listen_to_slayer's simple sumpless 3x18x18
Postby listen_to_slayer » Sat 03 Sep, 2011 1:54 am
Hi Everyone, this is my new tank that is in the process of being set up. I recently downsized from a 6x2x2 due to moving out of home and needing something a bit smaller and cheaper to run. Initially I was planning on buying a RSM, but decided for only a little more cash I could make a system that would have way better gear. I have decided to run this tank without a sump due to the fact that whilst renting I would prefer to limit my chances of having a flood (yes I know the odds are tiny, and my old system had a sump and it was fantastic... which is why as soon as I buy a house I'll be getting a 3x2x2 with a sump :clap: )
System Objectives: To maintain a nice reef tank, I could never afford to fill my old 6 footer with corals.
Strike up Date: December 2011-Jan 2012 hopefully
Display Tank: 3x18x18 - 6mm glass, black silicone without corner plastics
Display Lighting: 1x Orphek PR-156W (120W) - 60:40 (W:B) with 4 UV/Violet diodes. (waiting for it to be delivered)
Stand: 900mm high cabinet that will be as neat as possible. Socket outlets installed in cabinet with only 1 lead coming out of the cabinet and being plugged in
Hood: 350mm high hood, which will probably just have a reactor mounted in it with some GFO/Carbon if needed
Display Water circulation: 2x tunze 6055 pumps with a USB multicontroller - still to order
Skimmer: Tunze 9006 - still to order
Evaporation Top Up: Tunze Osmolator - still to order
Fish Wish list:
Midas Blenny
Royal Gramma
Flame Angel
MAYBE some Banggai Cardinals (not sure if the flame angel would chase these guys around)
Tank as it stands at the moment, cabinet and hood will be stained
doors open with the light on
The only power cord coming from the cabinet
I have the power
listen_to_slayer
Re: listen_to_slayer's simple sumpless 3x18x18
Postby ReefEscape » Sat 03 Sep, 2011 12:42 pm
looking good, iv been looking into leds why did you go with the Orphek light?
ReefEscape
Postby listen_to_slayer » Sat 03 Sep, 2011 1:01 pm
I went with Orphek because their LED's aren't off the shelf diodes like CREE, don't get me wrong, CREE are fantastic quality but the thing I like about Orphek is that their diodes have been specifically designed for reef tanks. The model I purchased also uses 120 degree optics which means one unit should give me enough spread on the tank. And finally the Orphek unit was considerably cheaper than any of the other 'high end' lighting systems, it was just over half the price of a 12" model Vertex and still a few hundred less than all of the others.
I'll be putting the Orphek light over a 2(L)x1(W)x18(H) until this setup is ready so as soon as it arrives I'll post some photos and log some growth rates of corals.
listen_to_slayer
Postby axela » Tue 06 Mar, 2012 12:18 am
any updates man?
Starfire Aquatics - Visit our Facebook page
axela
