Page 2 of 2
Re: New Pico Work Tank - 12 litres
PostPosted: Thu 25 Dec, 2014 1:14 pm
by chrismelb
Some Pocci growth (10 weeks)
You can clearly see the change in zooxanthellae density from when I had detectable Po4 (first pic) to zero Po4 (second pic).
PostPosted: Thu 25 Dec, 2014 5:26 pm
by kevinicus
hi,
nice build coming along here with really neat hardware. Keep the updates coming!
PostPosted: Thu 22 Jan, 2015 8:36 pm
by urbanrat84
Looking good! Any updates?
Btw that link you posted about sand beds in pico's is absolutely brilliant. Thats the sort of problems I encountered in my tank, it just takes much longer to happen in a bigger tank. And I've come to the conclusion after 7 years of learning the hard way that keeping the tank very clean and having renewable biological filtration or biofiltration on a rotational cycle is the way to go. Just my thoughts.
PostPosted: Tue 27 Jan, 2015 2:03 pm
by chrismelb
Unfortunately, I have lost the Strawberry Shortcake and Green Stag. Suspect this is due to the 100% water changes resulting in a substantial shift in water parameters. Now swapping to 30-40% water changes, weekly.
Ive never run into nitrate problems in any of my sand bed tanks. I've always preferred it as it gives a more natural look and also like the benefits of the micro flora that come with it.
I entered into the hobby back when Deep Sand Beds where all the rage and this has stuck with me. So long as they are largely left untouched they have never posed a problem for me. But I agree they are a nutrient sink and can cause problems, but in my experience this occurs when the bed is disturbed. Having said that, I am having a problem with my Damsel as he has started disturbing the upper level of the sand bed, will check nitrate and phosphate levels.
PostPosted: Wed 11 Feb, 2015 1:40 pm
by chrismelb
Tested nitrate (<.05) & phosphate (.03)
Have started doing an actual aquascape now.
The visiting acan, fungia and torch, have been removed and placed in tanks at home.
This morning, attached three tabling acros frags to the upright rock piece, back right :) Plan on putting a small selection of zoas on a rock just in front of that piece and then on the left at the front will be a small bommie of cluster acros frags, including the ones in the sand now. Once that is done, just going to sit back and hopefully watch everything grow :)
Polyps just starting to come out of the frags glued this morning
Again, excuse the iphone photos, keep forgetting to bring camera to work. But will do once aqua scape is finished.
PostPosted: Wed 18 Feb, 2015 1:37 pm
by chrismelb
Some close ups of polyps extension. Frags doing well and colouring up. I am using a cheap magnifying glass infront of my iphone6+ (DIY macro lens :talker: )
PostPosted: Thu 19 Feb, 2015 1:27 pm
by chrismelb
Finished my SPS cluster island and zoa island this morning.
Pics taken with a better camera: Panasonic LUMIX FT5 in macro mode correcting for blue saturation using custom white balance (i.e., pic of gravel sand)
SPS Cluster Island. Frags taken from my home tank. Some colours are yet to come as they were previous lit under a PC lighting. Also some were not in the best condition but hope will improve .
Pink Pocci
What hopefully will be a Purple acro
What hopefully will be a teal/Aqua acro
Purple & Cyan acro
Hard to believe but hopefully will be a hot pink Stylo
What hopefully will grow into a purple acro
Zoa Island
Green Alien Eyes
Green Alien Eyes under blues
Bloody Valentines
Green something
Green somethings under blues
Fire n ice
Fire n ice under blues
FTS. Not much to look at yet. Cant wait till they start growing and hopefully colouring up. Will prune them down if any start to block/compete with other
PostPosted: Sun 22 Feb, 2015 11:43 pm
by ClarityReef
whats your filtration system like?
Im just setting mine up and finding the best way so I can keep sps.
PostPosted: Mon 23 Feb, 2015 11:11 am
by chrismelb
ClarityReef wrote:whats your filtration system like?
I'm just setting mine up and finding the best way so I can keep sps.
Hi ClarityReef, what you see in the FTS is the filtration. It is purely biological with some help from the 30-40% weekly water changes. I don't run carbon, P04 remover, skimmer, nor do i have a reefuge with macro algae. I like to keep my nanos simple to avoid any mechanical/electrical malfunction, especially here at work. Nitrate and phosphate are absorbed by corals (more specifically the zooxanthellae and bacteria found in the corals), what ever microalgae grows in the tank (minimal), and bacteria in the water column and that attached to other surfaces (e.g., live sand, rock etc). I should warn that this doesn't work for everyone and it is a very fine balance to maintain - I can't just dump a cube of mysid/brine shrimp in and expect things to be ok, tank would probably crash. I am aware that the system can't handle a huge bioload so i'm careful with what goes in. I should also note that i don't dose any carbon sources (e.g., vodka).
PostPosted: Mon 23 Mar, 2015 10:05 am
by chrismelb
One month on and corals are colouring up nicely. Unfortunately, lost the two purple acros shortly after fragging everything. But apart from that everything else appears to be going well.
Pink Pocci
Before
1month on
Before
1 month on
Purple & Cyan acro
Before
1 month on
Green Table
Before
1 month on
Pink Stylo
Before
1 month on
Misc. acro
Before
1 month on
Blue/green table acro
Before
FTS 1 month on. Not much to look at yet as corals are still small frags.
PostPosted: Sat 28 Mar, 2015 11:58 am
by tommoo
very interested in your drainage pipe for water changes? could we grab a close up on it please? where does it sit on the tank?
PostPosted: Sat 28 Mar, 2015 1:52 pm
by chrismelb
tommoo wrote:very interested in your drainage pipe for water changes? could we grab a close up on it please? where does it sit on the tank?
Thanks Tommoo, the drainage pipe for water changes was in my acrylic tank. I no longer have this since switching to the glass tank. In the acrylic tank, I had it plumbed through the bottom panel and hose went through the cabinet panel and sat inside cabinet stand. You can see its position in the tank in one of the pics on my very first post
PostPosted: Thu 25 Jun, 2015 5:49 pm
by chrismelb
Long over due for an update, 3 months since last. Tank has now hit 8 months of age (However, not all corals are 8 months in as some have been added along the way).
Here are the pics :thumbsup:
Purple Pocci
Original
Now
Green Pocci
Original
Now
Pink Stylo
Original
Now
Teal Acro
Original
Now
Purple Cyan Acro
Original
Now
Zoas
Now
Table Acros
Original
Now
Unfortunately lost the little blue purple one but replaced with cyan one
New Addition
Video: (Make sure your watching it in HD via ur Utube settings)
PostPosted: Thu 25 Jun, 2015 8:35 pm
by Mxett
fantastic effort mate
PostPosted: Mon 04 Jan, 2016 3:34 pm
by hanzelz
Wow....just WOW!!!
Where did you get the bracket for the light?
PostPosted: Tue 09 Feb, 2016 1:34 pm
by chrismelb
hanzelz wrote:Wow....just WOW!!!
Bracket is all DIY - heatsink and fabricated acrylic. :thumbsup:
Im long overdue for a update. Will provide this soon with pics :).
PostPosted: Sat 23 Apr, 2016 12:16 pm
by millotoli
So awesome
Looking forward to the update
PostPosted: Fri 27 May, 2016 5:28 pm
by chrismelb
Ok finally got around to doing an update. Things have been going well. Cause work has been busy, I haven’t been as religious with my weekly water changes but as you can see from the pics below things are going well. Unfortunately the two acros on the upright scape didn’t survive through the neglect. But the rest is ticking along nicely. Especially the poccis and stylo, which are now shadowing other acros. I plan to add a birdsnest and maybe a rainbow monti to fill the tank a little more. Hope you enjoy the pics.
Yes, now have two yellow tail damsels. Really think damsels are underrated
PostPosted: Sat 28 May, 2016 10:28 pm
by Wakareefer
Awesome growth in such a small tank mate, what salt are you using? And are you dosing anything?
PostPosted: Sat 28 May, 2016 11:18 pm
by chrismelb
Thanks mate. I'm using RedSea Coral Pro. Not dosing anything, not even alk/calc. These are elevated in the pro salt (SPS portions) so I'm just relying on water changes. I do feed the fish ofcourse ;). As corals look happy, I haven't bothered to check parameters.
Usually with my tanks, I spend more time maintaing than enjoying but this one is so simple that I actually have time to sit back and watch it grow, having it at work also helps.
PostPosted: Sat 28 May, 2016 11:33 pm
by wayne2.0
Kickass pint-sized tank :)
PostPosted: Mon 30 May, 2016 8:31 pm
by Callumkscott
Tank looks good and I enjoyed reading the thread. Thanks
PostPosted: Mon 30 May, 2016 9:24 pm
by Mr Miagi
Awesome dude! Love a good pocci!
PostPosted: Sat 04 Jun, 2016 3:05 am
by Emperor_tang
Wow! Tank is coming along very nicely, loving it! Any new updates?
PostPosted: Tue 07 Jun, 2016 11:10 pm
by Wakareefer
One more question mate, since your not surface skimming what do you do about the scum/oils accumulation
On the surface?
PostPosted: Fri 10 Jun, 2016 4:52 pm
by chrismelb
Emperor_tang wrote:Wow! Tank is coming along very nicely, loving it! Any new updates?
Will get some new pics up shortly :thumbsup:
Wakareefer wrote:One more question mate, since your not surface skimming what do you do about the scum/oils accumulation
On the surface?
Good question, I don't have anything in place to remove surface films. Only occasionally do I see a film but this tends to clear after a few days, could be tied to water changes. I was thinking of using a Tunze 9001 skimmer as they surface skim but as its not been an issue i've not bothered. I'm enjoying the simplicity of this tank.
Re: Aquaforest - SPS Pico Work Tank (12 litre)
PostPosted: Tue 09 Aug, 2016 6:38 pm
by chrismelb
Bit of an update here:
Tank has a been a bit neglected last few weeks and I have missed a couple of water changes.
Unfortunately, the new yellow tail damsel also passed away from aggression from other damsel - these guys can be quite aggressive!
To more positive news, I am really excited to see Aquaforest products here in AU http://aquaforest.eu/en/. I've heard really good reviews about their range. I am now switching salt from RedSea Coral Pro to AF Reef Salt. My impressions so far on the salt are great, it mixes clear in 15mins as stated and coral polyp extension is noticeably greater for days after water change.
I will also start to test Alk consumption and if a drop is detected between water changes I will dose the AF balling: Calcium, Magenesium, KH Buffer, and Reef Mineral Salt. After four weeks I'll report any change and introduce Component Strong. I want to start slowly to determine what is causing change.
More to follow shortly :)
Re: Aquaforest SPS Pico Work Tank (12 litres)
PostPosted: Wed 25 Oct, 2017 12:53 pm
by UnderCoverBrother
Bravo - great thread, its unfortunate the acyrilic let go :(
PostPosted: Wed 28 Nov, 2018 2:33 pm
by Combatants
Any updates on the Aquaforest?
PostPosted: Mon 06 May, 2019 12:30 am
by chrismelb
No new update, sorry. As you know this tank lived on my work desk. I've since changed jobs and as a newbie, didn't feel confident setting up a tank on my desk. I've now been at this new place a year, and it is simply too busy to even look at a tank at work. The tank in this journal was packed up. But I am in the process of starting another at home, as I love the nano tanks :).
Stay tuned for the new journal :).
