Tone's 2000L Reef - TOTM 06/2011, TOTY 2011 RU, Aqualog TOW
Re: Tone's 2000L Reef - TOTM June 2011 -- TOTY 2011 Runner u
Postby saltydog » Thu 04 Apr, 2013 10:00 pm
That's a shame Tone.
All the best
DTSTTCPW
saltydog
Postby Macca_75 » Fri 05 Apr, 2013 8:26 am
Keeping the same fish in a closed system for 15+ years (and you don't know how old it was to begin with) is a credit to your dedication and husbandry.
Macca_75
Postby Tone » Sun 07 Apr, 2013 10:13 pm
The cycle of life, gents ... funny Old Blue ate like the proverbial pig but in its last few weeks stripped the weight off its frame. Shame, it was so thin at the end.
Some fish just seem to last forever, Macca. 'Blue had seen his 'dark' days many times being laid low with whitespot but always pulled through ... strong constitution ! I reckon that I just had a belligerent old fish with the right attitude ;)
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Macca_75 » Mon 08 Apr, 2013 9:59 am
Not dissimilar tot he PJ Cardinal I have - bought in 2001 (OR 2001). No matter what silly mistakes I have made she is still there. Big old goofy thing. Starting to fade in colour, but still got plenty o' meat on her bones.
Macca_75
Postby Tone » Tue 30 Apr, 2013 3:05 pm
Working on some upgrades ... as the T5s require tube replacement, I've decided to install LED strips instead.
First one is constructed from this DIY kit : http://www.aquastyleonline.com/products ... e-Kit.html with 4x all blue strips and 60deg optics. Strips are glued to a 25mm black anodised aluminium square tube with all wiring run internally. In testing, it looked very nice ... waiting for a suitable enclosure for the drivers and potentiometers before commissioning in place.
Looks like this :
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Rod the Reefer » Tue 30 Apr, 2013 3:42 pm
Looks good Tone.
How do they compare with T5's?
Postby slawman » Tue 30 Apr, 2013 5:51 pm
Looking very nice Tone. Are the lenses easy to swap out or do they come integrated with the led?
slawman
Postby Tone » Tue 30 Apr, 2013 7:12 pm
Haven't run it insitu yet, Rod, but I'd expect that the 24x3W LEDs are going to be better than the single 58W T5 that is replaced. I did do a brief test a few minutes ago before I start to assemble the control enclosure ... very blue and pushes right to the base. Unfortunately one bank isn't working ... done some testing with the multimeter and found a reversed connection; just got to fix that and she'll be good to go.
Slawman, the lenses pop off easily so you can use change them as you wish.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Rod the Reefer » Tue 30 Apr, 2013 8:11 pm
How do you go for colours though Tone? eg Fiji purple, etc.
Also, I know there's massive savings in bulbs, but wont you be using more power?
Postby Tone » Wed 01 May, 2013 8:22 pm
Rod, 14W more power ;) but the saving in tubes is far greater.
I've gone all blue on this LED strip and it does give a very clear almost electric blue colour even when turned down.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Macca_75 » Wed 01 May, 2013 8:56 pm
Tone wrote:Rod, 14W more power ;) but the saving in tubes is far greater.
If you dim them to (or ramp up/down) less than 100% then it may end up less power :wink:
Macca_75
Postby Tone » Thu 02 May, 2013 1:04 pm
Of course :) I probably only run them at ~80% otherwise they're very blue.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Rod the Reefer » Thu 02 May, 2013 6:30 pm
So, can you get purples etc Tone?
Would be sweet to replace T5's with these. :think:
Postby Tone » Fri 03 May, 2013 11:15 am
Purples are available from that source, Rod ... when you do your order it gives you the option to choose your LEDs.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Tone » Sun 05 May, 2013 1:47 pm
Have to turn them down a bit more as a branch of my Dallas underneath it RTNd real quick ... down to 50% power now.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby some_one » Wed 05 Jun, 2013 10:29 pm
Like the new LED strips Tone :thumbsup:
One question with running Ozone. How often are you changing your carbon and also how much carbon are you running after your skimmer?
