Flippers 6x3x2- video 24-7-11
Re: Flippers 5.5x3.5x2- A new beginning
Postby Darr1n » Tue 13 Apr, 2010 6:07 pm
I like the closed loop systems, but in the ocean, when does the water come out of the sea floor :roflmao: .
If you get your vortechs on a back panelk where it is black, you will barely see them. Look at what guys like stripes are doing with there.
Get it right and have a nice wave action, will look very natural.
Darr1n
Images: 20
Postby n0rk » Tue 13 Apr, 2010 6:18 pm
I guess another option worth considering is a closed loop in the hidden end (as in, from the side and not the base) in conjunction with VorTechs... run the CL in "tides" (6/6/6/6 hour blocks)... could get some interesting flow dynamics out of a tank this shape...
Postby Darr1n » Tue 13 Apr, 2010 6:33 pm
You mean like Deek's http://www.masa.asn.au/phpBB3/viewtopic.php?f=51&t=208704&start=150.
Can't imagine Flipper coping with that plumbing :roflmao: .
Would be awesome though.
Darr1n
Images: 20
Postby Flipper » Tue 13 Apr, 2010 7:43 pm
You're right there. Mine wouldn't look anything like that. Would need to have someone do it for me :tongue:
Flippers Tank Journal
Quietly going about my business
Flipper
Postby Flipper » Tue 13 Apr, 2010 7:48 pm
The only other thing I was thinking was to somehow plum the return somewhere at the other end, probably from the top.
Kean you're more than welcome to plumb it for me ;)
Flipper
Postby n0rk » Tue 13 Apr, 2010 8:26 pm
Could do the return like blags did, run the pipework along the top on a rack then drop into the tank?
Postby Flipper » Tue 13 Apr, 2010 8:42 pm
Yeah, Thats what I was thinking. Splitting the pipe with a tee at the end. It wont be a huge amount of flow but will add to the flow
Flipper
Postby StripestheEel » Tue 13 Apr, 2010 9:20 pm
fishlover wrote:Ok i guess i better stop hounding you about it then,just wanted to see your tank as TOTM one day.Kean
And having vortechs is going to stop him from getting TOTM? :roflmao:
At the end of the day Flipper, do what you want. It is your tank, not everybody elses.
Do what will be easier for you to set up, install and maintain.
Postby Deek » Tue 13 Apr, 2010 9:44 pm
Hey Flipper :)
I would have to say without a doubt that Vortechs will be far and away easier...
Put them on a black background and they will blend in nicely.
You will also have alot more room under the stand. :thumbsup:
cheers,
Derek
Deek
Postby Darr1n » Tue 13 Apr, 2010 9:52 pm
StripestheEel wrote:Do what will be easier for you to set up, install and maintain.
Sometimes we try and do too much, then it all gets too hard. I looked at closed loops, then the holes/plumbing got more complicated than I was capable of handling. My tank is setup now and I am so happy I kept it simple.
Darr1n
Images: 20
Postby Flipper » Tue 13 Apr, 2010 9:54 pm
Thanks guys. I need it to be easy and I need to do what i'm comfortable with and im not the handyman. Vortechs are about as difficult as it gets for me. Im into creativity so I will work on my aquascaping
Flipper
Postby fishlover » Tue 13 Apr, 2010 10:36 pm
No problem me doing the plumbing for you Flipper as long as your supplying the beer.I dont claim to be an expert plumber by any means but i spent Sunday setting up the plumbing on my sons new tank and actually really enjoyed it.
In no way was i suggesting he couldnt win TOTM with Vortechs in there just a personal opinion(im sure were still allowed to have them in this democratic country) that a tank looks better without them.Kean
fishlover
Postby Flipper » Tue 13 Apr, 2010 10:59 pm
Better sell me your vortech then
Flipper
Postby fishlover » Tue 13 Apr, 2010 11:03 pm
Thats a possibility when i re-set up my old tank i will be going Gyre flow and wont need it.But for now it will be used in my sons tank.Kean
fishlover
Postby StripestheEel » Wed 14 Apr, 2010 12:12 am
I felt uncomfortable putting holes in my base so that's why I went with the Vortechs. You can hardly notice them. Have a look at some vids and you will know what I mean.
Postby reefbuilder » Wed 14 Apr, 2010 9:30 pm
StripestheEel wrote:I felt uncomfortable putting holes in my base so that's why I went with the Vortechs. You can hardly notice them. Have a look at some vids and you will know what I mean.
reefbuilder
Postby parrdog » Wed 14 Apr, 2010 9:54 pm
I plan to put my Vortechs on the back wall as well, yep, my wall is painted black as well.
Your setup sounds and looks like it will be fanatastic Flip :).
Postby Flipper » Wed 14 Apr, 2010 10:01 pm
I just better not stuff up the aquascaping
Flipper
Postby Deek » Wed 14 Apr, 2010 10:03 pm
You should have an easy time with a 3.5' wide tank! :thumbsup:
Deek
Postby parrdog » Wed 14 Apr, 2010 10:17 pm
Yeah, your dimensions are just awesome, you should be sweet :).
Postby Flipper » Wed 14 Apr, 2010 10:29 pm
Be good if you guys could look at the overflow and check whether measurements are good.
Thanks to Shaanon for sketching it up for me...will owe him a few beers
Flipper
Postby shannonpayne86 » Wed 14 Apr, 2010 11:00 pm
just make them boags or caronas
shannonpayne86
Postby StripestheEel » Wed 14 Apr, 2010 11:29 pm
shannonpayne86 wrote:just make them boags or caronas
Hahaha, not picky at all
Postby Flipper » Thu 15 Apr, 2010 9:40 pm
Some feedback on the calfo measurements would be appreciated
Flipper
Postby pafc64 » Thu 15 Apr, 2010 10:39 pm
HI Flipper
Now I'm home (was at work when I PM you) I have been able to measure it a bit better.
Make the back pane of glass on your tank (front lip on Calfo) the height you want the water level to be in your tank.
The water level in my weir is about half way up the elbows on the Beanimal setup which makes it a 60mm drop for the water over the edge of the weir & is silent.
Hope that helps
Rick
Rick
Ricks 4x2x2
pafc64
Postby Darr1n » Thu 15 Apr, 2010 10:51 pm
I can see a trip to Whyalla :roflmao: .
Hey MASAOG Riverland-Whyalla tank crawl ;)
Darr1n
Images: 20
Postby shannonpayne86 » Thu 15 Apr, 2010 11:03 pm
I'm in I love the riverland and I love reef's, almost done with ya pics flip.
shannonpayne86
Postby shannonpayne86 » Thu 15 Apr, 2010 11:14 pm
shannonpayne86
Postby Scooby » Fri 16 Apr, 2010 5:42 pm
The measurements look good Flip, the elbows will be fully submerged within the overflow section so the syphon should start fine after a blackout.
Are you going 25mm all the way with bulkheads and piping?
Scooby
Postby shannonpayne86 » Fri 16 Apr, 2010 6:40 pm
The way I have drawn it is with a 35mm hole, thus allowing for a 25mm bulk head (going off of the hansen brand of bulkhead that's the size hole they require.). Let me know if ya want it changed flip.
shannonpayne86
