Nathan's Starfire Stick box 6ft TOTY 2014
Re: Nathan's Starfire Stick box 6ft TOTY 2014
Postby ssscuz » Sat 02 Jul, 2016 1:00 pm
A few pics from today. Tank is seemingly stable at the moment. Vodka/vinegar dosing is doing well to keep nutrients low. Carx is stable and helping Witt growth.
Postby Vilante » Sat 02 Jul, 2016 1:10 pm
Beautiful!
Vilante
MASS Member
Postby Rod the Reefer » Sat 02 Jul, 2016 7:04 pm
Looking good Nathan.
Postby aidanmary » Sat 02 Jul, 2016 10:52 pm
Looking good as always Nath
aidanmary
Postby azheaz » Wed 06 Jul, 2016 2:03 pm
Hi Nathan, just wondering if you're still dosing lanthanum to reduce PO4? If so, how do you remove the flocculent? Do you find this better than using GFO?
Thanks :thumbsup:
azheaz
Postby ssscuz » Wed 06 Jul, 2016 11:19 pm
Thanks all.
Yes still using the lanth (50:50) mix. Dosing straight into the sump.
It seems a lot more consistent than gfo, you can just keep dosing the same amount daily with the same feedings and phos stays fairly stable. The vodka and vinegar will be bringing some phos down also
Postby aidanmary » Wed 06 Jul, 2016 11:40 pm
What sort of benefits do you seeing using vodka and vinegar together?
I'm dosing vinegar on its own and it does bring the nitrate down but I'm seeing a bit of a cyano problem which has started to go away but only due to shortening the photo period I think. not sure if the vinegar has got anything to do with it.
aidanmary
Postby afhtan » Thu 07 Jul, 2016 1:16 am
Good to hear the lanth is working out well directly in the sump.
I might try it out when the gfo runs out.
Sent from my HTC_0P6B using Tapatalk
afhtan
Postby ssscuz » Thu 07 Jul, 2016 8:48 am
aidanmary wrote:What sort of benefits do you seeing using vodka and vinegar together?
I was hoping it would help keep the bacteria in multiple strains. I read that plain vodka dosing can cause a mono strain and prevent the nitrogen cycle happening. I have no proof it works, I do dose the continuum bacteria at 4ml a day aswell, so that may help with bacteria population.
afhtan wrote:Good to hear the lanth is working out well directly in the sump.
Just make sure you dilute the lanth down a lot, I used a 50:50 mix but that is still fairly strong. Start really slow, and do that for a week or more then up it. Lanth can be brutal and just strip all the phos out real fast which I found a lot of sps don't like
Postby azheaz » Thu 07 Jul, 2016 10:07 am
Good to see lanth is working for you Nathan! So from what I understand, you don't try and trap/remove the white flocculent? How much do you dose each day of your 50:50 mix? From what I've read people say it can kill tangs because the flocculent clogs their gills.
azheaz
Postby aidanmary » Thu 07 Jul, 2016 9:40 pm
Once they get the probiotic range in over the next few months I might start using the aquaforest bacteria and carbon dosing range which is supposed to sustain low nutrients. going to start of by trying some of there supplements and salt first and see how the quality is. a lot of nice looking tanks over seas using there products. apparently they are giving zeovit a run for there money.
aidanmary
Postby angel101 » Fri 08 Jul, 2016 2:32 am
Looking superb Nathan, it's a real credit to you!
I live in my own little world. But it's OK. They know me here.
angel101
Postby ssscuz » Fri 08 Jul, 2016 10:19 am
azheaz wrote:Good to see lanth is working for you Nathan! So from what I understand, you don't try and trap/remove the white flocculent? How much do you dose each day of your 50:50 mix? From what I've read people say it can kill tangs because the flocculent clogs their gills.
I'm currently dosing 3ml a day of 50% lanth and 50% ro.
I haven't had any trouble with the tangs so far.
aidanmary wrote:Once they get the probiotic range in over the next few months I might start using the aquaforest bacteria and carbon dosing range which is supposed to sustain low nutrients. going to start of by trying some of there supplements and salt first and see how the quality is. a lot of nice looking tanks over seas using there products. apparently they are giving zeovit a run for there money.
Yeah apparently their range is very good! Id like to see some Aussie tanks running it before I get to excited by it all tho.
Postby aidanmary » Fri 08 Jul, 2016 6:54 pm
yeah im really only looking to run some of there supps and salt. not interested in dosing half a dozen bottles every day that's for sure plus I don't have any of the awesomely colored sps like they do in there tanks so no point lol
aidanmary
Postby pyroay » Tue 12 Jul, 2016 9:39 am
I love seeing a really nice leather coral included in the set-up. So many tanks are all SPS which is great but i think some of the soft corals are underated.
10x4 Mixed Reef
10x4 Predator Tank - Back up and running.
Sustainable reefing with 100% of power consumption offset by Solar
pyroay
Postby Rod the Reefer » Wed 13 Jul, 2016 5:44 pm
That is a particularly nice one.
Postby ssscuz » Mon 18 Jul, 2016 2:41 pm
Rod the Reefer wrote:That is a particularly nice one.
Here's another nice one rod.... Came from a tops bloke in SA! Recognise it?
pyroay wrote:I love seeing a really nice leather coral included in the set-up. So many tanks are all SPS which is great but i think some of the soft corals are underated.
I'm trying to steer towards the mixed reef again. Lost site of it quite a while ago. Definitely makes it more impressive when you can see the flow in the tank moving corals around
Fts after glass clean
Postby ssscuz » Fri 20 Jan, 2017 8:20 pm
So it's been a long time since an update.
Tank seems to have been running fairly smoothly for about 3 months. Haven't had time for maintenance so leaving it alone has been good for it.
Should have triton test results soon. Might help explain the cyano which comes and go
Favourite view of the tank is this at the moment. It's grown out really well down this end of the tank
Fts
Frag tank is a bit wild
Top downs are so hard with iPhone and t5
This was a bargain at lfs $20
Stag at the water surface now
Frags from masov people
Postby wayne2.0 » Sat 21 Jan, 2017 2:53 pm
Stunning
wayne2.0
MASQ Committee