I'm going to be utilising Ozone in my system soon, but just need to sort out the GAC after the skimmer side of things first.
Cheers :cheers:
Brett
From WA, join MASWA!!
some_one
Postby Tone » Sun 09 Jun, 2013 12:59 pm
Hi Brett, I change GAC when I remember to ... true ... probably every 1 or 2 months as I have a very large reactor tube and i give it a shake up every now and then to break down any pathways. It discharges into a small filter sock to capture any carbon dust. The carbon reactor if fed off the return pump manifold and discharges back into the return pump compartment.
My ozone injects 50mg/hr for 30 mins every 6 hours.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby ryanrid » Sun 09 Jun, 2013 1:03 pm
Be nice to see a new fts, looks full to brim in the lighting shots
MASS Member
Postby some_one » Sun 09 Jun, 2013 6:42 pm
Thanks Tone :cheers:
I was reading up on it and most of the suggestions are to pass the skimmer discharge over GAC.
I already run a GAC reactor in the sump compartment which returns back to the sump (same setup as you described above), and was going to just keep using that setup with adding more carbon into the reactor. But was unsure of the implications/negative impacts of doing it that way.
Thanks for sharing Tone :clap:
Brett
some_one
Postby Tone » Sun 09 Jun, 2013 7:24 pm
:) Brett, since the O3 is injected via the skimmer, there is a much reduced chance of bromide poisoning of the tank ... very little if any O3 will escape via the water passed back into the display.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Tone » Sun 09 Jun, 2013 7:28 pm
ryanrid wrote:Be nice to see a new fts, looks full to brim in the lighting shots
:) Ryan, the FTS is the same as the previous ones ... soon I'm going to muster the courage to hack up the left side and reduce the LR to low levels ... normally I need to ruminate on the idea for a year or two so its getting close now. Then I'll post a new FTS.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby GrimReefer » Sat 22 Jun, 2013 9:43 am
Very interesting LEDs there tone, will be interested to see how they perform for you over time :thumbsup:
GrimReefer
Postby Dallas » Fri 19 Jul, 2013 9:28 pm
Any chance of a Dennis shot?
Dallas
Postby Tone » Sun 21 Jul, 2013 5:29 pm
Dallas wrote:Any chance of a Dennis shot?
Regards from Dennis ... I'm styling like a big boy now !
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Dallas » Sun 21 Jul, 2013 9:30 pm
He has great markings for a Pacific.
Dallas
Postby Tone » Tue 30 Jul, 2013 7:14 pm
Dallas dropped by a couple of new inmates for me last week ... a Moorish Idol and a Copperband ! Two beautiful specimens !
But WW3 has broken out ... the MI is large so I didn't think that it would attract any attention ... whoa! Dennis, the Sailfin, also large but not as big, has taken a distinct disliking to Molly ... apparently they have been previously acquainted in Dallas' tank, LOL ! Anyway, poor Molly is worse for wear with a couple of tears on one side and a bit stressed out. Lenny (Coppperband) has dealt with his demon, the Mimic, and life is good.
Despite this setback it looks like a peace settlement has been reached and I'm hoping that Molly will make a full recovery ... she's swimming and eating well, chasing down food.
Pics to come when the damage is repaired.
Reefing since '93.
2000L Reef.
Originator of MASQ
Tone
Postby Rusty1 » Tue 30 Jul, 2013 8:42 pm
Tone wrote:Dallas dropped by a couple of new inmates for me last week ... a Moorish Idol and a Copperband ! Two beautiful specimens !
The more established the existing tenant is the more aggressive they seem to be!
Hope it settles soon though Tone, love the MI.
Tank Now For Sale
Reef In The Wall
Tank on Facebook- Closed
Reef In The Wall- FB
Rusty1
Postby Dallas » Tue 30 Jul, 2013 10:19 pm
Dennis, you bastard.
Dallas
Postby Dallas » Tue 13 Aug, 2013 8:55 pm
Any sign of an armistice?
Dallas
Postby ssscuz » Tue 13 Aug, 2013 10:06 pm
Might be time for a fts while your uploading photos tone!! It's been a while :poke:
