New Tank, bigger size....and a Fresh start with better results
My aim is to create a Top shelf SPS reef to showcase to the best of my abilities the corals natural beauty and provide a better platform for continuing my reefing education.
KZ Zeovit SPS dominated display reef.
20 Sep 2012
Display Tank: Display tank specifications.
1500x750x500 OR 5' x 2.5' x 20" in the old terms. 12mm Starfire eurobraced with external Coast to coast (Calfo) and Conventional Bean Animal plumbing arrangement. 3mm Black acrylic internal with Router cut comb for background.
18" water height to keep it fairly shallow and allow maximum light penetration.
ATI Power-Module 8x54W
1540x850x1000h DIY steel stand with 2-pac House of Kolor poly cladding. Sleek and Modern and ultimately functional. Recessed rear top of stand to allow pipework to be installed behind tank.
Hood:
Open top, dislike the look of hoods generally.
900x600x400 2 section DIY acrylic sump, complete with a ATO resevoir built in.
Only need a sump to house the skimmer, passive carbon and Zeovit reactor.
Refugium:
Not happening. Zeo reef so no necessity for Refugium.
Artificial Salt Water utilising KZ reefers best salt when i can get it.
NSW depending on Delivery timeframes.
Closed Loop Gyre like system
This is an important area and one area I continually underachieve in previous tanks. I have been researching and researching this area in detail and now realise that I really need to improve the flow dynamics in this system. With an increased understanding of the demands of SPS keeping, i aim to be providing my SPS with the correct flow rate and an environment far more condusive for coral health. Should i achieve this then i should maximise the potential results for my display. Michael Galleri, Rod the Reefer, and Semillion's tanks are huge inspirations for me in this regard.
Some light reading on flow found here: http://www.advancedaquarist.com/2007/1/aafeature/view
Sicce 4000L for this important job.
KZ revolution small skimmer from the old tank. Love this skimmer, its service so far has been exceptional.
Auto Top-off via Tunze Osmolator
Calcium Addition:
Randies Recipe 1 via Kamoer Dosing pump.
Alkilinity Addition:
Randies Recipe 1 via Kamoer Dosing Pump.
Full Korallen-Zucht Zeovit system, utilising any supplement from that range as may be required.
Vertex ZF-30 zeovit reactor.
Will be maintained at close to NSW levels to the best of my ability.
Kalium
The Concept:
