Other Frag Entry Template
All entries for the Other category of the competition. No discussions allowed.
Moderators: Moderators, Promotions, Competitions & Sponsorship
Postby nUm » Wed 13 Apr, 2011 10:56 am
Hello all,
Please copy this code into your first post when adding an entry.
This will ensure all entries are identical in standard.
If YOU DO NOT copy this template and decide to make your own it will be deleted within 7 days if is not compliant.
To copy the below code press select all. You can then press CTRL + C or right click on the highlighted text and select copy.
Then create a new entry, press CTRL + V or right click and select paste
Code: Select all
[u]FRAG INFORMATION[/u]
[b]Description of Frag:[/b]
[b]Date of fragging:[/b]
[b]Frag Origin:[/b]
[u]TANK INFORMATION [/u]
[b]Dimensions of tank:[/b]
[b]System Volume:[/b]
[b]Lighting:[/b]
[b]Circulation:[/b]
[b]Filtration:[/b]
[b]Maintenance:[/b]
[b]Additives:[/b]
[b]Water Parameters[/b]
[b]Photo Evidence:[/b]
nUm
Return to Other
