My new 4x2x2 tank journal
Postby hades302 » Tue 16 Oct, 2012 5:11 pm
Hello and welcome to my tank journal.
System Objectives: A nice part of marine life in my loungeroom for me and my family to enjoy.
Strike up Date: Date system started 16/10/20012
Display Tank: 4x2x2
Display Lighting: 1 x white 36watt and 1 x blue - T8 40watt
Stand: Stand specifications. Pine.
Hood: Hood specifications. Pine
Sump: 2 Foot with 2200lph pump
Refugium: Refugium Specifications if applicable. N/A
Refugium Lighting: Lighting specifications. N/A
System Water: Salt Water
Display Water circulation: Wavemaker 6000l/h
Return Pump: Aqua One 2200l/h
Skimmer: Boyu 1400l/h
Evaporation Top Up: Manual
Calcium Addition: N/A
Alkilinity Addition: N/A
Other Chemical Maintenance: N/A
Ammonia - 0.00 ppm
Nitrite - 0 ppm
Nitrate - 0 ppm
Calcium - 00 ppm
KH - 00 dKH
Phosphate - 0 ppm
Salinity / Specific Gravity: 1.024
hades302
Re: My new 4x2x2 tank journal
Postby hades302 » Tue 16 Oct, 2012 5:21 pm
Adding Weir
Weir Done
Weir Done Image 2
Measuring Sump Up To Fit Everything
Sump Half Way There
Sump Finished And Plumbed In
Tank Ready And Cleaned
Tank And Sump Plumbed And Cleaned
Time To Add The H20
H20 In And Doing A Run Test
Will be adding the salt soon just wanted to make sure i have no leaks :)
hades302
Postby hades302 » Tue 16 Oct, 2012 5:23 pm
Im thinking the 2200l/h pump in the sump isn't enough its flowing but im not happy with it :(
hades302
Postby priscacara » Wed 17 Oct, 2012 12:57 pm
Great build shots, you have done a good job on it.
Postby TrevorR » Thu 01 Nov, 2012 7:58 pm
Any more updates
TrevorR
Postby jason angel » Thu 01 Nov, 2012 8:25 pm
looking good mate!
- JA
jason angel
Postby pafc64 » Fri 02 Nov, 2012 1:11 am
Hi :thumbsup:
Looking good :clap:
If your not happy with your return pump I would suggest you go to a 5000lph pump & run a flexible pipe from it up to where it goes into the tank as your PVC return has a few 90 degree turns in it & that will slow the flow rate down allot,with a flexible hose it will be a more gentle curve & cause less restrictions.
Rick
Ricks 4x2x2
pafc64
