit
Images: 44
Postby ssscuz » Mon 05 Aug, 2013 7:42 am
Thanks John, yeah I'll speak to u once your back
And Jamie u better believe I will beat u to it ha ha
ssscuz
Postby damer » Mon 05 Aug, 2013 9:29 am
ssscuz wrote:Thanks John, yeah I'll speak to u once your back
Im pretty sure you have me covered!! :konk:
Stand done that quickly? Who is making your stand?
"Don't ever give up!! Today might be your day for a miracle...."
Damien's 1300 x 1200 x 600
damer
Postby ssscuz » Mon 05 Aug, 2013 10:40 am
I'll be welding it up on the weekend.
That's the benefit of your father in law owning an engineering company.
ssscuz
Postby Bandit » Mon 05 Aug, 2013 11:26 am
I might still beat ya
Bandit
Images: 44
Postby ssscuz » Mon 05 Aug, 2013 12:21 pm
Bandit wrote:I might still beat ya
I doubt it, this thing could have water in it before u get back from vegas
ssscuz
Postby damer » Mon 05 Aug, 2013 3:02 pm
:o :o
Patience grasshopper ;) ;)
damer
Postby Bandit » Tue 06 Aug, 2013 3:55 am
Damn, moving real fast
Bandit
Images: 44
Postby ssscuz » Tue 06 Aug, 2013 8:23 am
There's no patience damer, it's a race to beat Jamie and u ha ha
ssscuz
Postby happy1 » Tue 06 Aug, 2013 9:20 am
cant wait to see this wet again it better stay at this address longer this is its 3rd home :crossfingers: :crossfingers: 3 x lucky
happy1
Postby damer » Tue 06 Aug, 2013 9:36 am
Bandit wrote:Damn, moving real fast
Yep ,quicker than you or I can move let alone get a tank going. :roflmao:
damer
Postby ssscuz » Tue 06 Aug, 2013 10:44 am
What size ATO reservoir do you think it will need? I currently have a 1ft cube for ATO on the 4ft
Thought maybe I'll need about 50 litres a week? So maybe I'll need a 2ft x 1ft x 2ft
The 4ft x 1ft behinds not really going to work. So think I'll use a 3ft I've got there for a frag tank behind and a 2ft for ato
ssscuz
Postby Bandit » Tue 06 Aug, 2013 10:53 am
I've got a 3x18 looking for a new home
Bandit
Images: 44
Postby damer » Tue 06 Aug, 2013 1:00 pm
Bandit wrote:I've got a 3x18 looking for a new home
And I've got a few of them if you need more :thumbsup:
damer
Postby ssscuz » Tue 06 Aug, 2013 1:20 pm
Thanks for the offer, think ill need a 2fter, won't be enough room for another 3ft under there.
ssscuz
Postby ssscuz » Tue 06 Aug, 2013 10:10 pm
well after looking at it and designing the stand a bit more, trying to fit two 4fters next to eachother was going to be harder than i though.
I think im not set on this design, where the 3 foot behind will be the frag tank, there will be a tee off the return to the frag tank and then ill put two bulkheads into the tank to drain over into the main sump. I had a little two foot lying around so ill use that for RO top up until i get something bigger. should hold 50 litres which im hoping will last a week.
Changed the design of the stand a bit to encorporate the size of the sump change etc. Still not sure what to use for under the tank between tank and stand and also under the sump. Marine ply was rediculously priced and then i would have to paint it. my current tank has paint under the sump and im less that impressed with how that has worn. I thought maybe melamine sheet, what are peoples thoughts? :cheers:
think this is where ill put the wp40. its a good place in the sense that it hides the cord and i can run it thru the overflow so it runs down rather than around the euro braces.
heres the tank lifter that masov now own 4 of. These things made it so much easier to move the tank.
ssscuz
Postby happy1 » Wed 07 Aug, 2013 8:38 am
good to see these in use & that they made lifting go smooth for you
don t forget i have that water trailer you can borrow any time :thumbsup: :banana: :banana:
happy1
Postby damer » Wed 07 Aug, 2013 9:04 am
Don't go melamine unless you can seal the edges. marine ply shouldn't be all that much, but its been a long time since I bought any.
Good thing we got four of those!! I can't wait to use them :konk:
damer
Postby ssscuz » Wed 07 Aug, 2013 9:43 am
damer wrote:Don't go melamine unless you can seal the edges. marine ply shouldn't be all that much, but its been a long time since I bought any.
See this is why I put my dumb ideas up!
My mate that's a cabinet maker said he can get HMR (high moisture resistant ) melamine. He has an edger at work but won't be able to seal the round holes so I'd have to paint them.
Think this will work?
Marine ply was $80 a sheet and had to be painted.
Chris I'll def be hitting u up for the trailer, thanks mate
ssscuz
Postby happy1 » Wed 07 Aug, 2013 12:23 pm
this is what i have above the 10 ft tank sealed with paint it was light & the builder suggested it .
where i have it it is easy to replace should i have too . 8 months & no problems so far :crossfingers: :thumbsup:
happy1
Postby damer » Wed 07 Aug, 2013 12:25 pm
What about formply Nathan?
damer
Postby damer » Wed 07 Aug, 2013 12:28 pm
Just went to search for a topic I remember seeing, but you have already found it :thumbsup:
damer
Postby ssscuz » Wed 07 Aug, 2013 1:27 pm
Yeah thanks mate.
That formply stuff looks good. Think ill be heading that way and just painting the cut edges.
ssscuz
Postby ssscuz » Wed 07 Aug, 2013 6:50 pm
been flat out at work.... so have had some time to think a few things thru.
Would there be any point in me hooking up my current chiller to the new tank? its a hailea hc250a so 1/4 hp.... for the new tank i would need maybe 3/4 hp.
I need to work it out before the tank goes in as i want to hard plumb it to outside if i do.
Last summer the chiller seemed to come on a fair bit on the other tank but the chiller was inside. i think this worked against me and i was trying to use the air con to cool it down even more. surely more water volume will take longer to heat up so i may be able to get away with just fans and the air con?
ssscuz
Postby coral1 » Wed 07 Aug, 2013 8:12 pm
this is soo exciting Nathan gonna be following your progress :thumbsup:
Renae
MASOV 2015-2016 president
Image[/image]
viewtopic.php?f=145&t=241394
viewtopic.php?f=145&t=162492
coral1
Postby Thommo01 » Wed 07 Aug, 2013 9:22 pm
Looks like this is going to be a good setup. Also interested in how your sump all plans out.
Tagging along
Postby ssscuz » Sat 10 Aug, 2013 9:56 pm
Today was build the stand day. Lucky my father in law is in structural engineering.
Made it cake walk with the help of these two, mate Simon and father in law Vlasta
Here's the steel cut and ready 50 x 50 gal (3mm) used a total of 32 meters for the stand
Setting up the jig
Frame without the detachable hood fitted, made it with 40mm legs on it so that it can be moved to different heights or be fully removed if needed.
Here's it all tacked up, great shot of me in the dirty work gear. Just need to head back tomorrow and finish off the welding and grinding. Not to bad for 5 hrs work.
ssscuz
Postby chromus » Sat 10 Aug, 2013 10:21 pm
Looks great Nathan, will the Lights be light enough not to flex the overhead rig?
Did you search RTAW Reefpedia B4 asking your question?
8x3x2.5 With Webcam
Tank Monitor (Work in Progress)
My reefs power consumption is offset with solar power
chromus
I Was Around When Noah Was a Reefer
Images: 27
Users browsing this forum: No registered users and 5 guests
