1500x800x600 peninsula build
Postby MitchD » Tue 07 May, 2013 1:49 pm
Hey guys, I've been lurking around the forum for the last month preparing for my new tank build and I thought it was about time I signed up and made a tank journal.
I've had my current 4x1.5x1.5 tank running happily as marine for around 18 months now with no dramas until it recently sprung a leak and dumped half the tank on the floor :furious:.
After a shoddy patch up job (still leaky near the top of the tank, it is 15+ years old) all of my livestock is back in with no losses, although it is low tide in there at the moment.
I took it as a sign that it was about time to upgrade, which brought me here :thumbsup:
System Objectives: Happy & healthy mix of fish and coral
Strike up Date: March 2014 :crossfingers:
Display Tank: 1500x800x600 peninsula room divider.
Display Lighting: 4ft, 144w Cree LED, 24 White 24 Blue with 90° lenses for now. Will upgrade once I get it up and running.
Stand: 1000mm high stainless steel stand, no cladding for now.
Hood: None if possible, otherwise connect-it from Bunnings to support lights.
Sump: 1000x600x500 racetrack style with inbuilt RODI reservoir.
Refugium: frag section.
Refugium Lighting: undecided.
System Water: NSW
Display Water circulation: Waveline DC10000 return & 2 x Jebao wp40
Return Pump: Waveline DC10000
Skimmer: Skimz Monzter SM203
Evaporation Top Up: Tunze Osmolator Universal 3155
Dosing: Kamoer dosing pump
Calcium Addition: Randys
Alkilinity Addition: Randys
Magnesium Addition: Randys
Here's the original designs I knocked up:
http://imageshack.us/a/img199/6667/tankfront.bmp
http://imageshack.us/a/img843/8859/tankback.png
http://imageshack.us/a/img15/5103/sump1.png
http://imageshack.us/a/img823/4898/sump2.png
Here's the final:
Thanks for reading :cheers:
MitchD
Re: 5x2.5x2 peninsula
Postby slawman » Tue 07 May, 2013 3:39 pm
Nice size tank, almost the same as my new build. Only comment at this stage is to check you have plenty of space to setup your beananimal plumbing in your weir. From the drawing it looks like you have about 125mm between each pipe which may make it a bit tight for space in there? What are dimensions of your weir?
slawman
Postby MitchD » Thu 09 May, 2013 10:55 am
slawman wrote:Nice size tank, almost the same as my new build. Only comment at this stage is to check you have plenty of space to setup your beananimal plumbing in your weir. From the drawing it looks like you have about 125mm between each pipe which may make it a bit tight for space in there? What are dimensions of your weir?
Thanks mate, I've drawn the overflow 750 wide x 250 high x 120 deep, but in the end I'll leave it up the the tank builder to do what he thinks is best.
Here's what I came up with last night using the bulkhead and corresponding hole sizes listed on here, and using this hole spacing calculator i found.
(Your solar build is looking really good by the way.)
here are the minimum requirements in regards to distance for drilling glass
x = 1.5 t
y = 4 t
t = glass thickness
measurements are taken from the outer most edge of the hole closest to the edge of the glass.
single hole along side: x from edge
single hole near corner: x from first edge, y from second edge
holes next to each other: x from edge, 4t apart
holes next to each other next to edge: x from first edge, 4t apart, y from second edge
It should work If I push the returns to each side, put the emergency in the middle, and have the main & backup facing out from the middle, it'll be tight but there should be enough room.
MitchD
Postby MitchD » Thu 09 May, 2013 11:03 am
A couple of pieces to the puzzle.
Those wp-40 are huge (softball size) and move some serious water. I wasn't game enough to give it a go on my tank so took it over to my mates, 1 of them replaced 6 powerheads in his 5 footer and made a nice wave. He's got some of his own now as well.
I'll get some crappy pics up of my current tank soon.
MitchD
Postby ssscuz » Thu 09 May, 2013 11:07 am
Nice build mate, pretty much all the gear I want to put into an upgrade!!
