After getting the offer of a lifetime from Brett (gwithian). I will be starting up a new tank, the old tank will be torn down and this one will replace. I have had ups and downs with the last tank. I am hoping this time around it will be easier and that I can put the knowledge that I have learnt over the last year and a half.
System Objectives: I said mixed reef last time and turned into a fairly SPS driven setup, this time I hope I can keep sps with some fish that I just couldn’t have in the 4fter.
System Type: SPS dominated, Mixed Reef
Strike up Date: 15th September 2013
Display Tank: 6ft x 2.5ft x 20” full starfire viewing and rear overflow.
Display Lighting: Ati powermodule 10 x 80w
Stand: Steel
Hood: Steel frame with melamine doors
Sump: 1200 x 800, three partitions with in built frag tank
Refugium: section in sump
Refugium Lighting: DIY Led/t5 hybrid
System Water: ASW red sea blue bucket
Display Water circulation: 2 vortech mp40w back wall and maxspect gyre xf130. Mp10 will be used in the frag section
Return Pump: Royal exclusive speedy 75w
Skimmer: vertex 250
Evaporation Top Up: avast marine peristaltic pump, controlled by apex, pumped from the garage
Other Goodies
Geo 818 carx with marine sources add on chamber
Diy led/4x24w t5 for frag tank
De bary 25w uv sterilizer
Calcium, alkalinity and magnesium Addition: calcium reactor, coral bones
Other Chemical Maintenance: vodka/vinegar for carbon dosing, lanth for phosphate
Nitrates: 0.00ppm
Phosphates: 0.03ppm
Alkalinity: 8.0dkh
Calcium: 400ppm
Magnesuim: 1240 ppm
Fts
20/8/16
14/5/16
1/7/15
12/04/15
17/2/15
28/9/14
4/8/14
1/6/14
1/5/14
26/4/14
1/4/14
3/3/14
26/12/13
7/12/13
16/11/13
Heres the baby, previously Brett's(gwithian) and pre that Scotto's
Sump plans
Stand that should be built this weekend
sump 1
