Nathan's Starfire Stick box 6ft TOTY 2014
Re: Nathan's Starfire Stick box 6ft x 2.5ft x 20
Postby ssscuz » Sat 10 Aug, 2013 10:52 pm
Thanks chromus.
Very valid point, we were all a bit sceptical but We tested it out, flexes about 20mm with 100kg on it. I'm hoping any light I have and cabinetry will not weigh more than that. I could add some bolt on corner braces if I have issues.
Postby chromus » Sat 10 Aug, 2013 10:58 pm
Nice, my ATI Hybrids are 22Kg each so I am watching for ways to mount them.
Postby Thommo01 » Sun 11 Aug, 2013 12:23 am
Great job with the stand so far. What are your plans when finished? Paint, powder, leave as is?
Postby ssscuz » Sun 11 Aug, 2013 12:29 am
chromus wrote:Nice, my ATI Hybrids are 22Kg each so I am watching for ways to mount them.
If u make the bracket fixed it would hold more chromus. Mine flexes because of the adjustable height. I'm not sure how tall I want to have the hood or how much room I will need between the glass and the steel to get in there.
Thommo01 wrote:Great job with the stand so far. What are your plans when finished? Paint, powder, leave as is?
My father in law thinks it will only need undercoat on the welds, I think I'll undercoat and paint it. Being gal I don't see the need for powder coating.
Postby Thommo01 » Sun 11 Aug, 2013 1:15 am
That was why I was asking. More only needs painting or coating for looks really. If you aren't fussed just some gal spray on the welds is good enough.
Only reason to paint it is if you don't like looking at Galv when you open the cabinet doors.
Postby ssscuz » Sun 11 Aug, 2013 4:29 pm
Well here's today's progress, 5 hours welding and grinding.
Not to bad for a amateur!
Got it home safe, u better be scared damer and Jamie, this is getting close to getting wet.
I took thommos idea and painted it, well started to.
Postby Thommo01 » Sun 11 Aug, 2013 6:19 pm
Yeh! Looks slicker in black. :nod:
Postby chromus » Sun 11 Aug, 2013 6:32 pm
Postby damer » Mon 12 Aug, 2013 10:11 am
Nice mate, and a very nice shed.
Damien's 1300 x 1200 x 600
damer
Postby ssscuz » Mon 12 Aug, 2013 1:12 pm
Agreed the black was a far better choice, lucky I get it from work.
damer wrote:Nice mate, and a very nice shed.
Thanks mate, it's very full at the moment. Can't even get my car into a 4car garage! To much reefing junk
Postby Rod the Reefer » Mon 12 Aug, 2013 2:15 pm
The heat is on. :pirate:
Postby gazman33 » Tue 13 Aug, 2013 1:03 pm
Mate it's looking pretty awesome already! How's the sump/s coming along? Also it looks like your going no hood ;) :thumbsup: let me know if you ever need a hand mate :cheers:
gazman33
Postby ssscuz » Tue 13 Aug, 2013 1:15 pm
Rod the Reefer wrote:The heat is on. :pirate:
I think the race is over rod. I'll definitely have water in it before the other two! Might even have all the fish in before Jamie gets water in his
gazman33 wrote:Mate it's looking pretty awesome already! How's the sump/s coming along? Also it looks like your going no hood ;) :thumbsup: let me know if you ever need a hand mate :cheers:
Nah having a hood mate, just didn't want it sitting on the tank so the frame can hold it
Postby damer » Tue 13 Aug, 2013 2:40 pm
:wall: :wall: :roflmao:
damer
Postby Rod the Reefer » Tue 13 Aug, 2013 3:23 pm
Yeah, Jamie is all talk. :devil:
Postby ssscuz » Tue 13 Aug, 2013 7:29 pm
Here's today's efforts.
Finished off the painting
Also think I have teed up some free malemine sheeting in white, so I think I'll be running a sheet in the bottom for sump, one under tank and then one on the back of the stand. Not sure if I want to run the hole in the centre section again or if I want to just cut holes for the pipes to come thru.
