Brett's first tank
Brett's first tank
Postby Aphilla » Tue 12 Apr, 2016 8:33 pm
I was given a 3 foot tank by a friend that was moving, and I decided that a marine tank would be for me because of the extra colours I'd be able to get. It's a nice, simple tank for the moment, but I hope to upgrade equipment as I go.
System Objectives: To learn about reefing in a methodical manner, starting basic and moving to more advanced methods and equipment, so I can be in the best possible position to have a large aquarium in 4 years time
System Type: Fish only, will become mixed
Strike up Date: 10/2/2016, first fish added 6/4/2016
Display Tank: AquaOne 3'
Display Lighting: AquaOne single T5
Stand: AquaOne 3' Stand
Hood: Nil
Sump: Nil
Refugium: Nil
Refugium Lighting: Nil
System Water: Artificial Salt Water
Display Water circulation: 1200L/PH canister filter, 2x 5000L/PH powerheads
Return Pump: Nil
Skimmer: Nil
Evaporation Top Up: Manual Top Up
Calcium Addition: Nil
Alkilinity Addition: Nil
Other Chemical Maintenance: Nil
Nitrates: 40mg/L
Phosphates: Unknown
Alkalinity: Unknown
Calcium: Unknown
Salinity / Specific Gravity: 1.021
Magnesuim: Unknown
14/04/2016
Aphilla
Re: Brett's first tank
Postby colg » Tue 12 Apr, 2016 9:07 pm
Hi Brett,
I can't see your images, not sure what's going on?
Have you got them hosted on a site like photobucket or are they on here?
Post a link and I'll see if I can help sort it.
Col
colg
Images: 90
Postby Abarnes » Tue 12 Apr, 2016 9:18 pm
Hey Aphilla,
cant wait to see what happens here, just a note though, the forums don't seem to like imgur, while its an easy upload Photobucket or similar hosting sites are better to not only keep track of photos but also upload to blogs and forums :thumbsup:
Abarnes
*edit* double post .... silly website :cheers:
Abarnes
Postby Aphilla » Tue 12 Apr, 2016 9:54 pm
OK, so I moved my pics to photobucket and now they seem to be working :) I just probably need to compress them in future though
Aphilla
Postby colg » Tue 12 Apr, 2016 10:08 pm
Cool!
Tank looks very clean, how long have you had it set up.
Was there a long cycle?
colg
Images: 90
Postby mrkris » Tue 12 Apr, 2016 10:31 pm
thats a nice size to start with! looking forward to seeing how you progress
mrkris
Postby Aphilla » Wed 13 Apr, 2016 8:51 am
colg wrote:Cool!
I've had it up about 7 weeks, I don't think the cycle has finished yet, however ammonia, nitrate and nitrite have spiked and all were dropping at last test Sunday, with the fish in the tank. I was getting a little impatient, but they have been in the tank a week today, and seem to be doing well. I fed them with frozen once and then they seemed to go off pellets, I'm trying to bring them back. But they may also have had quite enough with the frozen to see them through for a while, as the three of them were sharing one of the pre-made blocks....
I think I'll add a couple of gobies and a peppermint shrimp next, but that will be a couple of weeks off yet. I am wanting to add a couple of corals, but I need/want to do more research on them first.
Brett.
Aphilla
Postby melfish » Wed 13 Apr, 2016 4:29 pm
Nice start. Be careful with overfeeding in a new tank- a block of frozen food is a lot for three little fish and can raise your nutrients quickly, especially before the good bacteria is stable. Looks like you've been testing for that anyway though. Looking forward to seeing how it progresses, soft corals are a good hardy start and don't need a whole lot of light :thumbsup:
melfish
Postby mrkris » Thu 14 Apr, 2016 9:52 am
what are you running in your canister filter? be a bit careful if you are running normal fresh water sponges/wool as they will catch and hang onto poop and food which will cause your nutrient levels to go through the roof if you aren't cleaning it out very frequently.
if anything i would rip everything out of the canister and look at putting a big block of marine pure. wait a few months for that to build up bacteria while your tank goes through its ugly stages and then look at slowly adding some more things
nothing good in marine happens quickly :)
mrkris
Postby Abarnes » Thu 14 Apr, 2016 11:19 am
The sponges and filter floss / wool will act the same way a filter sock in a sump does and will polish your water and catch any detritus etc. really well, however like filter socks it will be best to change / clean them every 3 days or so. Forcing water through the unclean sock / sponge etc. will have the opposite effect to removing unwanted waste etc, and increase nitrates etc. (as mentioned above :thumbsup: )
Abarnes
Postby Aphilla » Thu 14 Apr, 2016 12:54 pm
Thanks for the feedback guys, I had forgotten about maintaining the canister filter, it has floss, ceramic and activated carbon, so I'll have to have a look at the floss and atleast rinse it until pay day. I have heard that activated carbon only really works for the first few days and then the openings to its pores can become blocked, so something else for me to try to remember :thumbsup:
Aphilla
Postby Abarnes » Thu 14 Apr, 2016 2:19 pm
Carbon should last a long time, just check what carbon you are using, some products may only be suitable for Freshwater. I'd look at purchasing some carbon from a Marine Aquarium, or similar supplier online. Look at K&J Aquatics, they have some fantastic carbon available (and they are here in Vic), or check any of the other online reefing store.
The ceramic is fine, however if you do head down the path, Marine Pure is an amazing product for both Reef and Freshwater tanks. I'm using it in the sump of my Reef, and I also have 6 2" cubes in my eheim canister on my Freshwater tank, I've found it much better than ceramic, and if you have enough (or the right sized blocks) it can help with de-nitrification also.
Abarnes
Postby Aphilla » Thu 14 Apr, 2016 8:28 pm
I have definitely heard alot about Marine Pure and researched it quite abit, and I will be incorporating it in some way. But all as funds will allow, there is a wealth of knowledge out there and I'm wading through it :)
Aphilla
Postby Aydee » Sun 17 Apr, 2016 1:31 pm
Nice start to the tank mate. It's all a bit of a learning curve, but it sounds like you're on track.
Dave
Aydee
MASAOG Committee
Postby Aphilla » Sat 23 Apr, 2016 12:12 am
I'm starting to get a bit of algae growing, and I still have 3 fish, very happy about that!
Aphilla
Postby mrkris » Sat 23 Apr, 2016 12:14 am
looking good! how are your parameters looking?
mrkris
Postby coral1 » Sun 01 May, 2016 8:19 pm
:wavey: :wavey: hey nice to meet you both at todays meet :thumbsup:
tank looks like its off to a great start
Renae
MASOV 2015-2016 president
Image[/image]
viewtopic.php?f=145&t=241394
viewtopic.php?f=145&t=162492
coral1
Users browsing this forum: Google [Bot] and 2 guests
