This tank is in the planning phase only at this stage.
Plan is to use most/all the equipment that is on my 6x2. I didn't keep the old journal updated regularly (apparently not for a few years...
Part of the reason for the upgrade is; i have to move my existing tank from outside back to the main living area. Tank was moved outside while i carried out some renovations and never made its way back in. That was over 12months ago!
I plan a final update, if only a photo, of the current setup, prior to pulling it down. Anyway onto the future...
System Objectives: To create a living piece of reef that is a pleasure to look at and allows me to keep developing more knowledge of marine aquariums
System Type: Mixed Reef. Due at this stage to amount of soft livestock already on hand. Will eventually bias stocking towards SPS
Strike up Date: TBA. Hopefully get things started in next few weeks, possibly wet in Jan
Display Tank: 2100x750x550 Eurobraced. 'Opt-iclear' front and sides, 12mm all round
Display Lighting: PacSun Pandora 4x80W T5 + 4x 75W
Stand: Steel
Hood: Open top
Sump: Probably convert a 4ft tank, i have a few spare
Display Water circulation: 2x 6105's and 2x 6095's
Return Pump:peedy R3 8,000l
Skimmer: r: 170 cone Vertex
Evaporation Top Up:tunze auto
Calcium Addition: randy's
Alkilinity Addition: randy's
Other Chemical Maintenance: randy's
Current Water Chemistry: N/A
Coming..
