Jordan's Tank III 28/6/2015 *update*
Postby jordan » Fri 26 Sep, 2014 5:56 pm
This will be my third Marine tank adventure. Old tank was given away before moving house. Planning to give Zeovit system a go this time.
System Objectives: SPS dominated tank?
System Type: Mainly SPS
Strike up Date: 17/10/2014
Display Tank: 5 x 2 x 2
Display Lighting: 1 x Maxpect Razor 300W 16K
Stand: Custom made stand - came with the tank (daves88 former tank)
Hood: Hoodless
Sump: 110L
Refugium: NA
Refugium Lighting: NA
Display Water circulation: 2 x Vortec Mp40 WES in reef crest mode. Tunze 6105
Return Pump: Eheim 3065
Skimmer: ATB medium
Evaporation Top Up: Tunze Osmolator
Calcium Addition: Randy 2 part dosing (Kamoer dosing unit)
Alkilinity Addition: Randy 2 part dosing (Kamoer dosing unit)
Nitrates: Undetectable (Salifert)
Phosphates: 0.00
Alkalinity: 7.2 dKH
Calcium: 380
Salinity / Specific Gravity: NA
Magnesuim: NA
Current tank Spec:Current 5x2x2 tank here
Old Tank Spec: Old 4ft tank here
Tank Spec (shut down): 4x3x2 New tank here
jordan
Re: Jordan's Tank III
Postby RedLineR » Fri 26 Sep, 2014 7:17 pm
Wow stunner mate!! Hit me up when you want frags!!
RedLineR
Postby Sailfin » Fri 26 Sep, 2014 7:34 pm
Woo Hoo Justin
Yell out if you need anything mate
Smile & have a Nice Day
Sailfin
Postby jordan » Fri 26 Sep, 2014 9:50 pm
Cheers fellas! Will be calling in favours when ready!
jordan
Postby oscar85 » Sat 27 Sep, 2014 12:56 am
yum!
oscar85
Postby daves88 » Sat 27 Sep, 2014 10:36 am
Looking good Justin :-)
daves88
Postby siddr20 » Wed 15 Oct, 2014 6:27 pm
I knew you would be back!!! Congrats on the new tank.
Ah your only in Concord now :) Sweet.. Im always around that area for work.
siddr20
Postby RedLineR » Sun 19 Oct, 2014 1:53 pm
How did the aquascaping with the glue?
RedLineR
Postby jordan » Tue 21 Oct, 2014 3:01 pm
Haven't do it yet mate. Been procrastinating. Hoping to do the plumbing this weekend.
jordan
Postby bubbleboy » Wed 22 Oct, 2014 2:33 pm
jordan wrote:Haven't do it yet mate. Been procrastinating. Hoping to do the plumbing this weekend.
Whats going on mate..... You had a short brake from reefing and now you fogort how to plumb a tank ? :poke: :roflmao:
let me know if you need a hand mate :thumbsup:
bubbleboy
Images: 21
Postby daves88 » Wed 22 Oct, 2014 3:08 pm
Also waiting to see this wet again!!
daves88
Postby jordan » Wed 22 Oct, 2014 3:24 pm
I never did any plumbing before! My brother in law did all of it. At least this time I have bought all the fittings. Still trying to figure out where to connect the RO filter as the laundry uses rainwater as well as the outside tap fittings.
Appreciate the offer Dave...will need your assistance stocking it when it's ready to go.
jordan
Postby bubbleboy » Wed 22 Oct, 2014 3:50 pm
jordan wrote: Still trying to figure out where to connect the RO filter as the laundry uses rainwater as well as the outside tap fittings..
