Joker's Aquamarine 900
Postby joker959 » Sun 12 Jun, 2011 4:04 pm
Hi, this is my first marine aquarium. I have two pre-school aged boys who, like most kids, love Nemo. So this is really their Nemo tank. I'm sure I'll take over as time passes.
System Objectives: A nice little display tank wit a couple of Clownfish, couple of other fish, easy to keep Corals and an Anemone down the track.
System Type: Mixed reef.
Display System: Aquamarine 900
Strike up Date: 10/5/2011
Display Tank: 3 x 1.5 x 1.7
Display Lighting: Maxspect Razor 160W 16000k LED's
Stand: Standard Aqua One stand
Hood: None
Sump: DIY 2 compartment sump went in on 4/07/2012
Refugium: Macro & live rock
Refugium Lighting: Ecoxotic Stunner LED
Display Water circulation: 2 x Tunze 6045 nanostream.
Return Pump: Marisys 240 pump
Skimmer: Aquamedic Turboflotor 1000
Evaporation Top Up: Tunze Osmolator
Calcium Addition: Red Sea Calcium +3
Alkilinity Addition: Aquasonic carbonate hardness generator
Other Chemical Maintenance: Phosguard in TLF 150 reactor
Ammonia: 0.0
Nitrite: 0.0
Nitrates: 0.5
kH: 130ppm
pH: 8.2
Phosphates: 0.02
Calcium: 350ppm
Magnesuim: Not tested
joker959
Re: Joker's Aquamarine 900
Postby joker959 » Sun 12 Jun, 2011 4:52 pm
This is a pic of the tank with the water just added.
I follwed the instructions in Reefpedia for cycling and added my live rock a week and a half after starting up. After 2 1/2 weeks ammonia and nitrites were 0.0 and nitrates at 5. Another week passed and levels were the same.
I spoke with my LFS and was advised it would be ok to add a couple of small fish and a coral or two. I got 2 small Clownfish and a Slipper coral last week.
The LFS got a new delivery of corals yesterday and I grabbed a nice green Hammer and a Duncan with 13 heads/polyps whatever they are called.
Its a pity they didn't get any snails etc for a clean up crew. I need some to knock down a bit of algae that is growing. It's not much but would like to see it gone.
Does anyone have a recommendation of how many snails I might need? looking at a Stromb and 4 Turbos. Maybe a Lawnmower Blenny. Might not have enough food for the lawnmower though?
joker959
Postby kj52faith » Sun 12 Jun, 2011 5:05 pm
lawnmower b eenies are on 100 percent reef safe and there are guys around selling turbos. You would need 10 to 20 baby ones. Or 9 adults.
kj52faith
Postby joker959 » Sat 25 Jun, 2011 10:29 pm
Stock update: Have now got some Turbo's and a Strom Snail.
I also got two Redline Cleaner Shrimp :-x from Reef Secrects and one small red Starfish from my LFS.
I will add some pics in the morning.
joker959
Postby reefsecretsaquariums » Sat 25 Jun, 2011 10:34 pm
:cheers: yes were are the pics :poke:
REEF SECRETS AQUARIUMS (07) 55356996
unit 2 number 9 Kortum Drive, Burleigh Heads . darren@reefsecrets.com.au
Reef Secrets Facebook Page
http://www.reefsecrets.com.au/
Australian Reefing Connection
EMAIL ME INSTEAD OF PMs IT FILLS UP TO QUICKLY. I CAN CHECK EMAILS FASTER.
I DONT WORK ON MONDAYS >>> ITS MY ONLY DAY OFF .
MASA Partner
MASQ Supporter
Postby joker959 » Sun 26 Jun, 2011 4:01 pm
Ok, here are some fresh pics of our new additions with the names the boys gave them.
Redline Cleaner Shrimp Rocky and Boo.
Starfish named Jim.
Marlin and Nemo (Marlin is the one with "sideburns")
Still looking for ideas for other Corals and Fish. Looking to get a Bicolour Blenny from my LFS this week. Hope to get an Acan like the one Reef Secrets has as profile pic on FB. It looks awesome! :poke: Darren, can you send me a pic when you get a similar one in?
joker959
Postby reefsecretsaquariums » Mon 27 Jun, 2011 11:47 pm
:poke: i would but my underwater camera is broken... ;)
MASA Partner
MASQ Supporter
23/07/2011 new pics added
Postby joker959 » Sat 23 Jul, 2011 10:58 pm
Here is some pics of the tank I took today.
Full tank shot
Bruno the Blenny
The rainbow acan I got from Darren at Reef Secrets.
