Petes Aquarium Mini (New FTS Pics 56K beware)
Postby petes-aquarium » Mon 20 Sep, 2010 12:34 am
After putting a hold on my bigger PROJECT I have started something a little smaller. Don't get me wrong the bigger tank is still going to happen and will be a combined system with overflow into this smaller system.
System Objectives:
Create a clean happy reef, with minimal fish and possibly a clam or two.
System Type:
SPS, Mixed Reef with minimal fish.
Strike up Date: Yay strike up occured 01-10-2010 :clap:
Display Tank:
Tank size 915mm x 640mm x 550mm Rimless with full length overflow. PURCHASED
Display Lighting:
Custom made LED, cree powered with T5 tubes for actinic. HALF MADE
Stand:
Custom made using a brick bar that will be enclosed with plaster to create a fish room. STAND DONE NEED TO DO CLADDING AND PLASTER
Hood:
Currently made from Connect-It square tubing. MOSTLY DONE
Sump:
Sump size 1000mm x 420mm x 440mm WAITING FOR IT TO GET BUILT
Refugium:
Second Chamber in sump 300mm x 420mm x 354mm
Refugium Lighting:
Haven't decided yet (more than likely a T5 tube or two.
System Water:
Natural salt water
Display Water circulation:
2x Vortech MP40WES PURCHASED
Return Pump:Sump return pump.
Laguna PowerJet 6000 PURCHASED
Skimmer:
Reef Octopus XP-2000 SSS PURCHASED
Evaporation Top Up:
Tunze Osmolator Universal 3155 PURCHASED
BM-T01 Dosing Pump 3 Channel with latter addition of BM-T02
Calcium Addition:
Not sure yet, leaning towards Tropic Marine or seachem products.
Alkilinity Addition:
Other Chemical Maintenance:
Nitrates:
Salinity / Specific Gravity:
To come tomorrow, Getting past my bed time. :roflmao:
Last edited by petes-aquarium on Fri 04 Feb, 2011 10:10 pm, edited 8 times in total.
My Tank Journal Currently on hold
Mini Tank Up and running
My photo site
petes-aquarium
Re: Petes Aquarium Mini
Postby petes-aquarium » Mon 20 Sep, 2010 12:35 am
Progress Pics.
Some bits.
Plumbing so far.
Tank as it sits atm, waiting for sump.
My photo site
petes-aquarium
Re: Petes Aquarium Mini Update
Postby petes-aquarium » Tue 21 Sep, 2010 7:22 pm
Todays update.
Just ordered a PSI-020B-DI-LW RO/DI unit from PSIFILTERS after talking to Peter on the phone, this seems to be the best option, at a later date I may purchase a solenoid and a float switch. This is all new to me so should be interesting to connect up when it arrives. Another toy to play with... :roflmao:
I will be changing the hood slightly after having a look; it kind of spoils the point of having a rimless tank. So will look into changing it so it is floating somehow.
Something like this maybe.
On another note hopefully my sump will be ready this week, got two days of this week so crosses fingers that it is. If so It will be set up for it's test run with fresh water.
Thanks for looking,
Peter.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (Updated 21/09/2010)
Postby bradw6860 » Tue 21 Sep, 2010 8:01 pm
mate where did you get the super reef octopus?
bradw6860
Postby petes-aquarium » Tue 21 Sep, 2010 8:34 pm
bradw6860 wrote:mate where did you get the super reef octopus?
From Dennison at Mary Annes Aquarium, I did have a classic 500 but this just came in and looks allot better. Haven’t really seen any reviews of it as of yet.
Peter.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (Updated 26/09/2010)
Postby petes-aquarium » Sun 26 Sep, 2010 7:55 pm
Received the sump on Friday and have been playing around with the plumbing all weekend, I still have to get some bits to finish it off tomorrow. Here are some pics so far of the system, it is slowly getting there and can't wait..... :)
This is the tank so far, still have to hang the lights from the ceiling. They are just sitting on the lip atm, luckily they don't way too much.
The weir so far I have cut down the emergency as it is too high in the pic. Flow is real good and very quiet.
A pic of the sump.
A close-up of the overflow, Ball valve is to be changed to a gate valve tomorrow. The flexible tube is just there to hold it up while testing.
A pic of the chiller plumbed in.
Thanks for looking,
Peter.
My photo site
petes-aquarium
Sump sorted
Postby petes-aquarium » Tue 28 Sep, 2010 10:00 pm
Hey all,
Small update, the plumbing and sump are finally sorted and have stable water levels in the weir finally (no fluctuations) I decided to go with a full syphon feed to keep noise down and an emergency backup. Only problem I am having is that my Laguna 6000 seems to have gotten a rattle kind of sound after 3 days of dead quiet running, not sure what’s caused the rattle. I have tried sponges under it with no luck and running it so it touches nothing but the outlet tube (no glass contact at all).
