Grumpy’s & Memaws Reef!!
Postby Nemo777 » Fri 26 Oct, 2012 8:15 pm
Hi all and welcome to our tank journal.
Firstly let me explain the names, in April 2011 we became Grandparents for the first time. :clap: and will be grandparents again in 2013!!! :clap: My husband wanted to be called Grumpy(what can I say he is a man always Grumpy!!) and I wanted to be Memaw ( I watch way to much Big Bang!!) So that's we got our names. Our grandson loves the fish tank..he calls the fish daddy's!!
Grumpy and I got our toes wet with an Aquamarine tank in April 2012. Now it is October and we are already upgrading to a bigger tank!! So you could say we are both truly hooked on this fishing addiction!!
Both Grumpy and I love the Great Barrier Reef, he is the diver I am the snorkeller. We have been in awe of the reef since our first visit in 2002. Since then we have been several more times. We have also visited other reefs...like the one out the front our resort on the Cook Islands. BEAUTIFUL is an understatement!!
So now it is time to upgrade...upgrade to what was the question. We finally decided on the Aqua One Aqua Reef 400 in white. Our other choice (if we had more money) was the Red Sea MaxS 650... this one is next!! As Grumpy says, small steps are required to achieve our ultimate goal in order to do things right!! :clap:
So get your bags packed, diving and snorkelling gear on and let’s get going to Grump’s & Memaws Reef.
System Objectives: A little bit of natures paradise in our family room!
Display System:Aqua Reef 400
Strike up Date: 25/10/2012
Display Tank: 132 x 52 x 156 cm
Display Lighting: 4 x 54W T5
Stand: Cabinet made from non-corrosive alloy frame and plastic panels.
Hood: Comes with setup
Sump: Sump is supplied as part of the package. We will be replacing the Bio balls with a deep sand bed.
Refugium: Refugium Specifications if applicable.
Refugium Lighting: Lighting specifications.
System Water: Artificial salt water - Red sea salt
Display Water circulation: 2 x Macro Wave Pump 2200-3000l/h and a Macro Precise Wave Maker Controller.
Return Pump:Sump return pump.
Skimmer: Aqua One G220
Evaporation Top Up:Manual
Calcium Addition: TBA
Alkilinity Addition: TBA
Other Chemical Maintenance: TBA
Current Fish Stock List:
Clown fish x 2-In hospital tank recovery from ich
Bicolour angel x1- In hospital tank recovery from ich
Blue tang x1- In hospital tank recovery from ich
Current Coral Stock List:
Elegance coral
Bubble coral
Torch coral
Hammer coral
Duncan coral
Acan coral
Flower pot coral X 3
Planned Stock List:
Splendid Mandarin Pair x2
Yellow Hawaiian Tang x1
Banner fish x2
School of Anthtias x 1
Yellow Goby X 1
The new tank!! :-x
Our new fish!!
One of a kind!!
:clownfish:
Tank Journal http://www.masa.asn.au/phpBB3/viewtopic.php?f=148&t=244956
Aquatic Log http://www.aquaticlog.com/aquarium/dashboard
Sheldon: Ooh, now that is a treat that's hard to beat. Get the Mad Hatter on the horn. I'm having a tea party!
Nemo777
Images: 39
Re: Grumpy’s & Memaws Journey to the Reef!!
Postby priscacara » Sat 27 Oct, 2012 11:59 am
Great intro to the TJ! Love the Aquareef 400 in white too, it looks awesome. Those rugrat fish can grow to a decent size but it takes a while so your safe for now :-)
Postby Rod the Reefer » Sat 27 Oct, 2012 12:11 pm
Hi Grumpy & Memaw,
Great starting point. Am impressed that you are taking it slowly, plenty of time to research and hopefully not make too many mistakes.
All the best.
