Rebirth of a goodie 900x900x450 monster birth with Zeovit
Postby Amphibian » Mon 21 Oct, 2013 9:24 pm
To build a mini version of my DT
System Objectives: Frag tank to support main DT
System Type: SPS,
Strike up Date: asap
Display Tank: 900MM X 900 MM X 450MM ex galleri3090 thanks Michael
Display Lighting: PACIFIC SUN HYBRID
Stand:timber stand opened all round for easy access
Sump: Sump specs if applicable. L shape Custom built
System Water: artificial salt water
Display Water circulation: 4 x tunze 6055 water circulation.
Return Pump: EHEIM 5000.
Skimmer: royal exclusiv 200
Reactors 3 X DELTEC
Rowaphos , vertex bio pellets , carbon.
zeovit recator Fauna Marin ZeoMatic
Evaporation Top Up:tunze 3155
Dreambox 5x3x2 viewtopic.php?f=145&t=263224
Mixed Reef 8 x 2.6 x 2 Revamp in progress viewtopic.php?f=145&t=245064
Frag Tank 4 x 3 x 2 viewtopic.php?f=148&t=257402
Rebirth of a goodie900 x 900x450
viewtopic.php?f=148&t=253999
Amphibian
Re: Rebirth of a goodie 900x900x450 monster birth with zeo
Postby Amphibian » Mon 21 Oct, 2013 10:24 pm
pic of the stand , the top is of plywood and sprayed top and bottom with 4 coats of clear marine polyurathane
I will cover the top with a thick recycled rubber, one piece tile
Amphibian
Postby Amphibian » Tue 22 Oct, 2013 5:01 pm
tank in position , with temporary leds
Amphibian
Postby chromus » Tue 22 Oct, 2013 5:18 pm
Rowa and Pellets and Zeo?
Postby millotoli » Tue 22 Oct, 2013 5:24 pm
Looks good. How do you like the dimensions? My wife chipped her 3 ft and i am considering building her a 3 by 3.
you must be loving it, two nice tank builds at once.
millotoli
Postby Amphibian » Tue 22 Oct, 2013 5:42 pm
millotoli wrote:Looks good. How do you like the dimensions? My wife chipped her 3 ft and i am considering building her a 3 by 3.
love the size of the frag tank , would prefer 4 x 4 but this will do until i refurbish the engine room, my mrs calls it the fish room .
im learning a lot as i build the DT and where i have gone wrong, i have made the improvements to the frag tank.
Amphibian
Postby Amphibian » Tue 22 Oct, 2013 5:55 pm
chromus wrote:Rowa and Pellets and Zeo?
i know , what is he thinking . well im experimenting in small scale first before implementing it to my DT.
It will be a strange combo but it may or may not work to plan .
Always wanted to explore the combination.
I realize chemistry composition of the medias and additives is quite complex.
Some one like myself ,a total novice shouldn't explore the boundary's.
I will pursue this method to my madness !!
Amphibian
Postby Amphibian » Tue 22 Oct, 2013 6:08 pm
some of the plumbing under way
Amphibian
Postby Amphibian » Thu 24 Oct, 2013 10:05 pm
I have 2 sumps that i will join together to form a L shape sump.
They will both be joined via 2 40mm im drilling near the base of the back panels.
I will then silicone the two together. i was going to use bulk head fittings , but decided not to as it would have reduced the hole diameter .
I am confident the holes will all line up.
well thats the plan !!!
Amphibian
Postby Amphibian » Thu 24 Oct, 2013 10:15 pm
some of the electrical work under way, will be replacing all the circuit breakers with RCD . I just ran out of stock and wanted to fill in some holes
Amphibian
Re: Rebirth of a goodie 900x900x450 monster birth with Zeo
Postby Amphibian » Fri 25 Oct, 2013 8:53 am
Amphibian
Postby saltymike » Fri 25 Oct, 2013 10:56 am
so many cool goodies in the "fish cave" lol
love the frag racks!!
Mike
Mike and Tina's AR400 Tank Journal link below
http://masa.asn.au/phpBB3/viewtopic.php?f=148&t=243993
saltymike
Postby Amphibian » Fri 25 Oct, 2013 11:08 am
saltymike wrote:so many cool goodies in the "fish cave" lol
Mike
yeah i suppose my garage does resemble a fish cave , once i tile the floor i will be painting the walls with a mural of some sort .
It will be ocean orientated
the frag racks were part of the tank i purchased from Michael , the racks were made by The Blue Glow
well built and i have them in a staggered formation.
Amphibian
Postby ssscuz » Fri 25 Oct, 2013 12:17 pm
That electrical cabinet is awesome!! Nice work mate
Postby Amphibian » Fri 25 Oct, 2013 12:24 pm
ssscuz wrote:That electrical cabinet is awesome!! Nice work mate
thanks ,
i try to keep it neat in an event to track wiring down for modifications its so much easier when they are all numbered
Amphibian
Postby sparker » Fri 25 Oct, 2013 1:53 pm
looks awesome, love the electrical work!
sparker
Postby Amphibian » Fri 25 Oct, 2013 10:14 pm
Sumps are both joined and water tested , all great and the Royal exclusiv 200 skimmer in position ready for action !
front sump section
back sump section
Amphibian
Postby Morgan_1985 » Sat 26 Oct, 2013 10:33 am
That electrical is hectic
Morgan_1985
Postby Amphibian » Sat 26 Oct, 2013 12:17 pm
Morgan_1985 wrote:That electrical is hectic
some times i do go overboard .
" its only a fish tank" i have been told that before .
Well , didn't i arch up to that comment.
im sure all fellow reefers would agree its NOT just a fish tank !
Amphibian
Postby NewyReefer » Sat 26 Oct, 2013 3:03 pm
Looking good mate your doing a awesome job... :clap:
I agree mate its definitely not just a fish tank.....
Postby Richo66 » Sat 26 Oct, 2013 11:22 pm
WOW!
Sensational job!!
That electrical work must have taken ages!
Richo66
Postby xixau » Sun 27 Oct, 2013 12:44 am
Like always love your work Nick :clap:
xixau
Postby Amphibian » Mon 28 Oct, 2013 9:06 am
I have the power supplies installed for the aquaray leds.
tunze 7095 wave maker installed to run 4 x 6055 flow pumps
tunze ph controller for the calcium reactor
tunze mv controller for the ozone generator.
more pic to follow
Amphibian
Postby jayellul » Mon 28 Oct, 2013 4:06 pm
So good!
Postby xixau » Mon 28 Oct, 2013 4:51 pm
...and this is only the "frag tank". Nick well done with your man cave :thumbsup:
xixau
Postby Amphibian » Mon 28 Oct, 2013 5:27 pm
Doising pumps installed together with the neat compact containers
tunze 5017 ato connected.
salinity / ph meter installed
im on a roll now .
Some body stop me !!
Amphibian
Postby Amphibian » Wed 30 Oct, 2013 8:37 pm
Aquaray leds mounted and well and truly under way .
More pic to follow soon .
Amphibian
Postby Amphibian » Thu 31 Oct, 2013 8:18 pm
front view of the proposed frag tank
i have a few things in there just to test it out for now .
I'll monitor its progress and hopefully all will be to plan
Amphibian
Postby Amphibian » Sat 02 Nov, 2013 12:25 am
adding some more to the tank , sohal is loving the space .
just testing it all out for now with some new tank mates for the sohal .
this will be the test now...
they say the sohal is a terror in the tank.
Amphibian
Postby Amphibian » Sun 03 Nov, 2013 9:57 am
skimmer is working hard as it should .
2 of the reactors in position, rowa and carbon .
Amphibian
