Flippers 6x3x2- video 24-7-11
Postby Flipper » Thu 01 Apr, 2010 9:45 am
We are moving house so naturally the first thing that comes to mind is a bigger tank, I want a DT where it will be more open where the fish have use of alot more water are where its not full of rock and the rocks aren't placed on the back glass. My design is based on Marcs Peninsular tank , which looks very impressive..
My original thoughts is to have 3 bommies but I still would like some connection between the three. This would be used to house my zoas and hammers.
I dont want to go completely SPS as I like the look of a mixed reef, which again is a bit more natural. I also like my fish and would like a few schools.
17/10/10
The DT will be ,as said previously, a Peninsular style 5.5x3.5.2 (still unsure on the 2' high, maybe 27"). I will be using the calfo overflow system. I am currently looking at having a gradient vinyl background in blue. Going from a darkish blue 2/3 of the way up the gradient to a lighter greyish blue.
I currently have Ecolamps LED lights and plan to expand on these. I will use to twin T5s along the side just to light up what the LEDs miss
The stand will be made out of timber and cladding in white 2pac removable panels for easy access
I would like to thank Shannonpayne86 for drawing the plans up for me.
Hood:
Basically made the same way as the stand with an open top. I have made it out of the click aluminium. It will be in 3 sections the 2 outer sections will be hinged to the main section allowing me to fold up the T5s ontop of the middle section to allow easier access to the tank.
Sump: Sump specs if applicable.
The sump will be 4'x18"x2' and is a simple 4 section setup. It will have a refugium but not sure if I will go DSB as I will eventually be using Bio pellets. Skimmer will be external (RO 1500) and an internal one (RO Vortex800) to use when my stock gets quite heavy
Natural salt water
Starting off with 3 mp40wes then gauge how much extra is needed
Changed from the panworld to a Laguna 7500
I have a RO (ooohh, that brand makes me shiver every time I write it) Hurricane 1500 external and RO Vortex 800
Auto topup using Reef Keeper controller by Digital Aquatics..great piece of gear
I will be running 2 phosban reactors. One with Biopellets and the other with AC
Calcium Addition: Dosing using dosing pumps
Alkilinity Addition: Dosing using dosing pumps
So here are some drawings so far , again thanks to Shannon.
I did the calfo drawing with alot , and i mean alot of help from Scooby. So any comments would be appreciated
Flippers Tank Journal
Quietly going about my business
Flipper
Re: Flippers 5.5x3.5x2- A new beginning
Postby damer » Thu 01 Apr, 2010 3:13 pm
the people allway look the same in those photos :roflmao:
should be good, look forward to it happening
Damien's 1300 x 1200 x 600
damer
Postby Rod the Reefer » Thu 01 Apr, 2010 4:25 pm
Hey Paul, you've lost some weight.
Postby Flipper » Thu 01 Apr, 2010 4:37 pm
Its gotta be about the weight....what about the rest of it? I actually have widen the vertical piece so I can fit some parts of my body through
Flipper
Postby Rod the Reefer » Thu 01 Apr, 2010 4:49 pm
Mate, I'll talk to you about it when you get here.
Postby ocellaris lover » Thu 01 Apr, 2010 4:56 pm
That... looks... AWESOME!!!!
Can't wait for it to come together!
Good luck
Geoff
Call me Geoff
ocellaris lover
Postby ryanrid » Thu 01 Apr, 2010 5:04 pm
is it going to be viewable from 3 sides?
this looks like it is going to be great, really like the stand design. if you go ahead with the white tupac panels i would get someone else to do it or even look into laminate as it is a big job and a PITA. i think my broo and I spent about $600 on paint for our 2 cabinets and about 5 days as sanding and adding 4 prime coats has to be done on different days.
good luck
Postby shannonpayne86 » Thu 01 Apr, 2010 5:20 pm
Flipper would you like me "distort" the picture of the guy in future drawings so people can concentrate on your tank critique rather than commenting on your biggest loser campaign?
shannonpayne86
Postby Flipper » Thu 01 Apr, 2010 7:05 pm
Definitely get someone to do the panels and painting. The beauty is I dont need to do that part until last.
Shannon, just put a picture of a pig in its place- similar size and no hair as well
Flipper
Postby Flipper » Thu 01 Apr, 2010 10:56 pm
It will be viewable from 3 sides so we can look at it from the kitchen, dining, lounge.
The biggest challenge will be to get it up 7 floors in a lift. I will start a recruitment drive as time gets closer
Flipper
Postby Flipper » Fri 02 Apr, 2010 5:46 pm
Well it didnt take long to hit a snag in this project. Everything looked good from the plans except for one thing. The tank stand was not going to fit through the door :konk: :konk: So after some advice it was decided that the only way it could be done it to make the stand out of wood. The stand would have to be temporarily made up somewhere to make sure all is well then dismantled and then rebuilt inside our apartment. Although a pain its not that much of a drama, says he who has no idea how to do it.
Stayed tuned
Flipper
Postby ocellaris lover » Sat 03 Apr, 2010 7:03 pm
What about building it in parts and bolting/slotting them together?
