Col's 4x2.5x2.5
Col's 4x2.5x2.5
Postby Kransky » Tue 26 Nov, 2013 10:01 pm
Col's 4x2.5x2.5:
System Objectives: New improved version of my 4'x18"x18"
System Type: Mixed Reef, SPS dominated
Strike up Date: TBA
Display Tank: 4x2.5x2.5 12mm glass. 3 hole weir on one end
Display Lighting: 8x54w t5ho possibly with led supplementation
Stand: Custom Stainless Steel
Hood: N/A
Sump: Still sorting out the sump, possibly 4x2x1.5 Acrylic
Refugium: Not sure
Refugium Lighting: Not sure
Display Water circulation: 2x Jebao wp40's
Return Pump: Need to find a quiet pump
Skimmer: BM NAC 3+ to start with, will see how it goes and upgrade if needed
Evaporation Top Up:Auto topup
Calcium Addition: Randys Recipe
Alkilinity Addition: Randys Recipe
Magnesium Addition: Randys Recipe
Current Water Chemistry: N/A
Heres a of pic of the tank being water tested as it was 2nd hand (thanks Mat (GRK-351) for the tank :cheers: )
Before anyone says anything, that aint a leak, its the weir overflowing.
I will post pics of the stand construction as it progresses. The frame materials have arrived ( 304 stainless steel 50 x 50 x 2mm wall shs) the whole stand will be coated with Nyalic protective coating.
Col.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby chromus » Tue 26 Nov, 2013 10:03 pm
WOW that sump must be 1 of those new super low profile things we hear about.
Re: Col's 4x2.5x2.5
Postby Kransky » Tue 26 Nov, 2013 10:07 pm
chromus wrote:WOW that sump must be 1 of those new super low profile things we hear about.
1.5' = 457mm so not really low profile :poke:
chris neill 1987 wrote:good choice on the lights
Thanks Chris
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby chromus » Tue 26 Nov, 2013 10:13 pm
That pic shows about 15mm :roflmao:
Re: Col's 4x2.5x2.5
Postby Kransky » Tue 26 Nov, 2013 10:15 pm
oh, the new stand :roflmao: its a racetrack with a micro skimmer :spit:
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby Kransky » Tue 26 Nov, 2013 10:18 pm
I had to use my gaff hook to drag that pallet from over a barbed wire fence at the shop next door to me for that pallet :roflmao:
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby Kransky » Fri 29 Nov, 2013 8:59 pm
I've started on the stand :)
I will hopefully have it all welded up tomorrow morning :thumbsup:
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby Timmie G » Sat 30 Nov, 2013 9:41 am
Love the idea of a steel stand thinking of building one for my new tank which is a similar size to yours, may I ask what size steel and thickness you are using?
Timmie G
Re: Col's 4x2.5x2.5
Postby Kransky » Sat 30 Nov, 2013 10:31 am
Timmie G wrote:Love the idea of a steel stand thinking of building one for my new tank which is a similar size to yours, may I ask what size steel and thickness you are using?
Hi Timmie,
Material is 304 grade 50.8x50.8x2mm wall
Col
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby GRK-351 » Sat 30 Nov, 2013 3:19 pm
good to see this tank finally with water in it!!
nice work on the stand Col. Might have to ask a favour on my next build!
Mat's first reef tank - 4x2.5x2 Peninsular
http://www.masa.asn.au/phpBB3/viewtopic.php?f=148&t=240695
GRK-351
Re: Col's 4x2.5x2.5
Postby Kransky » Sat 30 Nov, 2013 3:53 pm
GRK-351 wrote:good to see this tank finally with water in it!!
Thanks and no problem mate :thumbsup:
Col.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby Kransky » Sun 01 Dec, 2013 8:15 pm
Okay, so the weir has a small leak right at the top :wall:
probably a good thing as i will be cutting the weir out to repair and it will give an opportunity to remove the black paint that is under it.
now just to get shares in a fishing line company so i can cut all the silicone joins.
