This tank came about after a little disaster with my dream tank. This will be a dedicated SPS tank due to the Angel I currently have eating all the other types of corals.
I currently have more rock than I planned but am happy with the Aquascape so it is staying. I am also attempting to automate as much as possible to give the tank stability as well as chosing low wattage equipment where possible.
System Objectives: To run a successful SPS system with minimal work to maintain it
System Type: Mainly SPS
Display System: 1500 x 800 x 550 with Starfire front panel. It has a coast to coast (partly) overflow and is built by 1 of Brisbane's best tank builders, Dennison from Mary Anne's.
Strike up Date: September 1 2010
Display Lighting: 2 x Coral Vue dimmable 250watt ballasts with Lumenbright reflectors. Computerised moon lights. 2 x 80w T5 running KZ Fuji Purple and Geisman Pure Actinic
Stand: DIY timber stand cladded on 3 sides, open back. The panels are press on and pull off.
Hood: The hood is a 3 sided slip on to finish it off.
Sump: Currently running my old sump from the 6ft'er I had. It is 920 x 550 x 450 race track.
Refugium: Remote refugium added March 2012
Refugium Lighting: 2 x 24w Power Compacts
Support systems:60KG of rock maybe a bit less. Running Bio Pallets on this 1.
Display Water circulation: 2 x MP40's, 2 x Tunze 6205
Return Pump:Lag 11000 run externally.
Skimmer: ATI Powercone 250
Evaporation Top Up:Auto topup Profilux
Chemical Support: Turbo special CR
Calcium Addition: N/A
Alkilinity Addition: N/A
Other Chemical Maintenance: Non at this point
Nitrates: < 5ppm
Phosphates:.05 Sept 2012
Alkalinity: 8 DKH
Calcium: 400ppm
Salinity / Specific Gravity:1.026
Magnesuim: N/A
FTS SEPT 2012
Sept 2010
Trimac
Rabbit Fish
Mystery Wrasse
