I have been asked many times over the years why i have never had a journal on here, so here you go.
i have been collecting bits and pieces for my new tank for a while now. currently i have a 4x2x2 which has been going for about 7 years, and for 4 to 5 years before that i had a standard 4 ft. I am doing a big renovation on our house (adding more than we currently have) which has given me the chance to upgrade. lucky i have a spare locker at the fire station where i work to put thing in
System Type: mixed reef, lots of fish, lots of corals
Strike up Date: ASAP but a wile yet
Display Tank: 4 foot, 4 inches x 4 x 2, 3 sides 12mm starfire, side panel 15mm normal glass lasercut with external overflow. starfire laser cut one piece top brace. black silicone all round as well as polished edges. i think that its?? viewable through 2 and a half sides. one in the kitchen, one and a half in the loungeroom/entrance. fits in between the existing fireplace and a wall perfectly. ill get some photos of the walls that are coming out to explain it a bit better.
Display Lighting: two 6x54 t5 ATI sunpower untis (already have these)and 2 X 190 "Solatubes"
Stand: metal, powder coated
Hood: not sure yet
Sump: Sump size isnt finished yet, may make it myself, hoping to have some of my broodstock clowns in there as well
Refugium: see above
Refugium Lighting: ?????.
System Water: Natural salt water stored in a 1000 l IBC. direct fill to the tank via laguna pump.should be able to turn one valve to drain the old water into my fish broodtock system, and turn on a pump from the ibc to refill the reef. ahhh, no mor siphoning old water and tipping in 25l drums of new
Display Water circulation: 4 x tunze 6105 pumps on a 7096 controller (already have all this). may put in a couple of 6045 nanos i have if needed.
Return Pump:not sure yet, probably a laguna
Skimmer: Royal alpha 250 (already have this)
Evaporation Top Up:Auto topup
Calcium Addition: dosing pump
Alkilinity Addition: dosing pump
no images of the tank yet. wouls love one of those 3d thingys but my computer skills are limited to checking emails and google
so now after 10 years on RTAW, i have a journal