With flash
under actinics
Micromussa
Duncan
Brain
Torch
The tank has been running well. No dramas as of yet. I added another large piece of liverock which caused a very small ammonia spike but that was sorted with two 25 litre water changes the next two mornings.
will let the tank settle for a while before adding any more fish or corals.
Current livestock list:
2 x Ocellaris clownfish
1 x Bi-colour Blenny
2 x redline cleaner shrimp
1 x Strombus snail
Red Starfish
Turbo snails (started with 5 now have lots of tiny ones as well)
Corals
Hammer
Torch
Slipper
2 x Rainbow Acan
Micromussa
Duncan
Brain
joker959
Postby joker959 » Sun 29 Jul, 2012 9:11 pm
Well I thought it was time to do an update since it has been 13 months since the last one.
Summer was not kind to my tank. A combination of the temp getting as high as 30 deg in the tank and a malfunction in the lights (my LFS replaced the whole hood unit under warranty) resulted in the loss of my Acans, Brain and slipper coral. As a result I am upgrading my lighting to Maxspect Razor LED's and getting a chiller before summer. Just waiting for the light to come in as I pre-ordered it about 6 weeks ago, have been told to expect delivery this week.
I have also done away with the Marisys 240 filtration. I now have a DIY 2 part sump in the cabinet. The left side has my new Aquamedic turboflotor 1000 skimmer which pulls 20 time more gunk than the Marisys and a filter sock. It also has room for a pump for the chiller.
There are 3 holes drilled for plumbing through the dividing wall to the right side. This side has macro and live rock as well as the return pump I took out of the Marisys. Lighting is 1 x Ecoexotic stunner white strip.
The new sump set-up has seen my Nitrates reduce from above 20 down to 4 in 3 weeks using the Red Sea pro test kit.
Current stock list:
2 x Orange Occellaris Clowns
1 x B&W Occellaris Clowns
2 Clarkii Clowns
1 x Royal Gramma
1 x Bi-Colour Blenny
2 x Redline Cleaner shrimp
1 x Strombus Snail
4 x Mini Hermit Crabs
1 x Starfish
Turbo Snails
1 x Orange tip BTA
joker959
Postby dorz » Sun 29 Jul, 2012 10:01 pm
looking very nice! id be interested to see how the overflow is done, i used to have an aquamarine 900 too so if youre after any ideas, the link to the thread is in my sig :)
I like to glue animals to rocks and put disturbing amounts of electricity and saltwater next to each other
Dorz' 3x1.5x1.7 Modded Aquamarine 900!
Dorz' NEW 4x2.5x2' Automated Bucket!
powered by ORD; obsessive reefer disorder
dorz
Postby joker959 » Sun 29 Jul, 2012 10:20 pm
Here are some pics I have taken tonight.
joker959
Postby joker959 » Sun 29 Jul, 2012 10:24 pm
Dorz, as you can see by the pics I just put up, I still have the overflow box from the Marisys. I was following your journal when I first got this tank. it has given me a lot of ideas along the way. As you know, it's not the best system, but is a good beginners aquarium. I am already planning to upgrade to a bigger 5 or 6x2x2.
joker959
Re: Joker's Aquamarine 900 (now with DIY sump)
Postby priscacara » Tue 31 Jul, 2012 1:23 pm
Looks stunning! I keep umming and ahhing about any shrimp for my tank once its running so seeing yours has made be backflip quicker than a politician :-).
Postby joker959 » Tue 31 Jul, 2012 11:14 pm
Thanks Priscacara.
The Redline shrimp aren't cheap but they are a great addition to the tank. They try to clean my hand whenever I reach in to add new coral or clean corraline algae off the glass. The Bi-colour Blenny lets them clean him every now and then, the clowns and Gramma dont go near them though.
joker959
Re: Joker's Aquamarine 900 (DIY sump & Fan worm on glass)
Postby joker959 » Sun 05 Aug, 2012 9:47 am
I opened the sump cabinet this morning to check out the new live rock I put in there yesterday and was surprised to see this.
I haven't seen a fan worm on the glass before, has anyone else?
joker959
Re: Joker's Aquamarine 900 (DIY sump & Fan Worm on glass)
Postby priscacara » Sun 05 Aug, 2012 12:01 pm
Nice find!
Postby spwa » Sun 05 Aug, 2012 1:07 pm
Great system love the sump. must confess I am a DIY addict.
The Fan Worm.
Maybe you buried his tube at the bottom of the live rock?
I am not addictive person I just get mildly obsessed with things.
Simon's 5ft Shallow 380lt
Simon's 3ft Mixed System CLOSED
Simon's 40cm Cube CLOSED
There's always a plan for a new project, but don't tell my wife.(Opps she Knows now)
spwa
Postby joker959 » Thu 23 Aug, 2012 4:06 pm
Here is a video of my Clarkii feeding the anemone. I only have the white lights on as the video looked too blue with both on.
http://youtu.be/GHXBQ121msU
The Maxspect Razor LED lights have been on for 2 weeks now and they are awesome! :pirate:
Well, 2 dolphin torches strapped to the tank would be better than the compact fluorescent lights that were in the hood before. :roflmao:
I have some new acans from reef secrets that I will take pics of and put up later too.
joker959
Postby priscacara » Tue 28 Aug, 2012 1:36 pm
Liked the vid, I might have to do a bit of research on anemone's .......................told myself I wasn't getting one and I wasn't getting clowns but slowly changing my mind after seeing vids like yours.
Postby MBJManning » Sun 14 Apr, 2013 1:04 am
Hi!
Found this forum post via google. I have just recently bought an Aquamarine 900 with the MariSys 240 Filtration system with a chiller as well due to the heat we get in summer.
Im 18 and my tank will be a nemo tank too :)
Hoping your tank is still running and good
MBJManning
Postby joker959 » Sun 21 Apr, 2013 11:03 pm
MBJManning wrote:Hi!
Hi mate,
The tank has been running pretty smoothly since I got the chiller back in September. I haven't had anything major go wrong (touch wood) since I started the aquarium.
The best thing I have done since I started all of this was to get rid of the Marisys and build the sump and get a proper skimmer. The standard one just wasn't coping with the parameters I was aiming for.
Enjoy your new tank, it's a very addictive hobby.
You have a great LFS at Thornton too, I have bought a lot of my hardware and livestock from Hunter Pets, they have a great range.
Cheers - Brett
joker959
Postby joker959 » Mon 22 Apr, 2013 6:21 pm
Ok, here is a few pics of my tank today.
The BTA is hiding in the rock work and has bleached out. It began to bleach after I added the LED lights. I have read Chromus' thread on reviving anemone's and will give it a try to see how it goes.
joker959
Postby priscacara » Tue 23 Apr, 2013 2:41 pm
Hope the bta makes a comeback! Some beautiful corals, they really stand out with those lights.
Postby joker959 » Sat 18 May, 2013 10:48 pm
I have recently fragged some of my Acan's and Zoas and sold them. I picked up some Dallas frags from Tim and Chris when I was in Newcastle a few weeks ago, they are my first attempt with SPS corals. They haven't lost any colour and are even growing! :clap:
Here is a few more pics of the tank including my homemade frag rack and new Catalaphyllia Jardinei (Elegance coral) that I picked up at Mik's Pet Barn here in Forster.
Sorry about the iPhone pics, it's the best I could do. Click the pics for the full photo.
I bought a TLF 150 Phosban reactor that I'm running Phosguard in to reduce Phosphate levels. It tested at 0.25 (LFS api test kit) 4 weeks ago and after running the Phosguard for the last 2 weeks is down to 0.20 on my new Hanna checker.
I don't want phosphates down to 0.00, just below 0.1 should be ok for the corals I have at the moment.
Thanks for looking.
Brett
joker959
Postby priscacara » Thu 06 Jun, 2013 2:15 pm
Looks great, love that elegance its one of my favorite corals.
Postby joker959 » Thu 27 Jun, 2013 11:04 pm
So I've worked out how to take more pics that look more like what the tank does in person. Had to turn off the "B" channel blue led's.
joker959
Postby joker959 » Sat 13 Jul, 2013 11:07 pm
It has taken my Redline Cleaner Shrimp 18 months to work out what his job is. Here's a quick video of him in action. Click the picture to watch.
joker959
Postby potatocouch » Wed 16 Oct, 2013 2:44 pm
Hey joker,
I was just wondering with your return pump (Marisys 240 pump) - doesn't this include protein skimmer built-in already? Because I noticed that you have a separate protein skimmer (Aquamedic Turboflotor).
Just an extract from the item description "The skimmer has also been upgraded to a more efficient and powerful pump driven protein skimmer".
Just for my knowledge because I may need to get sump and return pump too.
Perhaps I misunderstood the item description.
potatocouch
Postby joker959 » Mon 21 Oct, 2013 8:35 pm
Potatocouch, I am using the return/skimmer pump from the Marisys 240 as my return pump and the new Turboflotor skimmer has its own pump.
joker959
