Postal Tank #3 The sensible one
Postby Postal » Thu 23 May, 2013 9:10 pm
Tank #3 for me, I won't call this tank a dream tank or a no expenses spared tank because that's not true. I prefer to think of this tank as a good example of what i have learnt so far in this hobby, hence the sensible tank.
For a change this tank is going to have a much clearer expectations and plans, hopefully it turns out well I don't want this to turn into an unsustainable chore.
It's still going to cost a packet but i hope to make a lot more smart decisions when doing the tank.
System Objectives: Pretty much a sensible tank. I don't want to over complicate this tank or go too crazy budget wise.
System Type: SPS peaceful community tank with minimal rockwork.
Strike up Date: Wet by end of June is realistic.
Display Tank: 1400mm by 500mm by 600mm, internal weir and eurobraced
Display Lighting: LED, can't be anything else.
Stand: Steel with adjustable feet. Cladded in White panels
Hood: Aluminium frame and cladded in white panels
Sump: Sump size not determined yet, it will only be a 2 chamber sump though, skimmer and then return section.
System Water: Natural salt water.
Display Water circulation: Two Tunze 6095's
Return Pump: TBD
Skimmer: Current front runner RLSS 6i
Evaporation Top Up: Tunze Osmo
Manual Dosing until dosing pumps, VSV dosing, Pete's Amino's and lots of coral food.
Nothing exciting to date
Postal
Re: Postal Tank #3 The sensible one
Postby Postal » Thu 23 May, 2013 9:12 pm
Planned tank
Scape plan
Scape from above
Waiting on some acrylic rod to pin it all together
Postal
Postby Postal » Thu 23 May, 2013 9:34 pm
Adjustable feet turned up now.
Tank is underway with mr dennison
Waiting on steel stand quote.
Plumbing adventures this weekend need to source more rural fittings.
I have an issue i need some assistance with. My Chiller is under my floor so my return goes up 50cm or so into the wall down around 1m to the chiller then back up to the tank, from the bottom of the chiller to the top of the tank it would be about 2.5m.
What is the best estimate at the total head height i need for my return pump.
Postal
Postby galleri3090 » Thu 23 May, 2013 10:43 pm
Awesome, Zeke :clap: I'm sure this will turn into a cracker. I look forward to following it buddy.
Michael
galleri3090
Postby peekandboo » Fri 24 May, 2013 8:16 am
Tagging along Zeke :thumbsup: ,about time you got this up and going :tongue:
peekandboo
Postby jayellul » Fri 24 May, 2013 9:57 am
Tagging along
Postby chromus » Fri 24 May, 2013 10:06 am
Sensible is just another way of saying "lame" :spit:
Good luck with it :thumbsup:
Postby nudibranch » Fri 24 May, 2013 10:31 am
I had always assumed the head height to be the difference between the surface of the sump and the height of the outlet. Atmospheric pressure would assist the pump getting the water "down" to the chiller and back "up" the return to the DT to a height that is equivalent to the sump.
The greater concern on pump size is the losses caused by the length/diameter of the pipe, the number of 90^ turns, Y/T junctions and in-line equipment (ie the chiller).
nudibranch
Postby jayellul » Fri 24 May, 2013 10:41 am
nudibranch wrote:I had always assumed the head height to be the difference between the surface of the sump and the height of the outlet. Atmospheric pressure would assist the pump getting the water "down" to the chiller and back "up" the return to the DT to a height that is equivalent to the sump.
Postby Postal » Fri 24 May, 2013 11:57 am
Thanks for the return pump help, I will chuck a massive pump on to begin with and downscale if required!
And damn straight phil my tank will be the lamest around!
Postal
Postby fishguy23 » Fri 24 May, 2013 5:37 pm
chromus wrote:Sensible is just another way of saying "lame" :spit:
his tanks much cooler than a bunch of sketches though ay phil :poke:
fishguy23
Images: 14
Postby Rusty1 » Sun 26 May, 2013 9:51 pm
I'll back his TJ to see fish and coral before any house journal..
Glad to see you made the right choice and didnt go back to those FW idea's.. :thumbsup:
Tank Now For Sale
Reef In The Wall
Tank on Facebook- Closed
Reef In The Wall- FB
Rusty1
Postby Postal » Mon 27 May, 2013 10:34 am
Thanks Rusty yeah that crazy fresh water talk, who knows what I was thinking.
Nothing too much exciting except I bought a bunch of flexible pipe and then spent 20 minutes arguing at the store that pipe fittings would indeed work on it. The muppets wouldn't sell me fittings so i'll just go to another store :nut:
Got an ato, and organised and ibc, slowly ticking things off the shopping list.
Postal
Postby MeLLeR » Mon 27 May, 2013 10:47 am
Nice Zeke, looking forward to seeing this one come to life ;)
MeLLeR
Postby robthepom » Sat 27 Jul, 2013 9:46 pm
Liar liar pants on fire, well there is always next June.
The tank is gonna look great it fits the house perfectly :wavey:
Now make with the water
Rob The Pom Tank Journal - 3 footer
Rob The Pom Tank Journal - 5 footer
There is a fine line between a hobby and a mental illness
robthepom
Postby Dan » Sat 27 Jul, 2013 10:30 pm
he hangs around with that Phil bloke on chat so next June is probably a better estimate Rob :pirate: :pirate:
since when does a tank ever stay sensible... either way it should be a cracker :cheers:
Postby damer » Sat 27 Jul, 2013 11:06 pm
all the cool kids take their time :thumbsup:
Damien's 1300 x 1200 x 600
damer
Users browsing this forum: MSN [Bot] and 2 guests