Plumbing layout with hose water change tap.
Image Image Image
Also got my PSI-020B-DI-LW and plumbed it in, seems to be working very well. my incoming water is around the 120 PPM TDS and outgoing is 0 PPM on RO and around 5 to 10 PPM on RO/DI (is this normal, not sure as never had a filter like this).
RO/DI Plumbing and units current location.
Image Image
Thanks for looking,
Peter.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (Strike up day 1-10-2010)
Postby petes-aquarium » Fri 01 Oct, 2010 11:18 pm
Hi all,
Today’s update , finally got some salt water in the tank thanks to Tommie for delivering my IBC with 1000L NSW... :) Some pics for you all to look at, nothing too exciting as of yet. Will be purchasing first lot of live rock tomorrow (10KG) planning to put 10KG in each week or two until I have about 30 to 40 KG depending on looks.
Filling the tank up.
Level in the weir.
Skimmer going crazy on its first start up, never had one before seems to be working damn good so far. Still need to tune it better and get levels correct.
And last but not least, as it sits on strike up day. Damn it looks boring so far.... :)
Thanks for looking.
Peter.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (Strike Up Day 01-10-2010)
Postby sydneydrewid » Sat 02 Oct, 2010 9:13 am
looking good.. the layout looks well thought out.. good luck :thumbsup:
Postby StripestheEel » Sat 02 Oct, 2010 10:53 am
Congrats Pete!
Postby petes-aquarium » Sat 02 Oct, 2010 9:13 pm
Hi all,
Today I bought roughly 18KG's of live rock and put it into the tank, I think the look is pretty good with plenty of room for acros etc.... when the time comes. The look I am going for is 2 bommies one back left side and one front right side, so far the back left one is done. Will get more liverock in a week or so.
This is what I came up with.
Also spotted my first thingo, don't know what it is but will find out. Any idea what it is...?
Thanks for looking,
Pete.
My photo site
petes-aquarium
Postby petes-aquarium » Thu 07 Oct, 2010 9:36 pm
Hi all,
Small update for today on how the tank is moving.
Current water parameters are below. I have started slowly dosing Brightwell Liquid Reef to boost Calcium/Alkalinity as they are on the low side. Ammonia/Nitrite and Nitrate have dropped considerably in the last couple days also and brown algae has started forming on the live rock. The cycle is under way and hopefully in a few days I can add a hermit crab or something small. :clap:
PH: 8.2
SG: 1.024
TEMP: 26.2
ALK: 6DKH LOW
CALC: 372mg/L LOW
AMMONIA: 0.05ppm HIGH
NITRITE: 0.1ppm HIGH
NITRATE: 5ppm
Some more hitchhikers that have been seen in the tank. not too sure what the snail is but the Brittle star was pretty cool on the glass and quickly retreated once the lights came on.
Image Image
And also a pick of a button that came on the live rock, really wonder if it is going to survive or not with that much skeleton exposed. Seems to be opening its mouth and does plump up slightly through the night :crossfingers: that it will be OK.
On another note the parts for my second string of 24LED's arrived today, hopefully will have them built this weekend.
Thanks for looking, and sorry for the crap pics currently can't be arsed getting the SLR out. :konk:
Pete.
My photo site
petes-aquarium
Postby petes-aquarium » Fri 15 Oct, 2010 9:16 pm
Small update, have added my first corals and some snails.
The snails I have added so far are listed below, the strombus is awesome and has done a real good job of cleaning the substrate.
2x Trochus
1x Strombus
Here are some pics.
The Aquascape so far.
The Strombus at work
Two Zoa's that I have added and the two Trochus snails.
Thanks for looking.
Pete.
My photo site
petes-aquarium
Postby n0rk » Fri 15 Oct, 2010 11:04 pm
Interesting Zoos, man. The ones on the right are sweet as.
BENJAMIN ::: If at first the idea is not absurd, then there is no hope for it.
IF YOU CAN READ THIS, YOU ARE LOOKING FAR TOO CLOSELY. I FEEL VIOLATED.
n0rk
Images: 10
Re: Petes Aquarium Mini (one month update)
Postby petes-aquarium » Mon 01 Nov, 2010 10:56 pm
Thought I would do a one month update, tank is going very good and am rather happy with its progress. All water parameters are stable.
PH: 8.2 to 8.4
SG: 1.025 to 1.026
TEMP: 25.5 to 26.9
ALK: 8d KH
CALC: 400 mg/L
MAG: 1200 mg/L
PHOS: 0.01
Current fish list5x Blue/Green Chromis
2x Clowns
1x Ember Blenny
1x Leopard Wrasse Male
2x Fire-Tail Gobies
1x Golden-Head Sleeper Goby
1x Green Mandarin
1x Blue Streak Cleaner Wrasse
Still to get a tang, still haven’t decided. Possibly Hawaiian yellow or a purple tang, although I do like the bristletoth kohl tangs.