PS. We are enjoying our second grandchild. :)
Postby Nemo777 » Sun 28 Oct, 2012 2:40 pm
Day One and Two
WOW!!! What a lot of work that was..took us all day Saturday to get the tank and sump built and in place. Filled it with water nearly to the top. Took a few hours and countless trips into town. Once to get the return pump from the lfs as they forgot to give it to us. The other times to get more tank water!! We have two water tanks that needed to be cleaned, so we had to drain them..luckily two of our daughters have tanks as well.
Cleaned the sand and coral sand lots which took more water. Can't and don't want to use the town water..it is a bit dodgy!! :o
Anyway all done for now..added the live rock from our existing tank to the new one. Left one piece as the our rose bta loves it and wanted to leave something for the fish to hide in.
Have tried to aquascape, like it for now but will see. Not a lot of live rock we know, not sure if we will add a whole lot more though..prefer the simplistic look.
Will do water testing later on today...
Also want to pull out the bio balls any suggestions as to what we should replace them with?? Was thinking deep sand bed. :think:
One side
Full tank shot
Other side
Thanks for reading :cheers:
Nemo777
Images: 39
Postby millotoli » Sun 28 Oct, 2012 3:01 pm
Hey Grumpy and memaw.
Your scape looks good
I am a fan of the white stands, it looks a little cleaner i think.
We are doing a aquareef 195 at the moment and we have had the sump modified for a dsb. then i have rubble and macro on top.
you need to lower the first baffle and raise the second one and add a small third one low. There might be other ways to do it, like a tub or container for the sand, it can just sit it in the middle section, the pros would know more.
enjoy :cheers:
Ollie
millotoli
Postby Nemo777 » Sun 28 Oct, 2012 6:06 pm
Just did the water... Calcium and Salinity are low..waiting on new salt to be delivered then this will go up.
Will also bond the rock together once we are happy with the scape.
Hope to start transferring fish and corals over next weekend. Fish maybe first then corals. We hope this is o.k to do???
We will probably take more water from our established tank and put it in to the new tank as well.
Nitrates:0
Phosphates:8.0
Nitrite:0
Ammonia:.25
Calcium:300
Salinity / Specific Gravity:1.019
Nemo777
Images: 39
Postby Nemo777 » Wed 31 Oct, 2012 6:13 pm
Update time.
Had a flood of water from the overflow bottle. All fixed hopefully.
Installed the wave makers to get some flow going :clap:
Ammonia-.25
Nitrite-10
Nitrate-0
Salinity-1.022
:clownfish: :clownfish:
Nemo777
Images: 39
Postby Nemo777 » Tue 06 Nov, 2012 11:50 am
Update time-
We had to move the tank due to the skimmer being difficult. We had original placed the tank on the carpet :konk: :nono: Lessoned learned!!
Moved it to a tiled area of the house.
Have been water testing regularly here are the results-
Wednesday 31st October
Nitrates:10
Nitrites:0
Ammonia:0.25
Salinity / Specific Gravity:1.022
Thursday 1st November
Nitrates:5
Nitrites:0
Ammonia:0.5
PH:8.2
Saturday 3rd November
Nitrates:10
Nitrites:0
Ammonia:0.5
PH:8.0
Salinity / Specific Gravity:1.026
Monday 6 November
Nitrates:5.0
Nitrites:0
Ammonia:0.5
PH:8.2
Took some new tank shots today,the aquascaping is not really good :( Very hard to get right!!
Will leave it for now till we are ready to add our corals from our existing tank.
Thanks for reading :clownfish:
Nemo777
Images: 39
Postby zeebull » Tue 06 Nov, 2012 11:58 am
Nice clean looking tank guys. :clap:
Will look very schmick once you start stocking it.
Craig
Ever wonder how much deeper the oceans would be without sponges?
Zeebulls shallow reef box
Zeebulls mini mantis box
Zeebulls 5x2x2 Shut down april 2012
zeebull
Postby saltymike » Tue 06 Nov, 2012 12:17 pm
Hi Guys,
and welcome to the AR-400 Club. great choice in tanks... i am a little biased lol.
bummer on having to move the tank it would of taken some effort.
looks like you are travelling along nicely so far, only suggestion i'd make is putting the 2 heaters in your sump (looks better in my opinion as its less cluttered) and maybe check your live rock isn't to close to the glass thus preventing easy cleaning whilst doing maintenance and will give the fish a little more swim options.
Mike
Mike and Tina's AR400 Tank Journal link below
http://masa.asn.au/phpBB3/viewtopic.php?f=148&t=243993
saltymike
Postby Nemo777 » Mon 12 Nov, 2012 5:33 pm
Update time-
Ammonia 0 :clap:
Nitrite 0
Nitrate 5 or 0
Calcium 340
Salinity 1.025
Diatoms appeared early last week.
Will do a water change on the weekend. Looking good!!
Will also dose some calcium if the salt and water change does not pick it up.
Thanks for reading
Nemo777
Images: 39
Postby Nemo777 » Mon 12 Nov, 2012 5:50 pm
Saltymike wrote:
Only suggestion i'd make is putting the 2 heaters in your sump (looks better in my opinion as its less cluttered)
We tried to put them in Mike but they wouldn't fit :(
Agree it would look nicer...although we a have a Blue Tang in our other tank that hides behind the heater!!
Will be moving the rock around again on the weekend, trying to aquascape again. :wall: :wall: :wall: :wall:
Tried to use bonding agents...but we worked out that Grumpy is allergic to them :shock: :(
Ah well we will manage.
Nemo777
Images: 39
Postby saltymike » Mon 12 Nov, 2012 8:48 pm
Hope this pic works
Can you do the heaters like this?
Mike
saltymike
Postby spwa » Tue 13 Nov, 2012 7:53 am
Its all looking good great job so far.
The heater should be fine there as long as they are submerged to the minimum line, and by the looks of it they are.
On another note your air intake for the skimmer, make sure its up above the water line as you could have a little accident when the skimmer is turned off and create a siphon.
I am not addictive person I just get mildly obsessed with things.
Simon's 5ft Shallow 380lt
Simon's 3ft Mixed System CLOSED
Simon's 40cm Cube CLOSED
There's always a plan for a new project, but don't tell my wife.(Opps she Knows now)
spwa
Postby priscacara » Tue 13 Nov, 2012 4:23 pm
With my water level U had to lean my heaters to keep them under but have them in the same spot as you :-)
Postby Nemo777 » Wed 14 Nov, 2012 1:20 pm
Thanks for the photo Mike, we are going to try this on the weekend when we do a water change. Agreed it will look nicer :)
One Issue we are having
Is our calcium is quite low.
On the 11/11 it was 340...with 1.025 salinity.
We are mixing our own salt water using Red sea salt.
Should we dose with calcium or leave it till after the water change and hope the salt brings it back up? ( this is what has been happening in our other tank)
:clownfish:
Nemo777
Images: 39
Re: Grumpy’s & Memaws Journey to the Reef with a Aqua Reef 4
Postby Nemo777 » Sun 18 Nov, 2012 2:22 pm
UPDATE TIME
A lot has happened this weekend. Woke on Saturday morning to find the tank very cloudy, immediately thought major ammonia spike.
After further investigation realized oue rose bubble tip anemone gone. :bawling: It was last seen on the glass next to a water flow unit...need we say more!!
The tank was a mess :bawling:
Quick decision was made to transfer all live stock and corals to new system as all the parameters were good.
So one day after all it good, fish are well, coral are well. No signs of stress. :crossfingers:
Some photos of the tank today
Molted Hammer
Hammer
Elegance coral
Duncan coral
Bubble coral
Alveopora
Alveopora
Acan
Bi colour angel, nemos x2, Blue tang
Will do some full tank shots later when all the corals are opened. We are still playing with the flow..
Thanks for ready
:clownfish:
Nemo777
Images: 39
Re: Grumpy’s & Memaws Journey to the Reef UPDATE!!
Postby priscacara » Sun 18 Nov, 2012 6:43 pm
Looks great, like your variety of corals! Just starting to get into acans but haven't found any nice goni/alveoporas in the lfs I would like get yet but looking at yours I might have to try further afield :-).
Postby Nemo777 » Wed 28 Nov, 2012 2:12 pm
Update time
Everything has been going well. Have started to dose calcium as our levels were low.
Added some new editions to the tank.
I finally have a school of fish...dispar anthias, very nice looking fish :)
Also added a snail and a urchin.
Will add more photos later on today.
Thanks for reading
Nemo777
Images: 39
Postby Nemo777 » Wed 28 Nov, 2012 2:20 pm
Thanks Priscacra...I love the goni/alveoporas as well...Would have a whole tank full of them if Grumpy would let me. I have brought some online and some from my lfs.
I hope to get a few more as well as different types of hammers. Then we will concentrate on getting them to grow...then enjoy siting back and watching.
Nemo777
Images: 39
Re: Grumpy’s & Memaws Journey to the Reef NEW UPDATE
Postby Nemo777 » Mon 10 Dec, 2012 4:00 pm
Update
We got 6 new dispar anthias, and a white cheek tang ( early Christmas present from Grumpy :-x ) All are doing well.
My new friend Charlie
We are going to start changing the sump over to macro algae over the holidays. :clap: As well as rearrange the live rock to sit on one side in anticipation of getting some new live rock in the New Year.
Took some more tank shots so enjoy... :clownfish: Will try to make a video as well over the holidays and upload it as soon as i work out how.
More pictures
Purple Goni
Green Goni
Half tank shot
My Grandson Joel loves the fish especially Charlie!!
Other side
Thanks for reading,
Grumpy and Memaw
Nemo777
Images: 39
Postby priscacara » Thu 13 Dec, 2012 11:55 am
Nice new additions, Charlie looks cool! Thats a huge looking elegance, might have to give gonis a try, the colors on yours are great.
Postby Nemo777 » Sat 05 Jan, 2013 3:17 pm
Well not a lot has happened since the last update.
"Charlie" has white spot so him and his friends has gone to a treatment tank. They will be treated with hypo salinity for the next 8 weeks.
This will give Grumpy and I some to re aquascape the tank. We hope to re-position some new corals we got and make sure every-one is happy :clap:
New hammer
New tourch
New Goni
Over the next month or so we are planning some upgrades.
1. New led lights
2. New chiller
3. New tests
4. New wave makers
5. Reef monitoring system
6. Dosing pumps
7. Auto top up
and Grumpy wants a transfer pump, so he doesn't hurt his back as much :sneaky:
We have also the sump. We have added Marco Algae and some live rock and took the Bio balls out.
Will post pictures later after we have re organized some things.
Thanks for reading
Nemo777
Images: 39
Postby priscacara » Sun 06 Jan, 2013 10:37 pm
Bummer on the whte spot but as you said will give you time to rescape and get it how you want it. That is a very bright green gonni, love it!
Re: Grumpy’s & Memaws Reef!!
Postby Nemo777 » Mon 25 Feb, 2013 5:27 pm
Update time :clap:
So over the last few weeks we have changed a few things.
We have had a change of mind with where we were going. We are still building towards a mixed reef, but are choosing more carefully. We have started down a new path with coral and fish selection.
We have changed our circulation pumps to the Aqua One 20000. They seem to be good so far. They stick well with the suction cups.
We also have changed our lights we are now running cree 256w from Guppys. They are pretty good..love the moonlight effect.
Updated coral list
2 toxic revers hammers
1 Goni
1 Duncan
1 Dragon soul favia
1 Green centered star polyps
Updated Fish List
1 Purple tang
1 Lipstick tang
1 Gold headed sleeper gobby
1 Lawnmower blenny
Others
2 Hermit crabs
3 snails
1 Green BTA
Hammer
Green BTA
The Goni is not coming out completely...we had a maroon clown fish try and host it. The clown continually knocked it over. We think it will recover with time.
My favorite fish
Hammer
Lipstick Tang- Please don't call the tang please...he/she is only a juvenile, with plenty of swimming space.
Nemo777
Images: 39