Postby Ilona » Thu 09 May, 2013 2:48 pm
I'll be following this one, same size as my intended upgrade :D
Ilona
Postby slawman » Thu 09 May, 2013 4:23 pm
Is that the DC 10000? I am running that on mine as well (if it is). I am impressed with how quietly it pushes that much water.
slawman
Postby MitchD » Fri 10 May, 2013 10:57 am
ssscuz wrote:Nice build mate, pretty much all the gear I want to put into an upgrade!!
Ilona wrote:I'll be following this one, same size as my intended upgrade :D
Cheers lads. :cheers:
slawman wrote:Is that the DC 10000? I am running that on mine as well (if it is). I am impressed with how quietly it pushes that much water.
Yeah that's the one. Itching to test it out, I might stick it in a bucket over the weekend to see how it goes.
Next on the list of things to do is getting the skimmer sorted & sussing out a good tank builder in Perth. Any recommendations?
MitchD
Postby Boggers89 » Fri 10 May, 2013 11:19 am
Ocean Reefs, Vebas or Seaview would be the picks I would say but there is a few others out there, my old man's tank is 10-11yrs old from seaview and well it still looks brand new never had a problem. (haven't dealt with them before)
Boggers89
Postby some_one » Fri 10 May, 2013 10:16 pm
IMO Vebas all the way :pirate:
The stand may not need any additional bracing. You noted steel, what size are you going to use?
My stand is the exact layout as you have drawn. I used patio tube (76 x 38) and it is fine. If your planning on making massive waves, that may be a different story.
You can have stainless steel wire to hang the lights from the ceiling. The only issue you may have is the raked ceiling. The wires need to be fixed to something solid, so you may have to trim in between the rafters to fix your wires to.
Brett
From WA, join MASWA!!
some_one
Postby MitchD » Sat 01 Jun, 2013 11:45 am
Thanks for the recommendations lads, shot Vebas a email the other week but haven't heard back, I'll give them a ring.
KAMOER Dosing Pump, Tunze Osmolator 3155 and Skimz monzter sm203 plus a few other pieces are inbound.
Engine room is pretty much sorted, just need a tank now :konk:
MitchD
Postby ssbk23 » Sat 01 Jun, 2013 11:54 am
Looking forward to watching this come together. It's the same size as mine :thumbsup:
ssbk23
Postby uglyman » Wed 05 Jun, 2013 10:35 pm
Looking like a great build :thumbsup: I would love to hear your opinion of the Skims sm203 once you get it running.
Uglyman's 4ft LED lit mixed reef
If your not prepared to be wrong, then you'll never come up with anything original.
Join the Marine Aquarium Society of Victoria today!!
Join MASOV's Facebook Page
uglyman
Postby MitchD » Mon 10 Jun, 2013 7:48 pm
ssbk23 wrote:Looking forward to watching this come together. It's the same size as mine :thumbsup:
uglyman wrote:Looking like a great build :thumbsup: I would love to hear your opinion of the Skims sm203 once you get it running.
Thanks guys.
Will defiantly give my thoughts on the skimmer.
The gear turned up today, a birthday prezzie for myself. Will chuck up some pics.
Just did a water change on my current tank and the baby blue tang (15mm) I picked up about a week ago thinks it's a good idea to hide under my carpet anenome when he's scared.
Are these guys stupid or does mine just have a death wish lol?
MitchD
Postby MitchD » Fri 19 Jul, 2013 1:36 pm
Long time no post.
After a lot of procrastinating I finally got round to calling Vebas, they said to email through the plans so :crossfingers: I'll get some sort of reply.
Some of the gear I have sitting around
Here's some crappy iphone pics of my current system, pretty basic stuff. Note the low tide due to a leaky tank.
MitchD
Postby MitchD » Fri 23 Aug, 2013 4:20 pm
Loc-line ordered from Modularhose.
Plumbing parts from Dural on the way.
Finalized tank and sump quote was due yesterday so shouldn't be too far off. 1500x800x600 3 panel starphire with polished edgework.
Stand builder & painting sorted out, just waiting on the exact tank dimensions before going ahead.
It's all finally starting to come together.
