Kit's Starphire 5fter - ToTF January 2014
Postby kit » Tue 20 Aug, 2013 10:47 am
I've been planning this build for a few months ... now that things are starting to fall into place, it's time I started a TJ. :thumbsup:
It's going to be a sizeable upgrade from my trusty AquaOne AR850 which has served me well for the past year and a half (TJ here: http://www.masa.asn.au/phpBB3/viewtopic.php?f=148&t=241437)
Here we go... thanks for taking the time to read :nod:
Equipment:
Tank: 5' x 2' x 20" - 12mm starphire - eurobraced - full length coast to coast external weir
Sump: 1000mm x 450mm x 450mm - 3 chamber
Cabinet: 2000m long powder coated steel frame - Polyurethane cladding
Lighting: Illumagic M120S
Skimmer: KZ Revolution S
Heater: Aqua Medic 300w Titanium controlled by an ATC 800+
ATO: Fish Street ATO
Return Pump: Tunze Silence 1073.040
Circulation: Jebao WP40
Dosing: Jebao DP4 dosing pump - Ca, Kh, Mg, KCl (at a later date)
Current fish stock list:
- 2 Occellaris Clownfish
- Green Coral Goby
- Purple Tang
- Kole Tang
- Magnifica Foxface
- Tominini Tang
- Redsea Sailfin Tang
Previous fish:
- Bi colour Blenny (Deceased - Jumped tank)
- Crested Oyster Goby (Deceased - Jumped tank)
- Flame Hawk (Deceased - Jumped tank)
- Lawnmower blenny (Deceased - Jumped tank)
Current FTS 20/7/2014
kit
Re: Kit's Starphire 5fter
Postby nudibranch » Tue 20 Aug, 2013 3:38 pm
Good Luck with the upgrade you've got some nice LPS going in the AquaOne.
What sort of scape are you going with in the 5 footer ?
nudibranch
Postby kit » Tue 20 Aug, 2013 9:29 pm
nudibranch wrote:Good Luck with the upgrade you've got some nice LPS going in the AquaOne.
Yeah, I didn't take photos of them but I am also having good growth with birdsnest, acro, monti and dallas :thumbsup:
Haven't worked out what scape to put in the 5ft yet, probably a simple open layout with 2 stacks. :)
kit
Postby cody.sheridan-2008 » Wed 21 Aug, 2013 11:14 am
Postby kit » Wed 28 Aug, 2013 5:43 pm
It's been a long uphill battle with finding the right tank builder but today I ordered the tank. :banana:
I've settled on a eurobraced 5' x 2' x 20" in 10mm starphire with an external coast to coast weir.
10mm eurobraced seems to be more than adequate and my floorboards should thank me with the weight saving :)
Should take 2-4 weeks...
I'm excited :)
kit
Postby Thommo01 » Wed 28 Aug, 2013 9:30 pm
Exciting stuff :shock:
Postby cody.sheridan-2008 » Wed 28 Aug, 2013 10:22 pm
Postby adamfenessy » Wed 28 Aug, 2013 11:09 pm
Nice tank by the sounds = whos building it for you?
adamfenessy
Postby kit » Wed 28 Aug, 2013 11:31 pm
adamfenessy wrote:Nice tank by the sounds = whos building it for you?
I spoke with and got quotes from a few tank builders but in the end went with Mr Marine.
Todd and Tanya have been really helpful in assisting me with the tank design and looking at some of his previous work, the build quality is excellent.
There will be some really nice finishing touches that I haven't seen other builders offer but I will reveal them after I receive the tank and take some photos :)
kit
Postby Lukebrown » Thu 29 Aug, 2013 5:23 pm
You did well to get hold of Todd!
After seeing some of his past work I wanted him to build my new tank as well, but after about 3 weeks of trying to get a quote from him and never getting any replies to my emails or calls I gave up and went with somebody else.
Lukebrown
Postby kit » Thu 29 Aug, 2013 5:50 pm
Lukebrown wrote:You did well to get hold of Todd!
Todd was the first on my list, but after calling him three times and not being able to get a hold of him I tried other tank builders.
I didn't really like the other quotes so tried calling Todd again; I got through and they were very helpful and always got back to me when they said they would... So, if you can't get through to him, keep on trying! :roflmao:
kit
Postby Morgan_1985 » Fri 30 Aug, 2013 10:22 pm
Can't wait to see it
Morgan_1985
Postby kit » Tue 17 Sep, 2013 11:24 pm
A long overdue update.
