Well after playing around with FW tanks for a while and going in and out of fish shop all the time and seeing the beautiful selection of colours and shapes in the marine sections I always knew I wanted to give it a go eventually. So here is my eventually starting to happen
Current FTS before shutdown(already took the light off)
System Objectives: To create a visually stunning display while learning the marine tank ropes. Hopefully get good at it one day (if all goes well) look at expanding.
System Type: Mixed Reef, with plenty of softies as the wife likes them the best
Strike up Date: Start of August 2010
Display Tank: Existing (previously a planted tank) 70 x 70 x 60cm cube made of optiwhite glass, with overflow.
Display Lighting: 150W MH with 14000k solarmax globe, 2 x 24W HO T5 Actinic globes. Lights will be lowered to 20mm above tank to avoid jumpers.
Stand: Existing stand. Steel frame.
Hood: Open design, Really just a shroud to hide the lighting
Sump: 60 x 40cm sump. Existing baffles need to be modified and new ones added to suit marine sump.
Refugium: In sump. Size will depend on space left after new baffles are put in.
Refugium Lighting: 90W LED panel that I had for my planted set-up(hopefully this isn’t too much overkill)
System Water: Artificial salt water ( will look into Natural once I get set-up)
Display Water circulation: Hydor Koralia's K Copy 5000L/H Power head
Return Pump:Eheim universal pump 38l/min
Skimmer: Bubble Magus BM-NAC180-CS Cone Protein Skimmer
Evaporation Top Up:Auto topup with RO/DI from 50L top up container.
Calcium Addition: Calc support via Bubble magus auto doser
Alkilinity Addition: Alk support via Bubble magus auto doser
Other Chemical Maintenance: ??? If needed via doser
From this
Back to a clean slate with lots of work to progress
My sump modification plans. Any thoughts or advice?
First time I used Sketchup, pretty cool
Any advice on how to go about removing the old baffles. I tried tonight for a short time and 3 broken razor blades and no success later
I'm Getting excited
