Glynn's new tank build 6 x 2.5 x 2.5
Postby Adwiner » Thu 11 Apr, 2013 1:26 pm
Hi guys,
Thanks to everyone for your support over the past few weeks. I am a new member and I am upgrading my tank already. You guys have inspired me.
With my new build I would appreciate any comments and suggestions people might have from their own experiences.
System Type:Mixed Reef
Display System: 6 x 2.5 x 2.5 (1000L)
Strike up Date: April 2013
Display Lighting: Radions x 3
Stand: Steel stand which I have re-enforced to the max and painted
Wooden black hood
Sump: 3 x 1.5 x 1.5
Refugium Lighting: none
Display Water circulation: 2 x jebao powerheads and Vortech Mp40
Return Pump: HQB 4500L
Skimmer: Bubble Magnus Bubble BM-NAC220-CS Cone
Heating: 2 x 300w Eheim Jäger
Chiller: ?
Evaporation Top Up:Auto topup, gravity fed by ball valve
Calcium Addition: Randys
Alkilinity Addition: Randy's
Other Chemical Maintenance: Randy's
Current Residents:
Blue tang
Two bar rabbitfish
Cleaner wrasse
Flamehawk
Swallowtail angel
2 x green citron gobies
Purple firefish
1 x Ocellaris Clownfish
1 x Yellow Coris Wrasse
3 x Blue/Green Chromis
4 x Dispar Anthias (1 male & 3 females)
1 Lyretail anthia
Nitrates: 0
Phosphates: 0
Alkalinity: 9
Calcium: 390
Magnesuim: 1280
Glynn's 6 x 2.5 x 2.5 build
viewtopic.php?f=145&t=249338
Adwiner
Re: Glynn's new tank build 6 x 2.5 x 3
Postby Adwiner » Thu 11 Apr, 2013 1:27 pm
Adwiner
Postby Adwiner » Thu 11 Apr, 2013 1:31 pm
Could I please get people's thoughts on:
Size of sump - bearing in mind if I put the sump on the stand I only have 22" high for the skimmer. Or it might have to be joining sumps on the floor.
Lighting- will definitely want LED's but want advice for a 36" deep tank. Could you please give me advice on what light you would choose for $500 and below and $1000 and below to light the whole tank.
Thanks heaps everyone
Adwiner
Postby priscacara » Thu 11 Apr, 2013 1:43 pm
Stand looks great Glynn! Unfortunately I'm still a novice so not much use to you on sumps and leds.
Postby Adwiner » Thu 11 Apr, 2013 4:59 pm
Thanks priscacara, just finished painting it. Will have doors eventually
Stand painted by Adwiner, on Flickr
Adwiner
Postby pazz » Thu 11 Apr, 2013 8:20 pm
lighting is going to cost a bit mate if it was 3 wide and 2.5 high it would of been cheaper .
pazz
Postby Adwiner » Fri 12 Apr, 2013 12:56 am
Totally agree Pazz, what would u recommend for a 3ft deep tank ?
Adwiner
Postby saltymike » Fri 12 Apr, 2013 10:14 am
Is the tank made yet, is it to late to go 2-2.5 high?
Mike
Mike and Tina's AR400 Tank Journal link below
http://masa.asn.au/phpBB3/viewtopic.php?f=148&t=243993
saltymike
Postby Adwiner » Fri 12 Apr, 2013 3:21 pm
Yeah it is Mike, I'm buying it off a fellow MASWA member, it's new though
Adwiner
Postby saltymike » Fri 12 Apr, 2013 11:51 pm
Oh ok mate. I'm not positive which LEDs you could use to get good par on the bottom and still stay under your budget?
There's AMB and Daluss LEDs which are decently priced and powerful but they lack controllability and are 50/50 blue white
High end LEDs will cost enough to make getting a new 6x3x2 made and youd still be in front lol.
Mike
saltymike
Postby Adwiner » Sat 13 Apr, 2013 3:00 pm
Haha Thanks Mike. It is a difficult one. Would T5's reach?
