Cam's 6x2.5x2.5 (MoneyPit)
Postby cameronandorla » Thu 07 May, 2015 8:55 pm
Thought i should start a tank journal for the new tank so i can look back and reflect how it has all come together.
So been running a red sea max 250 for the past 18 months and over the past 6 months or so have been collecting a few bits and pieces to set up a bigger new tank.
The tank will be 6x2.5x2.5 running a corner weir the front and both sides are starfire glass. I will be building a custom stand to be clad in cabinetry which runs floor to ceiling. The aim it to make the tank look as if its built in to a wall without actually doing so.
On the equipment side of things i will be running
4 radion gen 2 pros
4 tunze 6105
2 ecotech mp40
Return pump royal exclusive rd3 4500 lph
Tunze ato
dosing pump and tank control will be trough a ghl proflux
Will be using nsw and am running a ro/di system for the auto top up.
Last edited by cameronandorla on Wed 27 Jan, 2016 11:15 pm, edited 3 times in total.
cameronandorla
Re: Cam's 6 footer
Postby cameronandorla » Thu 07 May, 2015 9:13 pm
The Tank has a starfire front and sides
The weir has 2x 40mm drains (one to be used as an emergency) and a 32mm return which is going to come across the top of the weir and run to the centre of the tank. This plumbing will be black and should hopefully blend in with the back of the tank once it is either painted black or vinyl wrapped. I plan on covering the weir in black plexi glass with the weir comb cut out.
I have also decided today that I will look into running a heat pump instead of a chiller
cameronandorla
Re: Cam's 6 footer
Postby cameronandorla » Thu 07 May, 2015 9:18 pm
My good mate Ant and his work mates welding up the stand for me. Going to have to remove the sliding glass door to get this one in we think.
cameronandorla
Re: Cam's 6 footer
Postby cameronandorla » Thu 14 May, 2015 10:38 pm
So my good mate Ant built me this stand. Been galvinised and powder coated. As the irish say "sure to be sure"
cameronandorla
Re: Cam's 6x2.5x2.5
Postby Amphibian » Fri 15 May, 2015 5:12 pm
looking good so far , :thumbsup:
what sump arrangement are you going for .
Dreambox 5x3x2 viewtopic.php?f=145&t=263224
Mixed Reef 8 x 2.6 x 2 Revamp in progress viewtopic.php?f=145&t=245064
Frag Tank 4 x 3 x 2 viewtopic.php?f=148&t=257402
Rebirth of a goodie900 x 900x450
viewtopic.php?f=148&t=253999
Amphibian
Re: Cam's 6x2.5x2.5
Postby cameronandorla » Fri 15 May, 2015 11:23 pm
That is the standard vebas sump I have. Will be more than enough to run a filter sock skimmer and a pellet reactor for the time being. The fuge section i am considering using at a ato reservoir
cameronandorla
Re: Cam's 6x2.5x2.5
Postby BlakeyBoyR » Fri 22 May, 2015 3:57 pm
Looks like it'll be a quality setup :)
I'm not addicted to Aquaria, I can quit any time I want ...
BlakeyBoyR
Re: Cam's 6x2.5x2.5
Postby cameronandorla » Sat 20 Jun, 2015 5:49 pm
Ok i have been a bit slack as of late but this weekend i have got around to sealing the marine ply and will be painint it tomorrow.
cameronandorla
Re: Cam's 6x2.5x2.5
Postby cameronandorla » Sat 27 Jun, 2015 3:23 pm
The beast is in place!
cameronandorla
Re: Cam's 6x2.5x2.5
Postby cossack_carl » Wed 22 Jul, 2015 2:35 pm
Great setup! I am looking at building a tank with the same dimensions. May I ask where you got the tank from and how much?
and any further progress? :)
cossack_carl
Re: Cam's 6x2.5x2.5
Postby cameronandorla » Fri 31 Jul, 2015 1:07 pm
No more progress sorry. Just got married and have been spending the last few weeks in far north qld and now fiji. Certainly have some inspiration to get this thing done when i get home
cameronandorla
Re: Cam's 6x2.5x2.5
Postby cameronandorla » Sun 16 Aug, 2015 9:37 pm
Just a quick update of the tank beginning to be clad
cameronandorla
Re: Cam's 6x2.5x2.5
Postby cameronandorla » Sun 30 Aug, 2015 5:50 pm
bottom cabinet finished complete with hidden door ar either end
cameronandorla
Re: Cam's 6x2.5x2.5 (MoneyPit)
Postby cameronandorla » Wed 27 Jan, 2016 11:27 pm
Been a while between updates.
The top hood has been sealed and painted and all cladding has been completed. In the attached pic I have began plumbing up the corner weir (I have raised the drain since the pic as it was causing a bit too much noise)
Test fill to check for any leaks in the plumbing.