Hmmm thats a problem. no tap water oulet close by ?
jordan wrote:Appreciate the offer Dave...will need your assistance stocking it when it's ready to go
You know where to find me when your ready to stock up mate ! :thumbsup:
bubbleboy
Images: 21
Postby jordan » Wed 22 Oct, 2014 4:40 pm
Only rainwater tap. The only place that has a fitting I can screw on and have it off mains supply is in the outdoor dunny which isn't very big so it's going to look a bit ugly and in the way for when someone wants to use the bathroom.
jordan
Postby jordan » Sat 25 Oct, 2014 1:00 pm
Here's the 'draft' plumbing in place. Any comments / suggestions before I cement it all together?
jordan
Postby jordan » Sat 15 Nov, 2014 9:35 pm
1st draft of aquascaping done with the help of my oldest daughter. All pieces fit quite securely without glue.
Right hand side view
Left hand side view
jordan
Postby daves88 » Sat 15 Nov, 2014 9:51 pm
Looking good!
daves88
Postby jordan » Sun 16 Nov, 2014 8:43 pm
There was some moisture in the tank today
After a good 30 minutes fill time.....
jordan
Postby muz_z » Sun 16 Nov, 2014 8:52 pm
Look great Jordan :thumbsup:
And even better now it's wet!
- All Controlled by Profilux-
New tank being started stay tuned! Cade HL600 BP!
muz_z
Postby jordan » Sun 16 Nov, 2014 10:22 pm
Thanks for the positive comment guys!
This is the water filling / water change rig I'll be using for water changes. The other end is connected to my old Laguna 9000 return pump inside an IBC located in a detached garage.
To control the pump from so far away from the garage I tried a remote control powerboard so I could cut the power when the tank was filled. Got this one because the range is 50m ($42 Bunnings)
Works great!
Just in case the remote failed I had the tap on the waterchange device to manually shut off the water if needed.
Got this one because the range is 50m $42
So starts the cycling phase.
Waiting on delivery of a new RODI filter from PSI filters then need too setup topup tank and soaking of the Zeolite stones.
I forgot how damn noisy the Vortecs are.
jordan
Postby Mr Miagi » Mon 17 Nov, 2014 12:04 am
I like the open room, heaps of swimming space! Tagging along! :thumbsup:
Postby ryanrid » Mon 17 Nov, 2014 1:52 pm
good start Justine. :clap:
Postby jordan » Mon 17 Nov, 2014 2:42 pm
ryanrid wrote:good start Justine. :clap:
Thanks mate. Was all going to plan until I realised that my plumbing for the weir was incorrectly set. The intentional main drain (durso) and gate valve is higher than the backup which means at the moment the roles for the drains are reversed :wall:
At the moment it's all flowing nicely and quiet so I'll just leave it for now.
jordan
Postby Rod the Reefer » Mon 17 Nov, 2014 2:43 pm
Woo Hoo, here we go again! :clap:
Postby Sailfin » Mon 17 Nov, 2014 3:02 pm
Lookin Good jus
Sailfin
Postby jordan » Wed 19 Nov, 2014 2:54 pm
Got this in the post today
Image Looks familiar Dave88??
and
Hopefully will turn on the zeo reactor later today and begin day one of cycling /dosing the tank
jordan
Postby daves88 » Wed 19 Nov, 2014 3:28 pm
Looking awesome Justin :)
daves88
Postby Mr Miagi » Wed 19 Nov, 2014 4:06 pm
Awesome, loving the WC rig! :thumbsup:
Postby jordan » Wed 19 Nov, 2014 4:21 pm
Mr Miagi wrote:Awesome, loving the WC rig! :thumbsup:
Laziness breeds efficiency.......I did not want to be carrying drums of water in and out of the house :thumbsup:
Ideally the rig should be done with a one piece hose and proper barb / connectors, but at the end of the day when I added up the total for all the hosing and gear it would have cost me 5 times as much as what I ended up with (2 x grey water diverter hoses joined and no barb connectors - the rubber ends on the hoses fit perfectly snug over the 20mm pvc piping and the laguna pump outlet). I was quite chuffed that I saved a few bob.
jordan
Postby titusho » Wed 19 Nov, 2014 9:44 pm
Dosing container looks neat. I was going to get one similar but end up buying individual container because it is a bit easier to top up or clean when needed without taking all 3 out.....
titusho