Here is the tank and cabinet design which was finalised some time ago (inspired by RodneyRi's tank):
And equipment has started to arrive! Everyday over the last week has been like Christmas! :thumbsup:
Jebao wavemaker and Tunze return pump:
Plumbing:
LED Sump light:
When putting a few of the plumbing components together, I was thinking about how the flexible air hose for the Bean Animal setup would need to be secured somehow... thinking further I decided to make the airline out of rigid hose so that
1. It could be more discreet
2. I wouldn't need to secure it somewhere, it could just stay in place
Going down to Bunnings I purchased these:
I drilled the cap, screwed in the fitting, and then with some cutting and superglue, I made a rigid air line:
Now all I need to do is fit the plumbing, find the optimal water level and then trim the hose
Today I received an update on my cabinet (Built by fellow MASS member, Morgan - Thanks mate! Awesome work so far!):
It's all happening! Tank should be ready in within two weeks!!! :banana: :banana: :banana:
kit
Postby terbit » Tue 17 Sep, 2013 11:32 pm
Looks good Kit, quick question on the stand is there a load bearing sub frame inside the chip board cupboards ?
If not I wouldn't be putting a 2ft tank on it, let alone a 5ft starphire tank.
terbit
Postby kit » Tue 17 Sep, 2013 11:35 pm
terbit wrote:Looks good Kit, quick question on the stand is there a load bearing sub frame inside the chip board cupboards ?
Yep there sure is :)
Inside the cabinet is a powder coated steel frame. :thumbsup:
kit
Postby terbit » Tue 17 Sep, 2013 11:38 pm
Good to hear :thumbsup:
Couldn't see any evidence of it in the pic above.
terbit
Postby kit » Tue 17 Sep, 2013 11:41 pm
Here is the design for the steel frame:
And how it looked after powdercoating, before cladding :)
kit
Postby cody.sheridan-2008 » Wed 18 Sep, 2013 12:01 am
You've done a top job on this build so far Chris :clap:
Postby onetonne » Wed 18 Sep, 2013 12:06 am
Looking awesome! I just setup bean animal on my new setup and it's ridiculously silent. It doesn't even disturb the sump water, amazing.
onetonne
Images: 19
Postby Morgan_1985 » Wed 18 Sep, 2013 7:14 am
That was the idea! :))
Morgan_1985
Postby kit » Wed 25 Sep, 2013 12:29 pm
Not much progress in the past week. Unfortunately there has been a delay, but I should take delivery of the tank and stand soon.
I purchased a second hand sump and reconfigured the partitions... removing partitions is really hard work!
But after a number of hours, here is the end result - and it looks like it works! Silicone work is a bit messy as I didn't want to spray the joins with soapy water to smooth it, but that's OK, it's a sump and won't be seen.
kit
Postby rodneyri » Wed 25 Sep, 2013 7:43 pm
just saw your TJ good stuff mate!
rodneyri
Postby Thommo01 » Wed 25 Sep, 2013 9:09 pm
Good stuff. Have to agree with the whole removing glass thing. PITA!!!!!
Postby cody.sheridan-2008 » Wed 25 Sep, 2013 11:06 pm
Went over to morgans tonight, the stand is BOSS that is the only way to put it!
Postby kit » Sun 29 Sep, 2013 11:54 pm
rodneyri wrote:just saw your TJ good stuff mate!
Thanks! and thanks for your help when I was planning the tank too!
Thommo01 wrote:Good stuff. Have to agree with the whole removing glass thing. PITA!!!!!
Next time I'm buying a new one!
onetonne wrote:Looking awesome! I just setup bean animal on my new setup and it's ridiculously silent. It doesn't even disturb the sump water, amazing.
Yep, after doing a heap of research, looks like it's the best system to use!
cody.sheridan-2008 wrote:Went over to morgans tonight, the stand is BOSS that is the only way to put it!
Hopefully I will have it soon :thumbsup:
kit
Postby GRK-351 » Tue 15 Oct, 2013 10:08 am
any updates chris? should be close by now!
Mat's first reef tank - 4x2.5x2 Peninsular
http://www.masa.asn.au/phpBB3/viewtopic.php?f=148&t=240695
GRK-351
Postby kit » Tue 15 Oct, 2013 10:18 am
GRK-351 wrote:any updates chris? should be close by now!
Unfortunately both the tank and stand were delayed...
But I hope to have both by the end of this week! Will post updates then!
:crossfingers:
kit
Postby kit » Fri 25 Oct, 2013 12:10 am
Finally an update!
Yesterday I took delivery of the cabinet. :banana: :banana: :banana: I am very happy with how it turned out! :banana: :banana: :banana:
A HUGE THANK YOU to Morgan_1985 for making such an awesome stand!
There are a few details that you don't often see in a cabinet.. I highly recommend his work :thumbsup:
The stand is a powder coated steel frame with Polyurethane cladding. Matt finish in Dulux Whisper White (matches my kitchen cabinets).
Front view:
Doors open (three front, two side):
Sump area:
Plumbing opening:
Shark nose detail:
My tank is due for delivery this Saturday.. it's all happening!
kit
Postby rodneyri » Fri 25 Oct, 2013 6:52 am
Very nice looks like its a top quality build too!
rodneyri
Postby potatocouch » Fri 25 Oct, 2013 7:33 am
How much did Todd charge you for the tank?
Does the tank include plumbing work & cabinet? Or you have to build it yourself?
potatocouch