I discovered at this point that the rd3 4500 would not always start, it starts intermittently, I will pull it apart and give it a good clean in the mean time I am using a jebao dc12000
cameronandorla
Postby cameronandorla » Wed 27 Jan, 2016 11:34 pm
Tank and stand complete (test fill ok)
decided I wanted a sps dominated tank so the tunze 9430 has been replaced with a deltec sc2060 with a vertex self cleaning head, I have also picked up a jns alpha reactor for nutrient control.
cameronandorla
Postby cameronandorla » Wed 27 Jan, 2016 11:41 pm
I picked up an 1200l IBC which was sold to me as food safe. It had a strong solvent smell so didn't trust it and replaced it with 2x1500l custom made food safe water tanks (all copper and brass has been removed) this also means that I will eventually be able to keep 2 cars in the garage. I decided not to plumb the tanks together but I can do this in the future if I feel the need.
cameronandorla
Postby cameronandorla » Wed 27 Jan, 2016 11:43 pm
The tank will eventually have 5x ecotech radion pro. I still have 2 over my rsm250 growing out some nice sps to transplant into this tank. Eventually I will remove one off the rsm250 and transfer it to the centre of the MoneyPit once the cycle is completed.
I have also glued on the custom acrylic weir covers to hide all the plumbing.
Last edited by cameronandorla on Thu 28 Jan, 2016 12:07 am, edited 1 time in total.
cameronandorla
Postby cameronandorla » Wed 27 Jan, 2016 11:46 pm
This is the power setup I will be running (I really should have got the 3x PDUs as Chromus said) I am already running out of switches. Lucky I have 8 extra powerpoints put into the wall.
I have also added a18mm hose fitting to the return for easy water changes. That missing switch cover is also driving me crazy, I need to find it this weekend.
Last edited by cameronandorla on Thu 28 Jan, 2016 12:08 am, edited 1 time in total.
cameronandorla
Postby cameronandorla » Wed 27 Jan, 2016 11:49 pm
On the weekend I started the scape. I have used 4x boxes of the Caribsea SouthSea base rock (100kg) as well as a few nice large bits of plating base rock. The scape has been drilled and reinforced with acrylic rods as well as some of the tunze coral putty/kz cement/vertex putty.
The scape was by far the most difficult job yet and took almost a full day. I have added approximately 30kg of crushed coral sand as well.
Radions running at 60% with no water
cameronandorla
Postby cameronandorla » Thu 28 Jan, 2016 12:05 am
Started to run all the cables for the equipment. The Tunze 6155 mounts proved to be quite challenging to mount on the back glass but got there in the end by hanging them with some fishing line.
some of the equipment has changed, I am now going to run:
5x Ecotech Radion gen 2 pro
2x Ecotech MP40w
1x Ecotech Vectra L1(has 3x the power of the jebao dc12000)
2x Tunze 6155
1x Tunze Multi controller
1x Deltec Sc2060
1x JNS alpha 2
1x Tunze Osmalator
Still need to put the GHL and the GHL dosing pump
A few more cable ties should clean up the wiring a bit
cameronandorla
Postby Gats » Thu 28 Jan, 2016 3:14 pm
Love the scape. Brilliant!
Newbie 1st tanker.. fast learner...
Gats
Postby h111x222y333 » Tue 08 Mar, 2016 3:12 pm
Hi Mate, where you got that individual switched PDU from, and how much? Never seen that before.....
h111x222y333
Postby chromus » Tue 08 Mar, 2016 3:37 pm
We got them in a MASWA grp buy a few years back
Postby swazzle » Tue 08 Mar, 2016 10:06 pm
This is awesome
Watching the progress mate, some serious time effort and $$$ put in! Can't wait to see it wet
swazzle
Postby h111x222y333 » Wed 09 Mar, 2016 4:49 pm
chromus wrote:We got them in a MASWA grp buy a few years back
Still in Australia? or from other contury? Any company name or contact?
h111x222y333
Postby cameronandorla » Sat 12 Mar, 2016 6:36 pm
Picked up this 2nd hand acrylic sump today with built in fuge, sitting in the skimmer compartment is a skimz cm202 calcium reactor rated up to 2,500l
Tank is now running a haliea hc-1000a chiller (the chiller will be moved outside in the coming weeks as the temps in the tank were getting up to 28 degrees)
The tank has now cycled and have started to add a few frags to the tank. Got this awesome natural looking magnetic reef shelf about 2 weeks ago
cameronandorla
Postby cameronandorla » Sat 02 Apr, 2016 12:40 am
have bit the bullet and invested in an achelles tang, a sail fin and a purple tang. using the display to quarantine the new comers. have also added a few symphillea wilsoni, acans and a stunning acro al clam. pics to come this weekend.
cameronandorla
Postby cameronandorla » Fri 28 Oct, 2016 6:34 pm
cameronandorla
Postby Vilante » Fri 28 Oct, 2016 7:12 pm
Looking superb!
Vilante
Postby ratzy » Sun 13 Nov, 2016 11:53 pm
Hey mate, how have you gone with the 5 lights? Im currently setting up a 6x2x2 and I was going with xr30 pros (gen3). From all reports I only need 3, was considering 4 but people been taking me out of it and to stick to 3, so just curious why you went 5 and how you've found it.
Looks great either way,
ratzy