I think the idea of an electrical cupboard at one end is a good idea to. Keep the water away from electricals
Postby ssscuz » Tue 13 Aug, 2013 8:17 pm
ok i think i have sorted the sump design out.
Critique people.
Postby chromus » Tue 13 Aug, 2013 8:22 pm
Appears to be missing a front wall :poke: :spit:
The pumps and skimmer dont seem to match the scale so might be giving false sense of how much space u need.
Postby ssscuz » Tue 13 Aug, 2013 8:40 pm
chromus wrote:Appears to be missing a front wall :poke: :spit:
Arr knew I was missing something ha ha. :konk:
The skimmer was just a model I downloaded so I'll see once the skimmer comes how big it is. The footprint on the web says
18½" x 13" . So I'm hoping that the 1/2 isn't really there so I can fit it in the sump.
For all those playing along at home it's a vertex 250.
Postby Thommo01 » Tue 13 Aug, 2013 8:43 pm
Nice sketch-up work there! What are you planning for the top 2 rhs areas and what is the plan with the bottom lhs? Like your inlet section :thumbsup:
Postby ssscuz » Tue 13 Aug, 2013 8:54 pm
Top middle is the refugium. Top right hand side is ro reservoir, should hold 70-80 litres.
The theory is I can have the inlet section overflow after the filter socks into the frag section, I'll put a tap on that so I can allow some flow to go thru the fuge. The return from fuge will still go to the fuge section though
I want to stop all snails from getting into the frag/skim/return sections
Postby happy1 » Tue 13 Aug, 2013 9:45 pm
looking good :thumbsup:
happy1
Postby galleri3090 » Wed 14 Aug, 2013 11:11 am
Quality build, Nathan :o
I look forward to watching it develop, man.
Michael
galleri3090
Postby gazman33 » Wed 14 Aug, 2013 12:01 pm
Hey mate with the fuge Im trying to understand (probably way out to :konk: ) I see that the water is supposed to go through the socks then under the baffle between the sock section and fuge but then where is it going? Also are you going to have an emergency overflow from the filter sock section to the frag section? Just wondering because if a few snail do get into that valve and block it/slow it up you might have a puddle on your hands :o looking good but mate you got that stand done quick as! Watching this makes me want to do another build lol :devil:
gazman33
Postby Thommo01 » Wed 14 Aug, 2013 3:35 pm
Looks good to me. Good point about the sock area. For me it looks like if the socks block totally up(for some reason) the water will keep filling until it goes on the floor. Possibly drop the fuge wier lower in height(20mm or so) and then you can use the Fuge drain as a back up? Or put another back-up line in ontop of your filter sock area.
Postby ssscuz » Wed 14 Aug, 2013 4:18 pm
I'll put a better orientation up tonight. The divider near the fuge doesn't go to the bottom of the tank. It will go into the first chamber, flow over to the filter socks then go under the next partition into the weir. Where the fuge has a 25mm bulkhead also to stop the flood
Postby ryanrid » Wed 14 Aug, 2013 4:23 pm
very cool, nice dimensions :clap:
Postby coral1 » Wed 14 Aug, 2013 5:09 pm
i really like the sump design :clap: :clap: :clap: :clap:
Renae
MASOV 2015-2016 president
Image[/image]
viewtopic.php?f=145&t=241394
viewtopic.php?f=145&t=162492
coral1
Postby Thommo01 » Wed 14 Aug, 2013 6:54 pm
So what happens if your filter socks are blocked and the water fills up that section?
Postby ssscuz » Wed 14 Aug, 2013 9:27 pm
ryanrid wrote:very cool, nice dimensions :clap:
Thanks mate id love to take credit but this tank has been around the bush, the first owners choice for size. A great one though!
coral1 wrote:i really like the sump design :clap: :clap: :clap: :clap:
Hopefully it all works out to plans
Here's the back side of the sump thommo
I think it will make more sense now
Priced up some cabinet doors tonight. Almost fell over
Users browsing this forum: No registered users and 13 guests
