Frank's new project 120x90x55 sps with ATS and Chaeto reacto
Postby frk27 » Mon 11 Apr, 2016 7:20 pm
After nearly quitting the hobby due to work load, I decided to start a new set up easier to take care off.
I sold my old zeovit tank, bleach all my live rock(got aptaisia) and acid wash them.I start to aquascape keeping only the nicest and most porous rock after couple of month I am pretty happy with the outcome so I start to cycle them in bunning tubes while waiting for the tank.
System Objectives: I want to create a colorful, well aquascape reef tank easy to maintain
System Type: Reef tank mostly sps and lps
Strike up Date: TBA, asap
Display Tank: 120x90x50 rimless with corner internal overflow made by Dennisson
Display Lighting: 2X GHL mitras LV 6100, I am using AI rail mounting to hang them
Stand: Powder coated steel stand, kitchen cabinetry cladding with magnet. Will do an electric board away from the sump to plug all equipment and hide the chiller
Hood: No Hood
Sump:Raceway style sump 75x75x45, filter socks compartment, refugium, skimmer compartment and return
Refugium: refugium to grow macro algae and space for Turbo Algae scrubber,marine pure block and I will be running a Chaeto reactor as well
Refugium Lighting: LED
Display Water circulation: 2X Tunze 6105 and 1 maxspect gyre x150 everything control by apex Neptune controller
Return Pump: Laguna Max-Flow 9000l/h
Skimmer: BK SM 250
Evaporation Top Up:Autoaqua smart ATO will change down the track to tunze, I really don't trust this smart ato
Calcium Addition: 2 part randy dosing
Alkilinity Addition: 2 part randy dosing
Other Chemical Maintenance:Magnesium
frk27
Images: 88
Re: Frank's new project 120x90x55 sps with ATS and Chaeto re
Postby NewyReefer » Tue 12 Apr, 2016 7:51 am
Looking forward to watching this as im also in the planning stages of a 4x3 :thumbsup:
Postby afhtan » Tue 12 Apr, 2016 1:05 pm
Out of interest what things were taking too much time? Was it maintaining the supps for ZEO?
I am setting up a 6footer and am worried it will just consume all my free time so am doing as much planning as possible to reduce the maintenance effort.
afhtan
Postby frk27 » Tue 12 Apr, 2016 8:10 pm
I couldn't keep up with the dosing and all the maintenance involve in the zeovit system.( I am a very busy chef who doesn't see the day light very often and have also 2 young children)
Zeovit is very very good if you can spend the time dosing and changing the stone plus all the regular maintenance but if you skip a day or two you can quickly have a crash.I had a very good system until the day my zeovit reactor pump died and I didn't realise until a week after and he took me some time to replace it so after that the tank went down hill.
I took it as a learning curve but now I want to try something more natural and simple.
See how it goes.
frk27
Images: 88
Postby afhtan » Tue 12 Apr, 2016 9:44 pm
Thanks I am avoiding zeo on my tank too as it looked like too much work.
I'm sure this tank will be awesome as well.
Sent from my HTC_0P6B using Tapatalk
afhtan
Postby NewyReefer » Wed 13 Apr, 2016 7:53 am
Zeo isn't that bad when you get in a routine i was getting up in the morning making a coffee pump stones and ad some drops then same before bed once you get in the routine its just apart of your day.
You just need to keep a bit of a extra eye on the tank for changes thats all, and every 6 to 8 weeks when you're doing your regular maintenance just replace the stones aswell.
