I currently have a 5x2x2.5 lps reef up and running, but my lovely wife and the wisdom to try and clean it with an old magnet glass cleaner that I thought was thrown out years ago, and scratched it pretty bad.
Plus I have always regretted not getting a bigger tank to begin with, but I was not in the financial position to do so at the time.
It is also running on two Fluval FX5s, and a Tunze HOB skimmer which are a pain to maintain and keep clean enough to keep the water chemistry in check, so i am looking forward to the benefits that come from having a large sump, and refugium setup.
The new tank will be replacing my 5ft, and so I don’t have to worry about moving it, my new tank will be made into a room divider, with three viewable sides, and all my current livestock will be transported over when the time is right.
System Objectives: Happy healthy creatures
System Type: Mixed Reef - Primarily LPS
Strike up Date: TBA - possibly June/July 2012 if I get sorted
Display Tank: 2000L x 760W x 760H mm. Cross and euro braced. (Dennison @ Maryanne's Aquarium)
Display Lighting: x12 PAR38 LED lights from EcoXotic or Ledtric. (8 already on original tank)
Stand: Powder Coated Steel, with white laminated panels all round, held with magnets and clips. 2000mm x 760mm x 1050mm
Hood: Open top, but with DIY aluminium frame, again with white laminated panels (to match the kitchen) all round, held with magnets and clips. 2000mm x 800mm x 400mm
Sump: 1200 x 600 x 450 Sump (Dennison @ Maryanne's Aquarium)
System Water: Natural sea water
Top up Water: Own RO/DI unit
Display Water circulation: 2 x Vortech MP60WES at this stage
Return Pump: RLSS 10000LPH DC Controllable Pump
Skimmer: RLSS (Reef Life Support Systems) R8-i Protein Skimmer
Chemical Support :
Carbon Filtering: Via 2L Fluid bed filter
Bio Pellets: Via 2L Fluid bed filter
Calcium Addition: Via dosing pump
Iodine Addition: Via dosing pump
Magnesium Addition: Via dosing pump
Other Chemical Maintenance: N/A at this stage
Current Tank Side View!
Current Tank Front View! (Looks way better in real life.)
Favorite Coral
XLarge Duncan
Some of my existing stock.....
More To Come...........
