Nathan's Starfire Stick box 6ft TOTY 2014
Re: Nathan's Starfire Stick box 6ft x 2.5ft x 20
Postby ryanrid » Wed 14 Aug, 2013 9:42 pm
ssscuz wrote:
ryanrid wrote:very cool, nice dimensions :clap:
Thanks mate id love to take credit but this tank has been around the bush, the first owners choice for size. A great one though!
coral1 wrote:i really like the sump design :clap: :clap: :clap: :clap:
Hopefully it all works out to plans
Here's the back side of the sump thommo
I think it will make more sense now
Priced up some cabinet doors tonight. Almost fell over
Yeah but you get credit for being smart enough to buy it :devil:
Postby ssscuz » Thu 15 Aug, 2013 7:42 am
Ha ha yeah Ryan it was a great pickup!
What are people's thoughts with my return pump, will a 5000lph be enough for return and 1 rowa reactor? Or should I get another pump to run the reactor and whatever else I end up running?
Postby Ben S » Thu 15 Aug, 2013 8:21 am
How big is the rowa reactor?
Will it be rowaphos you will be running or se other kind of media? I ask because some media works better if the flow through it is slower so you maybe ok with the return pump powering the return and reactor.
Ben
Ben S
Postby damer » Thu 15 Aug, 2013 9:02 am
Mate I've got a spare wave line 10000 sitting in with my other stuff. I'm going to use it in the new growout/larvae system but you are more the welcome to borrow it to have a play with the flow rates.
Damien's 1300 x 1200 x 600
damer
Postby ssscuz » Thu 15 Aug, 2013 10:39 am
Thanks for the replies,
The rowa reactor is just a small 2litre or so reactor. I normally only use it if I have phos issues. It's only about 400lph thru it.
I just ask as I use my 5000lph on the current setup to run the chiller, return And reactor. The flow is still high back to dt. So if I remove the chiller it should do it??
Damer, I might have to take u up on that offer!
Postby Thommo01 » Thu 15 Aug, 2013 11:13 am
Ah. That sunp picture makes more sense. All good then :thumbsup:
Actually how is the fuge flow happening? By the looks of it the fuge level will never go higher than the filter sock outlet so it wont get any flow. If you are thinking of using valves I'd be a bit hesitant trying to control a level with a valve.
Sorry if I have missed anything else. Just hate wet floors, so better to ask.
Postby ssscuz » Thu 15 Aug, 2013 1:02 pm
Yeah I was going to use a valve but am a bit scared to. Maybe I just tee a line off the return to feed the fuge a bit and have to second bulkhead there just incase the level rises.
Postby Thommo01 » Thu 15 Aug, 2013 3:30 pm
You could put a bulkhead in the fuge around the same height or a bit lower than the filter sock bulkhead and then control the flow with an outlet valve. Then have the other bulkhead on the fuge as overflow protection.
Postby Thommo01 » Thu 15 Aug, 2013 3:36 pm
You could put a bulkhead in the fuge around the same height or a bit lower than the filter sock bulkhead and then control the flow with an outlet valve. Then have the other bulkhead on the fuge as overflow protection. Or forget the connection from the socks to the fuge and just tap off from the tank overflow and control flow to the fuge with a valve. Then whatever flows into the fuge can just head over into the next sump section via the bulkhead. No need for extra bulkheads and you can then have a larger water volume in the fuge. Still have sock blockage protection then as if overflow it goes into the fuge and over into the next sump area. Hope that makes sense.
Postby Ilona » Thu 15 Aug, 2013 6:30 pm
What, 3 pages and still not wet?! :sleepy:
Totally jealous, still think you can fit bigger in though :poke:
Ilona
Postby ssscuz » Fri 16 Aug, 2013 12:12 am
Yeah that's a good point thommo. I might be able to make that happen.
I'll have to draw up some more sketchups.
I did have an idea to use the 3ft I have as the filter sock and fuge area and just buy a two foot tank for ro.
It will give me more water volume than the other 4ft to.
Hopefully the skimmer turns up tomorrow so I can see how big that is all made up to. Worried its going to be huge and not fit in the sump section.