Col.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby cody.sheridan-2008 » Sun 01 Dec, 2013 8:18 pm
:clap: Good work, good luck with the repair :)
Re: Col's 4x2.5x2.5
Postby Kransky » Fri 06 Dec, 2013 10:20 pm
some more pics of stand build.
I'll get some more pics tomorrow of the completed frame tomorrow.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby cody.sheridan-2008 » Fri 06 Dec, 2013 10:45 pm
nice col!
Re: Col's 4x2.5x2.5
Postby Kransky » Sun 08 Dec, 2013 7:17 pm
I have finally got the god forsaken weir off.
Paint has been cleaned off the the tank.
Now to clean all the silicon off all the bits and the tank then to reattach the weir.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby cody.sheridan-2008 » Sun 08 Dec, 2013 8:38 pm
why does it have 4 panels?
Re: Col's 4x2.5x2.5
Postby Kransky » Sun 08 Dec, 2013 9:00 pm
Thats why i had to remove it, to clean the paint off from between the weir and the tank.
This tank is a few years old so I'm guessing construction methods were a little different back then.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby cody.sheridan-2008 » Sun 08 Dec, 2013 9:37 pm
yeah... u going to cut it off?
Re: Col's 4x2.5x2.5
Postby Kransky » Sun 08 Dec, 2013 10:45 pm
cody.sheridan-2008 wrote:yeah... u going to cut it off?
umm, it's off.
Cleaning it up and its going back on.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby cody.sheridan-2008 » Sun 08 Dec, 2013 10:50 pm
by that I meant the 4th piece of glass
Re: Col's 4x2.5x2.5
Postby xixau » Sun 08 Dec, 2013 11:48 pm
nice tank Col awesome job
when will be wet? :roflmao: :roflmao: :roflmao:
:cheers: :clap: :cheers: :clap: :cheers:
xixau
Re: Col's 4x2.5x2.5
Postby Kransky » Mon 09 Dec, 2013 4:30 pm
xixau wrote:nice tank Col awesome job
Thanks Rich,
hopefully lift it onto stand over the next couple of days and wet this weekend :thumbsup:
Col
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby peekandboo » Mon 09 Dec, 2013 5:34 pm
That if the stand holds :devil: , we can do it if you want when I'm over your place next week ;) don't wont you to break a nail :baby:
peekandboo
Re: Col's 4x2.5x2.5
Postby NewyReefer » Mon 09 Dec, 2013 5:40 pm
Looking great :clap: ,tagging along.
Re: Col's 4x2.5x2.5
Postby Kransky » Mon 09 Dec, 2013 6:28 pm
peekandboo wrote:That if the stand holds :devil: , we can do it if you want when I'm over your place next week ;) don't wont you to break a nail :baby:
Lol Clay,
You're just a pen pusher ain't you. Don't need you hurting yourself lifting a tank :poke:
Or we're you offering to help fill the tank. :roflmao:
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby peekandboo » Tue 10 Dec, 2013 12:35 pm
Don't use pens, I use a keyboard and calculator :roflmao: :roflmao:
Ill bring some coral down for you ;)
peekandboo
Re: Col's 4x2.5x2.5
Postby xixau » Tue 10 Dec, 2013 11:47 pm
you can pass by on you way down Clay and drop some of your specials :wavey:
xixau
Re: Col's 4x2.5x2.5
Postby Kransky » Tue 24 Dec, 2013 10:47 pm
Update time,
Tank in pos for neighbouring shop to forklift it up to stand :thumbsup:
Tank on stand filling for water test
Tank 99% Full, will test weir repairs on boxing day.
Col.
Cols Tank Journal
Cols 4x2.5x2.5
Kransky
Images: 16
Re: Col's 4x2.5x2.5
Postby cody.sheridan-2008 » Tue 24 Dec, 2013 10:52 pm
Insane mate!