Current Coral list
2x small zoas
1x Green torch
1x Anchor
1x Heliofungia
1x Elegance
Still to get heaps more... :roflmao:
Some Pics, I know there is still algae the Ember Blenny isn't a miracle worker. :roflmao: but he has cut it down a crapload.
Thanks for looking,
Pete.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (one month update, with pics)
Postby bjrouse » Mon 01 Nov, 2010 10:59 pm
Looking the goods mate
Kingston Town...SIMPLY THE BEST
My Tank
bjrouse
Postby petes-aquarium » Sat 13 Nov, 2010 8:05 pm
Small update,
Some pics of progress damn I need to get my 150mm Sigma or Canon 100mm F2.8L, using extension tubes are crap. The tank seems to be going good, loving the corals especially at night.
Benny the Blenny
Sea Star
Maze Brain
SPS frag
Preety sure I will be starting work on my big tank very soon, Salt Water is bloody addictive... :roflmao:
Thanks for looking.
Pete.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (FTS)
Postby petes-aquarium » Mon 06 Dec, 2010 9:29 pm
Just a quick update picture as it stands today.
Thanks for looking,
Pete.
My photo site
petes-aquarium
More pics 56K beware.
Postby petes-aquarium » Fri 04 Feb, 2011 10:09 pm
A small update, with a couple of pics.
Full tank shot.
Full tank shot, slightly older pic. Lights are fully hung from ceiling.
My hammers :-x love them... :)
Someone recomend me a chiller for about 2000Litres, thinking of a Hailea 1000 (but they are noisy) also thinking of a Teco TR30 (but its $$$$) might go for a Hailea HC-2200BH any one got one....? are they any good....?
Pete.
My photo site
petes-aquarium
Re: Petes Aquarium Mini (New FTS Pics 56K beware)
Postby marks » Fri 04 Feb, 2011 10:17 pm
Looking very good Pete, love those hammers.
Mark
marks
Postby StripestheEel » Fri 04 Feb, 2011 11:38 pm
Looks bloody fantastic Pete!
Postby mattgreen » Sat 05 Feb, 2011 12:17 am
this tanks stunning. same size as my new one will be. id have to deffintely recomend a bristtooth tang. (or kole) so much personality, and dont seem to need a large amount of swiming space, mine just grazes all day
mattgreen
Postby Barney83 » Sat 05 Feb, 2011 9:08 am
Thats a nice looking tank. And in such a short amount of time.
Good stuff!
Barney83
Postby fishwhisperer » Sat 05 Feb, 2011 10:10 am
:-x great colors :-x
And a spectacular build!!! Good on ya pete!!
Marcel.
water on my brain
fishwhisperer
Postby robthepom » Sat 05 Feb, 2011 12:41 pm
Nice tank Pete .....great hammer garden....might inspire me to clump mine togeather ...& great photos :thumbsup: :thumbsup:
Rob The Pom Tank Journal - 3 footer
Rob The Pom Tank Journal - 5 footer
There is a fine line between a hobby and a mental illness
robthepom
Postby robthepom » Sat 05 Feb, 2011 12:43 pm
Just noticed the chains hanging the lights ...they must have a 'safe working load' of 1ton each chain....how heavy are those heat sinks :roflmao: :roflmao: :roflmao:
robthepom
Postby petes-aquarium » Sat 05 Feb, 2011 9:08 pm
Yeah Rob, just a wee bit of overkill. All up weighs maybe 15-20KG's. And clumping the hammers together makes PE huge.
Matt I saw your new tank render at Marry Annes the other day as well, should be great when up and running.
On another note my Leopard wrasse just went belly up, wouldn't have a clue why. Was eating and swimming well yesterday, and no marks on his body. Hate when I don't know why things die. Only thing I did was give the tank a 25% water change like I have done a few times now.
Pete.
My photo site
petes-aquarium
Postby mattgreen » Sat 05 Feb, 2011 9:36 pm
howd you see it there? should be good been working on the stand today, had another look at your pics those hammers are STUNNING they look great!
mattgreen
Postby Jamess » Sat 05 Feb, 2011 9:44 pm
Awesome tank. BTW I think your first "thingo" was a cucumber of sorts. Not sure if anyone else already id'ed it (:
James' 4x2x2 Decommissioned and recycled to make....
950x600x450 LED Study Escape
Jamess
Images: 6
Postby Kapyong23 » Mon 24 Oct, 2011 9:41 pm
Great job to date pete :thumbsup:
The truth be known we dont keep fish - we keep water! - David Saxby
7 x 3 x 2 TJ - decomissioned
500ltr pre-build.
Kapyong23
Users browsing this forum: No registered users and 22 guests