I know ilona it's a slow process. And I don't think I could fit any bigger. This thing already looks huge
Postby cody.sheridan-2008 » Fri 16 Aug, 2013 3:08 pm
Looks great, tagging along :)
Postby ssscuz » Fri 16 Aug, 2013 5:36 pm
Don't u love when the courier turns up with reefing goodies.
This thing is...... Just wow!
Just fits between the baffles
Postby cody.sheridan-2008 » Fri 16 Aug, 2013 5:52 pm
It will truly skim the [censored] out of your tank no doubt!
Postby coral1 » Sat 17 Aug, 2013 9:13 am
very nice Nathan i would love one :-x but bit pricey for my tank :(
Renae
MASOV 2015-2016 president
Image[/image]
viewtopic.php?f=145&t=241394
viewtopic.php?f=145&t=162492
coral1
Postby ssscuz » Sun 18 Aug, 2013 9:11 pm
cody.sheridan-2008 wrote:It will truly skim the [censored] out of your tank no doubt!
Yeah it's rated quite a bit higher than my total system so should be good.
coral1 wrote:very nice Nathan i would love one :-x but bit pricey for my tank :(
The 300 should do your tank Renae, not a heap bit of gear brand new though
Postby ssscuz » Sun 18 Aug, 2013 9:14 pm
Here's my weekend endeavours
Decided that the garbage bin to mix salt just wasn't going to cut it. Here's my mixing station, it's not a new concept and I have copied the design from a heap of people in the states.
Tanks now on the stand in the garage
Postby Thommo01 » Mon 19 Aug, 2013 11:16 am
Thats a handy set-up. Well done. Will make life a lot easier when it comes to tank husbandry. Always a positive when the tank is easier to look after imo.
Postby Bandit » Mon 19 Aug, 2013 11:20 am
I thought you were going NSW :devil:
Bandit
Images: 44
Postby ssscuz » Mon 19 Aug, 2013 1:06 pm
I was Jamie till I worked it and its going to cost almost the same by the time delivery etc.
I'm
Having good results with asw so why change it to
Postby ssscuz » Sun 25 Aug, 2013 9:07 pm
Here's a few on the stand. Should
Have doors and cabinets by the end of the week. Just need to pull my finger out and finish sumps etc
Postby timmeh1 » Tue 27 Aug, 2013 9:41 pm
This is looking awesome Nathan! Looks like it will be wet soon :thumbsup:
timmeh1
Images: 6
Postby ssscuz » Tue 27 Aug, 2013 10:38 pm
timmeh1 wrote:This is looking awesome Nathan! Looks like it will be wet soon :thumbsup:
Yeah it's coming along nicely. Pretty much finished the 4ft sump, just need to sort out the smaller sump behind
Postby pilonstar » Tue 27 Aug, 2013 11:01 pm
supa coolio!
nice idea BTW :cheers:
The irony: removing all the nutrients, only to add them all back as high priced supplements.
Live stream tank http://www.erickmiranda.com
pilonstar
Postby sparker » Wed 28 Aug, 2013 12:07 pm
^^^EPIC reply^^^^
sparker
Postby ssscuz » Wed 28 Aug, 2013 7:36 pm
There's always a comedian!! Ha ha very good
Postby topogigio82 » Wed 28 Aug, 2013 9:01 pm
That is a nice looking metal stand, if i could ask did you just paint it with normal black paint? Or did you do more than that? I will be getting a metal stand myself and I do want it to last.
topogigio82
Postby ssscuz » Wed 28 Aug, 2013 9:19 pm
topogigio82 wrote:That is a nice looking metal stand, if i could ask did you just paint it with normal black paint? Or did you do more than that? I will be getting a metal stand myself and I do want it to last.
It's gal steel so didn't really need painting. But I didn't like the colour so I used gal primer two coats and then 4 coats black on the top.
If your getting a mild steel stand id suggest getting t powder coated so it lasts
Postby Thommo01 » Wed 28 Aug, 2013 9:32 pm
:roflmao: Good call. :roflmao:
Postby topogigio82 » Thu 29 Aug, 2013 4:44 pm
thanks... as to galvinising not rusting, i was under the impression (now apparently wrongly) it would rust, albeit not as quickly
topogigio82