Here's the final design I came up with:
MitchD
Postby some_one » Fri 23 Aug, 2013 8:27 pm
Nice sump design.
What is the optimum water height for your skimmer?
Brett
some_one
Postby MitchD » Fri 23 Aug, 2013 9:10 pm
Given the skimmer came with no instructions I'm not too sure on the ideal height, but going off their previous model of about the same size, between 180mm & 250mm.
I'm going to make a skimmer stand with adjustable plastic legs like this one.
(Pic stolen from Slawmans build, hope he doesn't mind)
Stand will be 1m high so there will be plenty of room for adjustment.
MitchD
Postby some_one » Fri 23 Aug, 2013 9:20 pm
Great idea :thumbsup:
Brett
some_one
Postby millotoli » Sat 24 Aug, 2013 6:53 pm
Nice detail on your drawings,
other tank looks good too! I'll be stealing the kitchen feet idea for my skimmer as well.
are you going to run your frame up the end to hide the overflow and plumbing?
Ollie
millotoli
Postby Thommo01 » Sun 25 Aug, 2013 10:06 pm
Like the sump layout. Looking forward to seeing how all this turns out. Have a similar set-up planned.
Postby MitchD » Mon 26 Aug, 2013 11:22 am
millotoli wrote:Nice detail on your drawings,
Ollie
Thanks Ollie, yeah the frame will be in line with the edge of the weir.
It'll all be hidden eventually, although cladding is a long way down the list of things to organize at the moment.
Thommo01 wrote:Like the sump layout. Looking forward to seeing how all this turns out. Have a similar set-up planned.
Cheers Tommo
MitchD
Postby MitchD » Mon 26 Aug, 2013 11:38 am
Some more pics.
Birdsnest is starting to take off.
My resident smasher finally decided to show his face. He's only around 40mm.
He's doing a good job of keeping the vermetid snail population in check and getting rid of the odd crab, so I'll keep him around. He'll be sump bound in the new tank.
MitchD
Postby priscacara » Tue 27 Aug, 2013 1:05 pm
Very nice shots of the corals, love the mantis too!
Postby MitchD » Wed 28 Aug, 2013 12:11 pm
Thanks Priscacara.
Loc-line turned up yesterday
My return plumbing will be set up somthing like this:
I'm also thinking of adding a 25mm SCWD to alternate the flow from side to side. What's the general consensus on them? Worth the hassle or not?
MitchD
Postby MitchD » Fri 30 Aug, 2013 7:44 pm
Tank & Sump ordered :banana: :banana:
Edit: Plumbing has also arrived. Adjustable legs & acrylic for skimmer stand, filter sock holder, & RO lid on the way.
MitchD
Postby Morgan_1985 » Fri 30 Aug, 2013 8:04 pm
Nice work man
Morgan_1985
Postby Tjacques » Sun 01 Sep, 2013 11:28 pm
Looking nice.
just wondering where you go your locline from as I'm looking at getting some.
Tjacques
Postby Sunderland » Mon 02 Sep, 2013 12:13 am
I'm in awe at the amount of planning that goes into these things and the detail, obviously really well thought out. Will need to stay tuned to this one!
Newbie Reefer just trying to make my way in this harsh world without killing too much stuff.
Sunderland
Postby MitchD » Mon 02 Sep, 2013 1:01 pm
Morgan_1985 wrote:Nice work man
Cheers Morgan. :cheers:
Tjacques wrote:Looking nice.
I ordered mine direct from the US manufacturer and got slugged 80 odd bucks for postage, but I combined my order with a mate of mine so that made it worth it in the end.
They seem to post express by default (My order arrived in less than a week) So if you got in contact with them before you placed an order I'm sure you could get a more reasonable price.
Sunderland wrote:I'm in awe at the amount of planning that goes into these things and the detail, obviously really well thought out. Will need to stay tuned to this one!
Thanks mate. It's taking a while but I'm slowly getting there.
I tend to over think things quite a bit, which probably isn't a bad thing when planning out something like this.
Id say my sump alone went though at least 10 complete re-designs before I settled on the final layout, even now I'm stopping myself from making changes to it. :roflmao:
MitchD