Geoff
Call me Geoff
ocellaris lover
Postby Flipper » Sat 03 Apr, 2010 7:25 pm
Thats all I can do Geoff. Thats why it has to be in wood
Flipper
Postby reefsecretsaquariums » Sat 03 Apr, 2010 11:30 pm
you can bolt metal togeather stronger than wood ... :poke:
i was gonna say why not go bigger but then you said the 7 stairs up.... :roflmao:
REEF SECRETS AQUARIUMS (07) 55356996
unit 2 number 9 Kortum Drive, Burleigh Heads . darren@reefsecrets.com.au
Reef Secrets Facebook Page
http://www.reefsecrets.com.au/
Australian Reefing Connection
EMAIL ME INSTEAD OF PMs IT FILLS UP TO QUICKLY. I CAN CHECK EMAILS FASTER.
I DONT WORK ON MONDAYS >>> ITS MY ONLY DAY OFF .
MASA Partner
MASQ Supporter
Postby n0rk » Sat 03 Apr, 2010 11:33 pm
:withyou: get a stand prefabbed out of RHS and then bolt the components together. It'll be the same as wood, only about a million times stronger if you do it right...
Postby Flipper » Sun 04 Apr, 2010 9:18 am
Its just the stand that wont fit and no matter how I look at it the bolt heads will stick out making it hardto add the panels after. The stand will be made out of 75x75mm square pieces.
Flipper
Postby StripestheEel » Sun 04 Apr, 2010 1:06 pm
My stand and sides came in parts. Go metal if you can, although in the end it doesn't really matter I guess.
Postby Lukey » Sun 04 Apr, 2010 1:11 pm
Yeah, also a big benefit of metal is the fact once you assemble and test it, you can re-assemble it upstairs without any ill effects. Whereas undoing a wooden frame and then re-screwing into holes already made will make a wood stand significantly weaker you'd imagine. Dunno if this'd hold true, but just talking from my experience in the past with various bits and pieces. Metal does not change size when you join pieces together with bolts, whereas wood does.
Hope that made sense, hard to describe.
Lukey
Postby Flipper » Sun 04 Apr, 2010 1:14 pm
Thanks guys for the advice. The next bit is to work out how to clad it with the bolt heads sticking out. Rods suggestion was to just pack it out
Flipper
Postby sydneydrewid » Sun 04 Apr, 2010 1:58 pm
looks very interesting Flipper, will be watching with great interest...
Postby samhaz » Sun 04 Apr, 2010 2:14 pm
I reckon its a great idea.
Build it on site.
Nice and easy to clad, eaiser to fit doors to, doesnt rot if the right timber is used.
Lukey, I guess they dont have any good carpenters in NSW then? lol
samhaz
Postby ocellaris lover » Sun 04 Apr, 2010 6:31 pm
Actually to avoid bolt heads sticking out, make the hole the radius of the bold minus the thread. Get a threading kit and thread the metal, and use the frame as the 'nut'. Then finally use and angle grinder (or hacksaw) to cut off the excess bolt!
You'd have to do it so that the bolt heads point inwards and that the side with the bolt on it would have to be drilled a little larger so that it doesn't get threaded.
Just a thought... :tongue:
Geoff :thumbsup:
Call me Geoff
ocellaris lover
Postby Flipper » Mon 12 Apr, 2010 9:54 pm
While Im waiting on info about my stand and tank I switched my focus to water circulation. I dont think 2 x mp40s will do the job in such a big tank so my thoughts are:
1. 2x mp40s
2. 2x mp40s at the top of the tank and 2 x mp10s about half way down the tank
3. Same as 2 but replace the 10s with mp40s
Desicions, desicions
Flipper
Postby fishlover » Mon 12 Apr, 2010 10:01 pm
If i was you Paul(and trust me im glad im not) i would seriously go with the Gyre system like Rod.I know next time i set up a big tank there is no way i will have power heads messing up the display.Cheers Kean
fishlover
Postby Flipper » Mon 12 Apr, 2010 10:08 pm
I was thinking about it but I already have 2 mp40s plus I cant get my head around the flow bit. BTW, how do you think I feel? Im stuck with myself :roflmao:
Flipper
Postby fishlover » Mon 12 Apr, 2010 10:14 pm
Sell the mp40's and get Rod to set up your new tank he will steer you in the right direction.With the money you make from the powerheads im sure you could get one of the flow pumps with the way the dollar is at the moment.Trust me you wont look back with nothing in the tank except coral and fish.Kean
fishlover
Postby shannonpayne86 » Mon 12 Apr, 2010 11:34 pm
Kean has a good point, i'd do it if I had the skill and money!!! Flip I should have ya new 3D renders done by tomorow, sorry been a bit busy now that Sarah has the ring on her finger!
shannonpayne86
Postby fishlover » Tue 13 Apr, 2010 5:46 pm
I dont think the money is really an issue when we are talking 2 vortechs already thats over $1000 in pumps,sell them for $400 each and that will pay for one of the circulation pumps.As far as skill goes most of that comes down to the tank builder drilling holes which is not a major problem,then as far as design and set up goes im sure Rod would be more than happy to help out.Go on Flipper do it and make the tank something special.Kean
fishlover
Postby Flipper » Tue 13 Apr, 2010 5:56 pm
Nah, I think I will stick with boring. I have more confidence in that way. Its ok to ask people for their help but there is a limit and I dont want to push my luck. If I do it with the vortechs then I know Ive done it
Flipper
Postby fishlover » Tue 13 Apr, 2010 6:06 pm
Ok i guess i better stop hounding you about it then,just wanted to see your tank as TOTM one day.Kean
fishlover