Adwiner
Postby Adwiner » Sat 13 Apr, 2013 3:02 pm
Tank is here. Thanks to MASWA for the suction cups. It made the job a lot easier. Still a bloody heavy tank with thick glass.
New tank is here. by Adwiner, on Flickr
Adwiner
Postby saltymike » Sat 13 Apr, 2013 5:02 pm
Looking at the tank in the background the led is a bit above the height if the new tank and the base of the little tank is lower than the big tank (that's by lining up the brick courses) so you could be lucky and use LEDs like what you have only it'll be a lot closer to the water surface ?
Mike
saltymike
Postby Adwiner » Sat 13 Apr, 2013 11:22 pm
That sounds good Mike. The tank has high sides for mountin as well.
Nice tank you have as well. Think I will be getting a school of Anthias too. They are really nice.
Adwiner
Postby saltymike » Sun 14 Apr, 2013 2:19 am
Yeah you could be lucky mate and just go with another of the leds you've got now.
Thanks I'm really enjoying my tank and my Dispar's. I love watching schooling fish swim together. Get to set up my LEDs tomorrow myself.
Mike
saltymike
Postby Adwiner » Sun 14 Apr, 2013 3:18 pm
Good luck Mike with the led setup. What light did you go with?
Adwiner
Postby saltymike » Mon 15 Apr, 2013 4:24 pm
LED = Pacific Sun Metis Hyperion R2
was a bit tricky setting up the programming as its blue tooth controlled and i'm not overly computer savvy with firmware installations etc but got it sussed (with my Bro-in law doing all the computer work lol) at about 11pm last night lol.
i'll post some pics in my TJ tonight.
Mike
saltymike
Postby Adwiner » Thu 18 Apr, 2013 12:24 am
Sounds brill thanks Mike
Adwiner
Postby Adwiner » Sun 21 Apr, 2013 11:23 am
Adwiner
Postby Adwiner » Sun 21 Apr, 2013 11:30 am
You may notice the tank is now in a different spot. The wife said it wasn't practical where it was for having guests round. I guess she had a point :)
Sump has now been ordered. Unfortunately I have had to go for 2 x identical cube sumps jointed by two holes. This is due to not enough room in the stand to fit the skimmer. The skimmer height changed the whole original design.
Sump design by Adwiner, on Flickr
Adwiner
Postby Adwiner » Sun 19 May, 2013 5:15 pm
Sand and some base rock aquascaping done :). Slowly getting there, still waiting on sump and then I can plumb it.
image by Adwiner, on Flickr
Adwiner
Postby Adwiner » Tue 28 May, 2013 2:45 pm
Adwiner
Postby priscacara » Sat 08 Jun, 2013 12:06 pm
Looking good with the large bommie, great size tank but I would need floaties to get in and clean something that size :-) .
Postby Adwiner » Sat 08 Jun, 2013 7:25 pm
Haha yes it is a challenge to clean. It's full now and is cycling. Must have had die off an I have nitrite now.
Adwiner
Postby Adwiner » Thu 13 Jun, 2013 9:05 pm
Still cycling, but not far off done. Shame I can't put fish in yet but I could get corals sorted once phosphates come down.
Adwiner
Postby Adwiner » Sat 22 Jun, 2013 9:26 pm
Left side of tank by Adwiner, on Flickr
Right side of tank by Adwiner, on Flickr
Full tank by Adwiner, on Flickr
Update shots
Adwiner
Re: Glynn's new tank build 6 x 2.5 x 2.5
Postby Adwiner » Mon 02 Sep, 2013 10:25 pm
Some updated photos of the corals in the tank. Tri colour courtesy of Brett. :)
Adwiner
Postby Adwiner » Mon 02 Sep, 2013 10:27 pm
Adwiner
Postby Adwiner » Mon 02 Sep, 2013 10:36 pm
Adwiner
Postby some_one » Mon 02 Sep, 2013 10:45 pm
Looking good Glynn :thumbsup:
Good to see the Tri colour is nice and happy :)
Brett
From WA, join MASWA!!
some_one
