Wazza & Chantelle's 8x3x2 restart update 08/10/2012
Postby wawazza » Tue 20 Sep, 2011 11:04 pm
Full Tank Shot 02/03/2012
Well i have had my ups and downs. majority downs with my previous tank, but from that i only look at the positives and the learnings from it. Living in Karratha i have Australian Coral Farms 10 minutes away and have got to befriend Wayne and his staff who are a great help.
I also have a 7 metre boat and do alot of fishing and diving around our magnificant archipelago.
I have grown up on and under water and to be finally able to afford a reef in my house is a great adventure. I am just looking forward to a tank that i am not worrying about it leaking...
System Objectives: To produce a stunning view of underwater life, seen as if you were diving yourself. To have the system maintain itself enough for me to go on holidays and have no dramas but feeding the system. I want the aquascape to very spacious as if it was the endge of a reef meet sand.
System Type
: Mixed Reef
Strike up Date: Building stage
Display Tank: 2.4 x 3 x 2 12mm built by Vebas
Display Lighting: Still undecided, more then likely 4 x Ecotech radion
Stand: Galv steel frame, with custom "Curtain" for ease of access. 1.1m High
Hood: Hoodless, although a full length light hanger which can "swing" off the tank.
Sump: Deep sand bed plus refuge also internal skimmer compartment .
Refugium: In Sump
Refugium Lighting: T5
System Water: Still deciding, more thgen likely NSW collected in my boat hull !!
Display Water circulation:Currently 1 x MP60 + Tunze USB Controller and 2 6105's. (for a start)
Return Pump: Still deciding would like an adjustable, will be good quality.
Skimmer: Reef Octopus Super 5000 external (using in sump as internal) Ehieim compact feed pump
Evaporation Top Up: Currently have RO unit but not installed.
Runing Seneye Reef+ syestem
Calcium Addition: NA (require some education)
Alkilinity Addition: NA (require some education)
Other Chemical Maintenance: NA (require some education)
Current Water Chemistry: NA
Wazza
8X3X2 (Current Build)
viewtopic.php?f=145&t=233320
7x3x3 Mixed reef (obselete)
viewtopic.php?f=145&t=229111
wawazza
Re: Wazza & Chantelle's "Happy Place" Build 10x3x2
Postby kj52faith » Wed 21 Sep, 2011 5:49 pm
Nice wazza, If your going for a refugium for a tank that big you will need to provide a big refugium to have an effect on the system
kj52faith
Postby wawazza » Sat 24 Sep, 2011 2:13 pm
Have really been struggling with lighting choices obviously going the larger tank has upped the value on lighting.
Was thinking:
2 x Inwatter 4 foots approx ($3000)
4 x Ecotech Radion approx ($3200)
Toyed with the idea of the Vertex Illuinex (the cheaper version of the Illimuna) but i dont know about them, are they controlable etc.
Really stuck on this my budegte is now 3k give or takeand im straying to the Ecotechs Radions.....
Wazza
wawazza
Postby reefsecretsaquariums » Sat 24 Sep, 2011 3:20 pm
10x 3 whoooha should be awesome ... :cheers: im coming along for the ride ... :clap: sometimes i look at my 8x3x2 and think .. dam should have gone 10 foot .. :wall:
REEF SECRETS AQUARIUMS (07) 55356996
unit 2 number 9 Kortum Drive, Burleigh Heads . darren@reefsecrets.com.au
Reef Secrets Facebook Page
http://www.reefsecrets.com.au/
Australian Reefing Connection
EMAIL ME INSTEAD OF PMs IT FILLS UP TO QUICKLY. I CAN CHECK EMAILS FASTER.
I DONT WORK ON MONDAYS >>> ITS MY ONLY DAY OFF .
MASA Partner
MASQ Supporter
Postby wawazza » Sat 24 Sep, 2011 5:19 pm
Haha yes well i have a tendency not to do things in half's, I am really looking forward to aquascaping and making it quite a "Bare" tank. 3 individual bombie setup with some nice and white sand.
I started off buy wanting 6 foot setup as i was too scared to go big as i have had several problems with my last second hand tank. The more i talked to Pacco the more confident i felt so i decided to go with my dream size.
Going to be expensive in lighting though, oh well its only money....
Wazza
wawazza
Postby kj52faith » Sat 24 Sep, 2011 6:54 pm
The ecotechs are able to upgradable over time, I don't know about the inwatters. I like the ecotechs new light, but i don't like the noise of their vortechs :( And thats true what you say, it's only money
kj52faith
Postby wawazza » Sat 24 Sep, 2011 7:26 pm
I have never heard the noise level of the Vortechs yet i ahve read the banter betweent tunze vs vortech. I have 2 6105's but no controller so i am going to by the Tunze USB controller then i was thinking of buying a MP60 to go along with the lights and if i was happy get a second MP60...
Its a bit of a holden ford thing... But im happy to try both..
But thats the plan this hour, my opinion alters often and my mind changes...
Wazza
wawazza
Postby chromus » Sat 24 Sep, 2011 8:24 pm
I would listen to an mp60 prior to purchase, even mp40 users complain 60's are loud.
Postby wawazza » Sat 24 Sep, 2011 8:40 pm
Probably a good point, i am going to visit Vebas in the next few weeks when i am down in perth i shall have a listen then hopefully.
I have to give it to ecotech about having majority of the pump exterior to the tank allthough i like to be able to point my tunze where i please.
Wazza
wawazza
Postby kj52faith » Sat 24 Sep, 2011 9:28 pm
Since your tank is so long to tunze provide great long distance turbulence maybe 3 mp40's on the back wall or 2 mp60's as the vortechs provide wide flow and a different form of flow.
kj52faith
Postby shannonpayne86 » Mon 26 Sep, 2011 9:45 pm
It's simple, I've seen both the Tunze and the Vortech, if its in clear sight and don't mind noise get a Vortech MP60 as they are a much neater looking pump ( I have one). If it's out of sight definitely go Tunze. Turn ya TV up to normal volume and you will still hear it but hardly notice it.
shannonpayne86
Postby wawazza » Tue 27 Sep, 2011 12:26 pm
Well i have decided to go with the Vertech Radions x 4 as a start. We the finances re-develop and if required i will purchase a 5th.
With this i will also grab a MP60. To go with my 3 Tunze pumps i already own.
Now its just awaiting the tank builder to return from holidays!! Come on Pacco hahah
Wazza
wawazza
Postby wawazza » Thu 29 Sep, 2011 5:17 pm
Plaing this tank in my lounge room, also deciding on which theatre lounge to purchase just for the tank!!
Wazza
wawazza
Postby bigdhsv » Thu 29 Sep, 2011 10:43 pm
Talk to pacco about these babys "SICCE VOYAGER 10 HP" saw one in action in vebas and the flow this thing gives eats the mp40's and id say at $200ish they would help your budget and allow for better lights!
bigdhsv
Postby wawazza » Thu 29 Sep, 2011 11:17 pm
I talked to him about these, will pop in for q look when fly down in a weeks time. Not a fan of the radions?
Wazza
wawazza
Postby wawazza » Thu 06 Oct, 2011 9:56 pm
Had 36 meters of steel arrive for my stand today.. Have some days off next week to start welding... It's 50 x 50 x 3... Going to be quite heavy but I'll only be lifting it once.
Going to paint and then get a mate who is a trimmer to make me a "curtain" that press studs on for easy of access.
Any tips from people who have diy stands would be appreciated
Wazza
wawazza
Postby clowns4me » Tue 20 Dec, 2011 3:22 pm
Any updates??
...Sometimes doing the right thing aint doing the right thing...
clowns4me
Postby wawazza » Sun 25 Dec, 2011 12:29 pm
Hi, I have ordered and changed size to 8x3x2 should be ready mid Jan.
Stand is complete just need to sort out what lights and how to hang them. If I go radions I want to hang from the stand.
As for flow I have got a couple of tunze 6105 and a controller but will prob purchase 1/2 mp60 (to go with the radions)
So I am pretty much in the stageof planning still, I am not in a huge rush as I jumped into my last tank and that was a diaster. Researching this site hours on end is brilliant help.
Will throw some photos of the stand up when I'm home, in Perth for Xmas...
Wazza
wawazza
Re: Wazza & Chantelle's 8x3x2 (build)
Postby notsomot » Sun 25 Dec, 2011 1:13 pm
Wazza make sure you use a good paint, makes all the difference.
I used two pac Durabuild. Paint for oil rigs out at sea. Expensive but worth it.
I used same steal, I cut it up but got a welder to pressure weld it for me
notsomot
Postby wawazza » Sun 25 Dec, 2011 1:34 pm
Wazza
wawazza
Postby wawazza » Sun 25 Dec, 2011 1:37 pm
Notsomot did you cap your ends?
Wazza
wawazza
Postby notsomot » Sun 25 Dec, 2011 1:50 pm
Yeah man, photos on my tank j.
Inside is air tight to stop rusting from inside out
notsomot
Postby wawazza » Fri 30 Dec, 2011 9:19 pm
Hi all, time to start buying some serious gear,
4 x Ecotech Radions
2 x MP60s
Tunze ATO
Also going to be adding a rail that goes over the centre of the tank full length to hold the lights.
I already have a reef octopus super 5000,
Wouldnt mind a suggestiion on a good return pump??
Wazza
wawazza
Postby bigdhsv » Fri 30 Dec, 2011 9:34 pm
laguna max flow say 6000 or above would be my choice
bigdhsv
Postby wawazza » Fri 30 Dec, 2011 10:18 pm
Thanks Damian, Pacco said you have a mate who did your black backing, would he be keen to do mine?? i want to get it done before it gets up here.
Wazza
wawazza
Postby bigdhsv » Fri 30 Dec, 2011 11:23 pm
hey mate it was my brother who did it, but he is not able to do it again, i had to organise it myself and go get the vinal. but there is a shop next to vebas that can do it for you
bigdhsv
Re: Wazza & Chantelle's 8x3x2 (build) stand photos
Postby wawazza » Sat 31 Dec, 2011 11:58 am
Small update,
Modified my stand, will finish painting tomorrow.
Im buying more steel to make the bar that goes over the centr of the tank for the lights next week.
http://www4.snapfish.com/snapfish/slide ... =snapfish/
And this is where the tank will stand in my house:
Wazza
wawazza
Re: Wazza & Chantelle's 8x3x2 (new photos light hanger)
Postby wawazza » Sun 01 Jan, 2012 8:04 pm
Few photos of how i am going to hang my lights,
Main point is i want to be able to afjust height and also adjust very high and get them out the way for working in the tank.
This gives me more then a metre extra height from running height. More then enough i believe.
Fire away with any suggestions..
Wazza
wawazza
Postby radioman » Sun 01 Jan, 2012 8:50 pm
this is looking to turn out to be a great tank.
can I make a sugestion ref the hanging for the radions, they have a largish power supply so might need a bracket or wooden area to locate the power supply for each light unit. They are a great light unit, I have had two over a 4 ft tank for about a month now and the coral is going nuts also next to no heat, so cuts down on the cooling requirement for the tank.
the 60's are a great choise as well especially for a 8fter. :clap:
Looking good so far. :thumbsup:
radioman
Postby wawazza » Sun 01 Jan, 2012 8:55 pm
how long are the power cords on the radions? i want to run them inside the frame. and all the way down the bottom.
Should i run the radions long ways with the tank or at 90's to the front of the tank, remebering the tank is 3foot wide and i will mainly be running softies on a small 3 bombie aquascape.
4 x radions
Wazza
wawazza
